Bsr p144r single automatic/manual turntable unit instruction manual
2 Suggested Answers
Grubhead
  • 5349 Answers
SOURCE: 1960s stereogram.bsr turntable turning to do fast.
If I can understand you right, the turntable is running fast. I don't think you need a new motor, generally the deck will run slow if the motor is knackered (or not at all). What you need to do is remove the platter, you will find a horseshoe bracket holding it on at the spindle (it may be covered up so you wil have to remove the cover part often a silver disc). The most likely cause will be the rubber idler tyre being worn damaged etc or out of place. There could be grease dirt or something else causing the problem.
Posted on Mar 26, 2010
Testimonial: "excellent thanks"
Hey there, After a power outage the motor that drives the platter "BSR turntable" does not function. Is there a fuse or some other likely suspect?
If the motor is directly connected to a mains supply then the chances are that when power was restored it burnt out or damaged the motor itself. Following the mains lead into the unit should answer where the power goes. If it goes to a transformer and it's associated power supply the problem will be found there.
Nov 07, 2016 | Audio Players & Recorders
I need a service manual for the BSR McDonald CA 50 turntable
BSR tended to make old style turntables, ones with a 78rpm speed on. I don't the model in question, but if it is a one of these, there's not much to them. Basically a rubber tyre runs inside the rim of the platter, while the tyre is pushed on a mains powered motor, in at least 3 different positions (depending on the speed). The tyre moves up and down depending which speed is selected.
Speed faults are caused by either a bad motor, or muck, oil, or grease in it.
A faulty tyre that is worn and doesn't push on the motor or platter anymore or not hard enough. Plus of course tyre height setting wrong.
Nov 08, 2015 | Audio Players & Recorders
Start stop button will not work when I do not want to use foot peddle, it tries but nothing happens. when I use the BSR IT DOESN'T WORK with it , I always unplug foot peddle before I try, followed the...
I have a BSR on my machine but every time I use it, I have to go through a checklist, otherwise it will not work. I use the foot control with mine, otherwise it will continue to sew in place when I stop moving the fabric. If you have never used your BSR, maybe it hasn't been calibrated for your particular machine--if your machine is ever serviced, it's recommended to bring the buttonhole and BSR accessories so they can calibrate them properly to your machine.
In the meantime, this link may help:
Thread Bernina BSR Help Please
Nov 11, 2017 | Bernina Sewing Machines
I have a BSR C197 Turntable that won't switch from "off" to "on". It just sticks on off. Everything turns manually, but I cant move the little lever from off to on.
You will need to open the deck up from underneath. This should reveal some mechanical cause as to why the switch does work.
Aug 24, 2013 | Audio Players & Recorders
Turntable does not rotate when switched 'on'.
K, I'm not familiar with that particular stereo unit but there were a lot of stereos from years gone past that used a turntable made by BSR. When you activate the switch to start the turntable listen closely to the record platter for a hum or possibly the sound of a motor turning (they're quite quiet). Is the switch lever you pull rectangular made of black plastic, you pull it towards you one click to start the record and pull it one step further (spring loaded) to make the tone arm lift from the record automatically? Just want to make sure I'm talking about the right turntable before we continue.
Oct 10, 2008 | Audio Players & Recorders
115 people viewed this question
 Grubhead
Grubhead
