Question about Boost Mobile ZTE Force 4G LTE
Configure apn my apn configuration for my lte is gone after one of sprints software updates. I need the apns for boost
How do I find or where do I find APN?
There is no need of APN....jus set default configuration
Jan 17, 2016 | Nokia Lumia 635 &Cortana& 8GB Unlocked GSM...
Good Afternoon..... I cant receive or send pictures what is the APN code for SVP G13 watch phone
An Access Point Name (APN) is the name of a gateway between a GPRS, 3G or 4G mobile network and another computer network, frequently the public Internet. A mobile device making a data connection must be configured with an APN to present to the carrier.
For AT&T
Programming non AT devices with the correct APN and MMS data settings AT...
For Tmobile.
Mobile apn settings Step by Step Configuration
Oct 16, 2015 | SVP G13 Gsm Unlocked Watch Cell Phone...
Samsung s4 I deleted the apn on accident how can I get them back
Every carrier uses its own APN Settings to get its 3G/4G LTE network working on an Android smartphone or tablet device. Now, these APN settings are usually "downloaded" automatically to your phone when you insert a SIM card. BUT, there are times where the APN are not selected automatically OR when the APN settings are not downloaded.
In those instances, your 3G/4G LTE data will not work but that can easily be fixed.
Step 1. First, browse your Settings menu and find the "Access Point Names" menu. This is usually under "Mobile Network Settings" or "More Mobile Networks" or "Mobile Networks" under Settings menu depending on the Android device used.
Step 2. Once you are in the APN Settings menu, first thing you should check it that the APN is on the correct one. If the correct APN is not checked (sometimes this happens), simply check ON the correct APN for your carrier. That will make your 3G/4G LTE data working right away.
Step 3. There are also times where the wrong APN is listed or there's simply no APNs listed. In these rare cases, you can simply add a new APN, hit the "+" button. 25264381-evzu5111kn4ie1titkzzffdn-4-2.jpg
Step 4. For APN setting, the "Name" can be anything. "APN" setting is the most important, usually you only have to fill this out for your phone to work.
Step 6. Hit "Save" when done.
Step 7. Next, make sure to select the new APN Setting you have saved. Within 5-30 seconds, your phone should start picking up 3G or 4G LTE signals and your data should be working again on the phon 25264381-evzu5111kn4ie1titkzzffdn-4-14.jpg
Nov 01, 2014 | Cell Phones
Cant recieve or send out mms
Here are the APN settings for your phone and T-Mobile.
These need to be correct for mms to work.
APN & data settings
To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From the Home screen, press the Menu key.
  2. Touch Settings.
  3. Touch Wireless & networks.
  4. Open the Access Point Names or APNs. menu (in steps above)
  5. If there is a T-Mobile APN, touch it. If not, press the Menu key, and touch New APN.
  6. Verify and update the following settings for the Data APN:
    • Name: T-Mobile
    • APN: epc.tmobile.com or fast.t-mobile.com (for LTE devices)
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: <Not Set> OR Internet+MMS (depending on software version)
  7. Press the Menu key.
  8. Touch Save.
  9. In the list of APNs, delete all others that may appear. If there is a FOTA APN, you may leave that one. To do this:
    1. Touch the APN you want to delete.
    2. Press the Menu key.
    3. Touch Delete APN.
  10. Verify that there is a circle next to the one remaining APN to show it is activated.
  11. Perform a soft reset.
  12. Test your data connection, by accessing a web page or sending a picture message (MMS) to yourself.
Sep 15, 2014 | ZTE Concord Blue Smartphone - T-Mobile 832...
What are the apn settings for t mobile on unlocked i717
APN: epc.tmobile.com but you it's an LTE Device, use: fast.tmobile.com instead
Proxy: <Leave in Blank>
Port: <Leave in Blank>
Username: <Leave in Blank>
Password: <Leave in Blank>
Server: <Leave in Blank>
MMS proxy: <Leave in Blank>
MMS port: <Leave in Blank>
MCC: 310
MNC: 260
Authentication type: <Leave in Blank>
APN type: default,supl,mms
APN Protocol: Leave it to the Default one
Jul 16, 2014 | Samsung SGH-i717 Galaxy Note HD LTE 16GB...
How to open mms in android samsung mobile the mms which i have received
Hello Sanju
I assume there might be MMS settings which you need to get from your service provider.
You can try these steps
Click on Settings ' Wireless and Network ' Mobile Networks - and ensure "Use packet data" is on.
Also.. in the same menu window - enter Access Point Names and ensure that you have your network provider's MMS APN configuration in there. Some network providers can send the configuration to you by their website or a phone code.
Some network providers might request you need to have at least a WAP or Internet APN (Access Point Name) configuration before MMS gets delivered to your mobile phone... if the above still doesn't help you download MMS, install a WAP or Internet APN configuration through your network provider - (by: Naith_KK)
Hope this should do the trick.
Feb 18, 2014 | Cell Phones
How to add apn for sgh a597 on straight talk
AT&T phone on Straight Talk (sprint)? Unfortunately, AT&T uses GSM which is not compatible withSprint's CDMA technology.
Straight talk runs on the Sprint network, same as Boost and Tracphone. Although some phones are the same, some only work on certain networks.
Sep 04, 2012 | Samsung sgh-a597 - Sgh-a597...
Manual configuration of my "MY
Manual Configuration for Globe Subscriber:
GPRS Settings
GPRS Data Account 3 Account Name: myGlobe MMS Access Point Name (APN): mms.globe.com.ph GPRS Data Account 4 Account Name: myGlobe GPRS Access Point Name (APN): www.globe.com.ph WAP Network Settings
Rename Profile: myGlobe WAP Homepage: http://www.globe.com.ph/globe.asp Data Account: myGlobe GPRS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
MMS Network Settings
Rename Profile: myGlobe MMS Homepage: http://192.40.100.22:10021/mmsc Data Account: myGlobe MMS Connection Type: HTTP Proxy Address: 203.177.042.214 Proxy Port: 8080
Manual Configuration For SMART subscribers:
GPRS Settings
GPRS Data Account 1 Account Name: Access Point Name(APN): GPRS Data Account 2 Account Name: SMART GPRS Access Point Name(APN): Internet Exit and save settings WAP Network Settings
Rename Profile: Smart WAP Homepage: http://wap.smart.com.ph Data Account: Smart GPRS Connection Type: HTTP Proxy AddressL: 010.102.061.046 Proxy Port: 8080
Rename Profile: Smart MMS Homepage: http://10.102.61.238:8002 Data Account: Smart GPRS Connection Type: HTTP Proxy Address: 010.102.061.046
Jun 27, 2011 | Cell Phones
What is the apn
APN is Acces Point Name.
In mobile phones it's usually used to configure internet connection or MMS messaging, every cell service provider has differrent APN and optionally password, you should contact your provider, to get APN.
May 13, 2011 | LG KU990 Viewty
Boost Mobile ZTE Force 4G LTE Logo
16 people viewed this question
Top Boost Mobile Cell Phones Experts
Lawrence Oravetz
John mullen
Are you a Boost Mobile Cell Phone Expert? Answer questions, earn points and help others
