Which planet has two moons - Televison & Video
Cannot see anything through my tlelescope
  1. Get Stellarium or another fine astronomy program
  2. During the day, point the telescope at a part of the landscape about 100 yards away.
  3. Use the lowest power eyepiece (highest number) in the focal tube.
  4. Center the landscape object in the telescope.
  5. Align the finder scope so that it points exactly where the main telescope is.
  6. At night, leave the scope out to reach thermal equilibrium (about an hour for small reflectors and refractors)
  7. If the scope is on a EQ mount, polar align.
  8. Point the finder at the moon. The moon should be in the main scope also.
  9. Practice finding the moon before you start on the planets
  10. Once you are comfortable with the moon and planets, you can go for the deep sky objects
Mar 24, 2015 | Optics
I cannot get the konusmotor 500 to see out of
Mar 21, 2015 | Konusmotor Electronic 500 Newton 114mm...
Can't see anything thru my orion xt 10 skyquest even after collimation
Oct 30, 2014 | Optics
What planets did galileo discover
Galileo's accomplishments did not include any planet discoveries but were significant nonetheless. The 6 planets known in his time had been known since antiquity. With the help of the newly invented telescope however, Galileo discovered the 4 largest moons of Jupiter. That discovery alone was quite extraordinary but it was its ramification that created more problems.
Back in the 17th century, is was essentially Church doctrine that the Earth is at the center of the universe and that everything else - everything - revolved around it. What Galileo found was not only do these moons exist, they revolve around Jupiter, not the Earth. This what ultimately got him exiled in his later life.
One other discovery Galileo had using the telescope was that Saturn had "ears" on each side. Later, as telescopes became larger and could resolve more detail, it was found that the "ears" was actually a ring around the planet.
Sep 08, 2014 | Optics
Name all of the planets people have walked on.
Earth. That's it. People have walked on the Moon, but you said planets.
May 20, 2014 | Cambridge University Press Planets To...
How do i focus the telescope
May 06, 2014 | Tasco Novice 30060402 (402 x 60mm)...
How does the moon affect earth
The moon is larger than moons of other planets and helps slow the earth to have 24 hours days that we know. It gives us the tides. It protects earth from asteroids or other dangers
Nov 25, 2013 | Vacuums
I cannot see anything through the lens of my brand new 6 SE. What should I do?
During the day, point the telescope at a part of the landscape about 100 yards away. Use the lowest power eyepiece (highest number) in the focal tube. Center the landscape object in the telescope. Align the finder scope so that it points exactly where the main telescope is. At night, leave the scope out to reach thermal equilibrium (about an hour). Point the finder at the moon. The moon should be in the main scope also. Practice finding the moon before you start on the planets Once you are comfortable with the moon and planets, you can go for the deep sky objects
Dec 28, 2012 | Celestron NexStar 6 SE (354 x 55.88mm)...
I can't see anything out of the large scope
Use the 20mm to view an object (building, tree etc.) far away during the daytime. Align the finderscope to the object.
To view the moon, leave the scope out to equalize the temperature for at least 1/2 hour. Use the 20mm and no barlow. Point the scope towards the moon by sighting along the barrel of the scope, then use the finder to zero in on the moon. You may then switch to the 4mm eyepiece. for a more magnified view of the moon. You will have to keep moving the telescope because of the earth's rotation. The higher the magnification, the more you will have to adjust the scope. Because of the cheap finderscope, finding the planets will be difficult. Best to always sight down the length of the scope to get you close. The planets will be small and indistinct.
This is not a astronomical telescope! May be used for views of the moon but the cheap mount is not suitable for other planets. Max power would be 225x NOT 420x as advertised. The erecting prism is for terrestrial use only.
Nothing discourages an amateur astronomer more than a toy store telescope. My advise would be to use this scope for nature watching and go buy a good telescope (Meade, Celestron, Orion etc.). Even Those 60mm refractors are superior to this! A descent scope would cost a minimum of $200
Nov 03, 2010 | Bushnell Deep Space 78-9512 (120 x 60mm)...
Starguide can not even find the moon let alone planets
question answered on another post-- the moon and planets are CALCULATED and will always have some error. Your initial alignment MUST BE very accurate.
Jun 06, 2009 | Optics
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
