Question about Scotsman MDT5N40A-1H 523 Lb Touchfree Nugget Ice Machine/Dispenser
Drops ice without being called for - Scotsman MDT5N40A-1H 523 Lb Touchfree Nugget Ice Machine/Dispenser
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
Is the machine dispensing ice just after the cup is removed in front of the hands free sensors? If so then you need to add MDT portion controlled dispensing kit. A time - delay relay kit is now available for addition to the MDT3,MDT4, MDT5 and MDT6. The purpose of the kit is to limit the amount of ice dispensed per activation. The kit number is KPC-MDT. The kit includes a time delay relay and potentiometer. When the touch-free dispense system is activated, the time relay powers the dispense motor and / or door solenoid for a limited time. That time is adjustable to accommodate the cup or glass being used. a typical application for the kit is a high volume dispense situation where the amount of ice spilled is unacceptable. Spilled ice is usually caused by overfilling the container during dispensing,followed by the extra ice being dumped into the units drip tray.Adding the kit allows the amount of ice per per dispense to be set to match the amount an individual needs,so there is less waste. This is especially helpful on the MDT6, which is a high volume,rapid dispensing model. Now if the machine is just dumping ice when no one is around it, then replace the hands free sensor.
Posted on Jul 17, 2014
I have an LG model LFX25974ST refrigerator. My issue is the ice flapper that allows the ice to drop will not open.partment and clog up. if i hold the flapper door open manually the ice drops down and
http://c.searspartsdirect.com/lis_png/PLDM/F1107036-00005.png
405A
on diagram Motor,dcPART NUMBER: EAU59551201 $27.41
Back ordered Call Marcone appliance ... Or goto searsparts
but this is the part you need.... To access it take outer door appart
see diagram on searsparts.com
Jan 16, 2014 | LG LFX25960ST Stainless Steel French Door...
Is there a way to make ice without using ice cube trays?
Sure - there are a few ways you can be inventive and make ice without the trays. First of all if you have a lot of freezer space you can shallow fill plastic cups. Or fill a shallow cake tin with water and freeze. Once it's frozen, you can smash it into pieces by dropping it onto the kitchen counter.
Feb 18, 2013 | Home
I have a Kenmore white side by side refrigerator Model# 106-56542400. The ice maker is not working we already replaced the filter a week ago and it is still not making any ice at all. On the left side when...
Up on the top right hand corner of your freezer, next to where the ice drops, there is a small black tube. That tube freezes and it will stop the ice maker from working. Take a blow dryer to it until you see the tube without the ice hanging from it. you will have to do this about once every 6 months. After paying for a repair man to come out and fix it, this is what he told me to do. Good luck.
Oct 22, 2010 | Kenmore Refrigerators
Ice maker quit after my husband over filled the top shelf and blocked the air flow for the freezer. The freezer started to defrost itself and water was on the floor in front of the freezer. He unblocked...
Yes, If you will try a couple things. Fill ice maker with water and let freeze. Tell me if it will drop the ice when frozen, Let me know that and your model number. I am doing this to decide which one is the problem. The ice maker or the water control valve. Sea Breeze
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Maytag ice maker not dropping ice
The ice maker is the single most hateful appliance I've ever worked on. It is a marvel of electronic theory and complication. The contacts in it are the smallest in all appliancedom. The timer unit costs almost as much as a whole new ice maker. You know where I'm going. Luckily, you probably can replace the unit yourself and avoid a service call, but put a towel below the work area to catch all the screws you will drop.
Apr 25, 2009 | Maytag Matag 25.6 Cu Ft Side By Side...
Ice maker is freezing to make ice, but the ice will not fall .
If it's filling too full of water (big, thick ice cubes) your water valve has failed.
If the cubes are normal size but th IM won't cycle into "harvest" to eject them, replace the whole IM.
SG
Apr 07, 2009 | Refrigerators
Items dropped in the dispenser
you will need to cal someone to have whatever it is removed.
Feb 13, 2009 | Refrigerators
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
Scotsman MDT5N40A-1H 523 Lb Touchfree Nugget Ice Machine/Dispenser Logo
56 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
