Frymaster PSDU50 Shortening Disposal Units Logo
A
Anonymous Posted on Apr 14, 2014
How many ounces in a cup - Frymaster PSDU50 Shortening Disposal Units
Brad Anderson
Level 1:
New Friend:
  • Contributor 29 Answers
  • Posted on Jul 16, 2014
Brad Anderson
Contributor
Level 1:
New Friend:
Answers
29
Questions
Helped
24084
Points
31
How many cups is in 50 grams?
here you go!
http://www.answers.com/Q/How_many_cups_is_50_grams?#slide=1
50g = 1.8 ounces there are 8 ounces in every 1 cup so 1.8 ounces / 8 ounces = .225 cups which is a little less than a quarter of a cup, so look for a
How many ounces are in 8 cups of water
Hi
There are approx. 64 ounces in 8 cups of water
hope this helps Nick
1helpful
I need to convert 150 grams of dates to + how many cups
The first thing you must do it's convert grams to ounces. If you put grams to ounces in a Google search a Google converter will automatically pop up. Enter the amount of grams you're trying to convert in this case 150 and you will receive an answer of 5.29109 ounces or approximately 5 1/3 ounces since a cup contains 8 ounces this is approximately 5/8 of a cup
2answers
How many fluid ounces in a cup?
There are eight (8) fluid ounces in a cup, so five cups is 40 ounces.
2answers
What equals 48 ounces??
Hi Yesenia
There are a couple of possible answers, depending on whether you're talking about liquid ounces, or weight ounces.
For liquids, there are 8 fluid ounces in a kitchen '1 Cup' measuring cup. That means 48 fluid ounces are the same as 6 cups, 3 pints (2 cups per pint) , or 1-1/2 quarts (two pints per quart).
For weight, there are 16 ounces in a pound. (One fluid ounce of water also weighs one weight ounce, which is the basis of the adage 'A pint's a pound, the world around', since a pint is 16 fluid ounces, and 16 fluid ounces of water, or near-water like some beer, will then weigh a pound' ).. Anyhow, in this case, 16 goes 3 times into 48 ounces, so it will weigh 3 pounds.
For metric, 2.2 pounds per kilogram, or 29.5735 milliliters per fluid ounce.
Cheers!
1helpful
There are eight (8) ounces in a cup so 16 ounces is two (2) cups.
1helpful
How much coffee do you put in for 100 cups? thank you
I can't say how much cups but if you want to make 60 ounce coffee Then you need 3.25 ounce ground Dunkin coffee Let 10 ounce each cup so for 100 cups you need 1000 ounce coffee. For that (3.25*1000)/60. =54 ounce ground Dunkin coffee Thanks Please rate my work I gave you a very good answer
1helpful
How many ounces is 15/8 cups?
Well, 1 cup = 8 ounces
15/8 cups = 15 x 8/8 ounces = 15 ounces --- almost 2 cups as you might expect
Top Frymaster Kitchen Appliances - Others Experts
john h
Are you a Frymaster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
