Question about Karcher 26410050 Pressure Washer TRacer Wide Area Surface Cleaner (T350) For Up To 2650 PSI
T racer will not spin when water switched on - Karcher 26410050 Pressure Washer TRacer Wide Area Surface Cleaner (T350) For Up To 2650 PSI
Blue hat boat racers,batteries inserted,but propellers do not spin
Put it in water - the two screws on the bottom of the boat act as a safety, the props will only spin when the boat is in the water.
Mar 22, 2015 | Blue Toys
Spiderman racer build
Fault 1E
no water supply
filter is block
leackage in bottom leack switch
float type check it
Jun 12, 2013 | Toys
Washer runs rough and noisy at high speed
racers and water seal in the wash tub will damage........replace both racers and water seal
Jun 08, 2013 | LG WM1812C Front Load Washer
Makes noies on spin cycle
check the racers and water seal in inside the wash tub.......or tub mounting bracket.....
May 25, 2013 | LG WM-2277HW Front Load Washer
Karcher t50 t-racer not spinning
Check power to start switch and relay switch to motor.
Oct 22, 2012 | Karcher Garden
Beach Racer Quad fuse for high gear keeps blowing out
Called wayfair with same issue. Extra fuses are sent attached to the battery packs. They said to go to Walmart or an auto parts store and to get a 40 v fuse instead of the 30 that comes with the quad. Worked fine when we switched the fuse so far.
Dec 30, 2011 | Activeforever CTM Kids Electric Big Beach...
I want cheats for Ridge racers5
I'm not sure if you're asking for cheat codes for use with Ridge Racer DS for the Nintendo DS, or Ridge Racer V for the Playstation 2 - Unfortunately, neither game has actual cheats built into them. You can, however, use a hex editor tool (also referred to as a Trainer, Gameshark, or Action Replay), which would allow you to cheat.
Intec Action Replay for the Nintendo DS: http://us.codejunkies.com/Products/NDS-Action-Replay---USA__EF000142.aspx
Action Replay codes for Ridge Racer DS for the Nintendo DS: http://us.codejunkies.com/search/codes/Ridge-Racer-DS_Nintendo-DS_17825879-17___.aspx
Intec Action Replay for the Playstation 2: http://us.codejunkies.com/Products/PS2-Action-Replay-MAX---USA__EF000306.aspx
Action Replay codes for Ridge Racer V for the Playstation 2: http://us.codejunkies.com/search/codes/Ridge-Racer-V_PlayStation2_1048770-1___.aspx
Mar 03, 2009 | Nintendo DS Console
Repair of Mini Racer
That probbly means the motor is permanently unfixable- you could get a new motor or get a new racer at toys R us
Jan 17, 2009 | National Kids Mini Cooper Racer Ride On...
Karcher 26410050 Pressure Washer TRacer Wide Area Surface Cleaner (T350) For Up To 2650 PSI Logo
132 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
