Question about Frigidaire FWS833A Top Load Washer
Pieces of matal broke off under agitator in washer
    Problem Solver:
  • 34 Answers
THATS THE TRUNION ON TOP OF CONE SHAPED PART IT HAS 2 BOLTS AND A PIECE OF METAL THEY SCREW INTO ON THE CONE SHAPED THING THOSE BOLTS BREAK ALOT IN OVERLOADING
Posted on Sep 02, 2014
Help! I replaced the clutch and motor coupling a month ago. Ran great till this week. The wife washed tennis shoes, it quit agitating and spinning-i could hear the motor running fine. I again replaced the...
Have you checked for any damage on the lid switch at all? Washers won't engage the cycle you're having issues with if the lid switch is faulty. usually a magnet or plastic piece that pushes down the piece to engage agitation.
Sep 21, 2017 | Kenmore 22622 Top Load Washer
Vbsr2080woww
follow this steps and fix it. God bless you
First you will need to identify if you have a direct drive type or a belt drive. The later is obvious if you have belts under your machine it is a belt drive, if not it is a direct drive. Also there are 2 basic agitator types with some variances among them. The 2 piece and the single.
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dogs follow video.
Agitator Coupling / Spline
The other type depending on age of your machine use a spline. Newer GE types have a coupling that gets stripped out and the older GE type has a spline directly on the agitater that gets stripped out. You will need to remove the agitator. The dispenser usually pulls right out. This will give you access to the bolt that holds the agitater down. Remove the bolt, then place your fingers under the agitator and pull up. This can take some force. A belt slid under the agitater can also work. Once off you will see if it is stripped or not.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente of motor coupler
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Jul 09, 2013 | Washing Machines
Washer will spin but does not agitate, checked the belt its ok.
Number 310 probably is stripped out. Mounted under the agitator this is called a drive block/bell.d390837.jpgI believe the part comes with a new bolt also. This plastic piece has splines inside that slip onto the tranny. Over time the splines wear smooth and the washer will not agitate. To get to it you yank off the agitator:
Oct 28, 2010 | GE WDSR2080D Top Load Washer
Can't remove agitator
Get 2 2x2 pieces of wood or 2 oak handles, 20 inches long. lay on on top of the other on the top of the washer. Loop a rope or ******** both sides of the agitator over one of the pieces of wood and tie it to the top piece of wood. Twist the top piece of wood slowly. As the 2 loops tighten up under the agitator the bottom piece holds the rope firmly across the top of machine. This save you from getting socked in the face by the agitator when it come off. You can buy an agitator remover but why not make you one and have so much fun doing it See the pic below? just ease a stick above the 2x4 and start slowly twing till she jumps out. Note: I didn't make this design I found it on line. I would run the rope under the agitator instead of taking a chance on breaking the fins. But that's just me.The trick is to grab it by the neck instead of the base. So try that before concocting a agitator remover. The agitator just snaps on. The drive block under the agitator is stripped out Wh43X10009 91c45a0.jpgis the part number. Here it the manual3c3b88a.jpg
May 25, 2010 | GE Profile WPSR3100W
Need to remove agitator to remove lodged medallion
Remove the agitator top cap, and unscrew the mounting bolt part way. Pull up on the agitator by both sides of the rim, then finish removing the bolt after the device is loose. (Keeps you from smacking your face when the agitator comes loose.) Hope this helps.
Oct 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Hot point washer heavy duty 7 cycle jewelry caught under spinner
if the unit is just a few months old the agitator has not seised the the shaft. the very top of the agitator should unscrew and with a little effert you should be able the lift the agitator off the shaft collect the jewlry and put it back together all should be find
Aug 10, 2009 | GE WBSR3140DW Top Load Washer
Agitator on Estate washer will not fully agitate.
The dogs are broke on the agitator. Need a new set of dogs.......(duh ...not the barking kind, it's part of the agitator) Agitator has two pieces. It is the top piece.
Jul 14, 2009 | Estate ETW4400VQ Top Load Washer
Whirlpool Washer does not spin or agitate.
The motor coupling has broke , it is a small plastic rubber piece you can see under the unit that connects the motor to the gear case. very common problem about $120.00-150.00 to have repaired or $20.00 or so for you to replace. they are not simple but not to difficult to do.
Let me know if I can help or answer any other questions.
Apr 14, 2009 | Whirlpool LSR7333 Top Load Washer
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
Sheet caught under agitator
the agitator comes out..... by simply taking off the cup that holds fabric softner, just pull upward if needed wiggle and pull. under that you will see a raised plastic piece the raised plastic pc is pulled of by using a pliers pull upward under this you will find a bolt 1/2 or 9/16 socket remove bolt and pull out agitator same way by wiggling and pulling upward
Jan 08, 2008 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire FWS833A Top Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
