Question about Minn Kota Boating
Speed dial does not work unless I put a piece of card board under the right side?
Minn kota power drive speed dial?
  • 10 Answers
SOURCE: Where can i get a circuit board for my minn kota
http://www.northlandmarine.com/MinnKotaQuickRef.htm
You need your serial number of the trolling motor, length of shaft, and thrust poundage.
or you could call Minn Kota direct and give them the same information at 800-227-6433.
Posted on May 02, 2009
  • 10 Answers
SOURCE: proper batterie hook up on minn kota 70 thursh
Raventrans click this link to take you to a website which will you can click on schematics. I suggest adding a 50 amp fuse for your 70 lb thrust unit. scroll to the end of the schematic to find the battery hookup for a 24 volt hookup.
http://www.mikesreelrepair.com/./index.php
Posted on May 08, 2009
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Posted on Jun 28, 2009
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Posted on Jul 13, 2009
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
What is amp. draw of minn kota 40pd? thanks
Digital Maximizerâ„¢
Digital Maximizerâ„¢. Up to five times longer run time on a single charge.
Conventional speed coil technology wastes energy by delivering a constant, steady flow of power to the motor regardless of the speed setting resulting in wasted energy.
Pioneered in 1985, Minn Kotas innovative Maximizerâ„¢ technology delivers the precise amount of power needed at any setting, along with variable speed control. Now, our advanced, digital microprocessing optimizes draw to extend battery life and reduce damaging heat. Get up to five times longer run time on a single charge.
Would think you would have to ask direct, but standard practice is to run your Minn Kota from a separate battery anyway, so the draw is pretty irrelevant to main engine starting.
your manual is here and states it has a battery level meter.
http://www.minnkotamotors.com/Support/Owner-Manuals/PowerDrive-V2/
Minn Kota Motors
Jan 06, 2016 | Minn Kota Boating
My minn kota 85 trolling motor is stuck in one speed,i need a manual
first of all what speed is it stuck in if hi speed sounds like a mother board problem if a lower speed check the speed dial
Apr 04, 2013 | Minn Kota Boating
The motor has two speeds. Very fast forward and very fast reverse. The speed control is not functioning
A lot of these units have 2 year warranty. Minn Kota web site list authorized warranty repair centers. The foot control unit most likely got water in the digital switch. If not under warranty any longer, open it up and see if any water bubbles in the sealed board where speed switch makes contact. If so you will need new foot control.
Sep 30, 2010 | Minn Kota Powerdrive 68PD V2 Pontoon Motor...
Jun 09, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Can you wire a minn kota foot control
.....I think so ;)
Here's a schematic, complete with wiring diagram:
Maxxum 70 Bowmount
Best of luck!
Mike
Jun 04, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn Kota power drive trolling motor will not steer to the right **** huard my minnkot will only steer left. I do not have a foot pedal, use the wrist remote control. even goes left when pressing down...
There is a good chance that he control board is bad. This is a common problem with these units. I have replaced my control board twice.. When the control board goes out, the some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
May 29, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Prop spins slow on any speed on the foot pedal
There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
May 27, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
It is the circuit board in the foot pedal. You will have to replace the whole foot pedal. This is a very poor design. The thin plastic which protects the contacts gets a little hole which allows water to enter and consequently the contacts corrode. Has happened to me two times in past four years. It might be OK for operation in a dirt-free water-free environment; but not under actual fishing conditions.
Apr 29, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Ran aground on lake,now stuck on high speed,can't lower speed
My Minn Kota 55 powerdrive had the same problem except mine occurred while it was trailered in the yard. High speed only, everything else worked great. From what I could research the control module is a frequent problem. Took a chance and purchased a new control module and this cured the problem. Maybe this happening and running aground was just concidental.
Apr 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Minn kota turbo 35 27lb thrush trolling motor
I have a minn kota turbo 35 27lb thrush trolling motor after 3 hours of running it the motor dies
Mar 01, 2008 | Minn Kota GPS
Boating Logo
23 people viewed this question
Top Minn Kota Boating Experts
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Phil Walker
Phil Walker
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
