Question about Splendide Ariston Stackable Washer & Dryer
Code H20 on washer - Splendide Ariston Stackable Washer & Dryer
    Top Expert:
  • 5,913 Answers
Water solenoid
Posted on Sep 22, 2017
Indesit washing machine showing H20
code showing h20 is the clue water is also known as h20,so your problem is the inlet valve letting the water into the back of your machine needs replaced or water pipe is kinked and no water is at the supply,. these valves are cheap at 10 dollars,adrian.....
Dec 20, 2014 | Indesit W 123 Front Load Washer
H20 fault code splendide washer
Hello!
Seems that a fill valve is broken.
Usually in such cases, a valve replacement is required.
Nov 19, 2013 | Splendide ARWXF129W - Washer 24" Whit...
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
Indesit Evolution W16s washing machine H20 error code
if there a advance cycle button push it an see if the timer will advance to spin if not turn the power off to washer an wait a couple mintue an the door will open
Apr 24, 2010 | Washing Machines
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Fault code h20 flashing on indisit wie127 washing machine
H20 is indicating a problem with the incoming water supply to washer.
Check the inlet hose/s for kinks or other restriction, ensure that you have a good pressure to the washer, make sure tap/s are fully turned on.
If all o/k,then could be a problem with the inlet valve/s
Thankyou.
Jan 21, 2010 | Indesit W 123 Front Load Washer
Does not complete cycle comes up with -H20 on screen
Hi.
Fault code H20 is indicating that the washer is not filling correctly, check tap/s hoses, and inlet valves for water supply.
Thanks.
Nov 07, 2009 | Indesit Washing Machines
I have a hotpiont wf860 flashing fault code H20, please help
h20 code indicates that the appliance is not filling at all or filling to slow,check pipes are not kinked and taps are open correctly
Jun 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Does anybody know what H20 code stands for?
H20 code stands for low water pressure. In case it flashes on the screen, disconnect the hot and cold pipe and check them to see if there is enough water pressure
Dec 12, 2008 | Hotpoint Ultima WD72 Front Load...
Splendide Ariston Stackable Washer & Dryer Logo
73 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
