Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
Green and red lights alternate while charging
98 ford explore just put a new alternator in .I got power from yellow wire but not the green wire .green is ground rite
green/red is the charge lamp circuit. when grounded it should turn the light on,if it doesnt, you may have a blown fuse. the lamp circuit provides the "turn on" signal to the alternator as a positive voltage. the voltage regulator is a gounded load until the alt starts charging, than it puts out a positive voltage to turn out the light.
Nov 08, 2014 | Ford Cars & Trucks
What wire on the ignition switch goes to the alternator on a 86 thunderbird
The gray-yellow wire from the key switch powers the charge light.
The light green-red wire goes from the charge light to the alternator.
Apr 16, 2013 | 1988 Ford F 150
M28 battery is flashing green and red when put on v28 milwaukee charger
Is the battery hot or cold??? either temp. extreme will do that...
otherwise the battery is shorted internally and so the charger will not charge it...the battery will need to be replaced.
heatman101
May 21, 2011 | Milwaukee Tool Milwaukee V28 1/2" Hammer -...
Continuous alternating one green and three flashing red battery
note.gif NOTE: Battery operating time (the time the battery can hold a charge) decreases over time. Depending on how often the battery is used and the conditions under which it is used, you may need to purchase a new battery during the life of your computer. Check the battery status light — If the battery status light flashes orange or is a steady orange the battery charge is low or depleted. Connect the computer to an electrical outlet.
If the battery status light flashes green and orange, the battery is too hot to charge. Shut down the computer, disconnect the computer from the electrical outlet, and then let the battery and computer cool to room temperature.
If the battery status light rapidly flashes orange, the battery may be defective. Contact Dell _I found this on : http://support.dell.com/support/edocs/systems/latd820/en/ug/index.htm Hope this helps and good luck. if i "fixed ya" please rate me. thanks-jmattes
Oct 22, 2009 | Dell Latitude D820 Notebook
The green light that indicates charge keeps flashing red and green alternatively even when the battery is fully charged
That is an indication of an internal failure of the battery (Bad cell etc). It may well remain functional, but the only way to resolve is a replacement battery
Oct 13, 2009 | Dell Latitude D510 Notebook
No power to alternator green/red wire on dash light
alternator drived mechanically by a belt receiving energy from the crank shaft . and it chargs the battery , so your battery dead or the cables nedd to be replaced
May 31, 2009 | 2002 Ford Ranger Regular Cab
No 'green' light on bacl of my 'old' Vivitar 285
Then I'd say it's a reasonably sure thing that the green light is just burned out, The lights are supposed to be off at first, then red when there's a partial charge, then green when there's a full charge, then flashing between red and green when the "battery saver" kicks in. If you're seeing off, then red, then off, then flashing red, then that means everything in the charging circuit is working perfectly, there's just no green light.
Nov 30, 2007 | Vivitar 285HV Flash
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
41 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
