Question about Konica Minolta bizhub 350 All-In-One Laser Printer
How to rest a transfer unit for a konica minolta c300
  • Konica Minolta Master
  • 6,161 Answers
Replace the transfer belt with a OEM belt assy.
Posted on Dec 30, 2015
  • 12 Answers
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Posted on Mar 20, 2009
  • 12 Answers
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
Posted on Apr 06, 2009
SOURCE: Can i reset my Konica Minolta C250 transfer unit
On your transfer unit there is a .80 amp fuse you can replace. this will reset your belt. make sure you use .80 amp or it will not work. on your fuser there is an inline 1/16 amp fuse next to the plug you can replace for that.
Posted on Oct 01, 2009
  • 44 Answers
SOURCE: Konica Minolta dirty copies
If your dropping toner your losing bias on your Image Unit. You will probably need a new unit.
Posted on Dec 14, 2009
  • 15 Answers
SOURCE: Replacing Image Transfer Roller Unit & Paper Dust/Ozone Remover
hi this unit located in the RIGHT DOOR
Posted on Jan 15, 2010
Another one is konica Minolta c300 given me a code of 3101
TO clear the code did you open and close the front door. Powering the machine on and off does not reset code open closing the front door does. If that does nor work recommend getting a new fuser/fixing unit.
Feb 26, 2015 | Konica Minolta Bizhub C300 All-In-One...
How to rest a C3452 error code on a minolta C300
try a trouble reset turn the machine off hold utility/counter power machine on select trouble reset reboot machine
Aug 17, 2014 | Konica Minolta Bizhub C300 All-In-One...
P7 p28 p5 c300
For P-7 replace the magenta image unit
for P-5 and P-28 unless you know your way around Konica Minolta Copiers you need to have the two sensor located below the transfer belt on the right side cleaned and or replaced, to clean them you must uncover them because when the belt assy. is remove the are covered.
Mar 21, 2014 | Konica Minolta Bizhub C300 All-In-One...
C300 Fuser unit reset
To reset fuser unit you need change the 60mA/250V fuse,located in the fuser unit contact house (a little green diode).
Dec 24, 2013 | Konica Minolta Bizhub C300 All-In-One...
C300 transfer belt to be replaced call technition indication how to settle
you can actually replace a fuse on the transfer belt to rest this code.the fuse cost about 1 dollar versus the 300 dollars the transfer belt costs. I believe on this mode the transfer belt comes out from the left side where the waste toner box is.
Sep 28, 2013 | Konica Minolta bizhub C450P Laser Printer
Trouble c-2551 call service
Cyan Image Unit (Blue) Pull out cyan image unit not the cyan toner, Shake the image unit along the axis of the unit we want developer and toner spread evenly along the entire image unit. Then re-install. Reset code by closing and opening image unit door, not toner door. Worse case replace the image unit you do get bad ones.
Additional questions:
1.Is this a new unit?
2. Is it OEM or third party?
3. Is it new?
4. Did you chip it?
Sep 12, 2013 | Genuine Konica Minolta Konica Minolta...
How to solve model c360 konica minolta the printer displaied change image transfer belt
There are two ways to solve this issue, First you can replace the whole transfer unit or you can install a new un blown fuse to rest the internal counter.
Nov 19, 2010 | Konica Minolta KONICAMINOLTA Transfer Belt...
HALLO. >I HAVE GOT A KONICA MINOLTA C300.THAT IS MAKING LIGHT COPIES EVEN WHEN PRINTING FROM MEMORY A DEMO PAGE. PLS! ASSIST WITH SOLUTION TO THIS PROBLEM?
Have you check, the image units, for is the light copies a b/w issue or a color issue? have you check the consumables does the transfer belt or fuser unit need replacement. are image units OEM or third parties?
Aug 17, 2009 | Konica Minolta Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
78 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
