Question about Hardware & Accessories
Jamar hydraulic pinch guage stuck
Unable to press button much, only goes up to 1 pound with max force
4 Suggested Answers
  • 246 Answers
SOURCE: My pound key is stuck, how do i fix it?
take the phone apart, take off the keypad rubber thing and see if the part that touches the contact is loose or something. most times just taking off the rubber thing and putting it back will fix that problem. Or, take a needle or pushpin and pry up the # key a bit...see if that fixes it. Depending on the model of the phone it might take a while to take it apart...so try the pushpin or needle method first even a toothpick might do it. :)
Posted on Jun 09, 2012
  • 7993 Answers
SOURCE: final Given that Force 1 = 35 pounds and Force 2 = 120 pounds, find the angle between the forces if the magnitude of the resultant force is 140 pounds. Round answer to the nearest degree. (a)62 (b)13
You do have many math questions. If you expect us to do your homework for you, you should post under an appropriate category. I started this morning answering this question with time-consuming diagrams but did not finish and did not post the answer. During the day I tried to locate your question but for the longest time could not until I launched an all Google search over the Internet and found it. Why should anybody go through all this grief to help you? Well I just did not want my previous work to go to waste.
I hope it helps somebody.
OACB is a parallelogram. R is the resultant.
Use the cosine law in the triangle OAC
R^2=(F_1)^2+(F_2)^2 -2(F_1)(F_2) cos (angle OAC)
Replace the variables by their known values and reduce your equation to cos (angle OAC) =-53/112. Solve for angle OAC in degrees
angle OAC =arccos(-53/112). The angle between the two vectors is the supplementary of angle OAC
Posted on Dec 07, 2013
  • 35654 Answers
SOURCE: TC 765. Why are pinch rollers erratic?
Dirty or defective solenoids
Posted on Feb 11, 2016
I Press Play Button, And Tape Goes Into Fast Forward Mode
Pinch Roller linkage is stuck. Clean and regrease and it will work right again- I have done hundreds of them
May 01, 2012 | Teac Audio Players & Recorders
What are the tyre pressure in psi for 650 nt deauville
turn the gage around or somethin. It should be on their if not go get a new guage. And if you do not know what the psi should be at look on the tire. And dont put the psi to the max. if it says 35psi put like 32psi just leave a few pounds off the max psi
Apr 03, 2010 | 2001 Honda Deauville NTV 650
Kawasaki ZZR 250. Engine hydrauliced after fuel
sounds like you blew a set of piston rings. instead of building compression in the cylinder its pressurizing your crank case forceing the oil out the breather into your air box
Dec 18, 2009 | 1992 kawasaki ZZR 250
Oil pressure gage on the dash is reading maxed out since I replaced water pump
the guage reads max when a full ground is applied to the sending wire sounds like that wire got pinched and is touching metal ground grounding out showing max press or the unit itself is saturated and needs to be replaced . the sending unit is right under the distributor a big bell looking object with single wire on it .follow the wire and make sure it doesnt touch ground anywhere but the unit and if you change it dont use teflon on it it needs to contact the metal block to make ground work ..
Nov 19, 2009 | 2003 GMC Sierra 1500
I am unable to wake up my netbook from sleep... pressing the power button or anything else on the keyboard seems to do nothing.
Try having it plugged in and press and hold the power button for 10-15 seconds. If it is stuck in sleep mode this may force it to shutdown and then it will hopefully start up next time you press the power button.
Oct 30, 2009 | Acer Aspire One Netbook 8.9" Notebook
Bucket goes up but wont come down the bucket goes up perfectly fine dumps curls perfect but when i want to come down the bucket goes very slow it takes about 5 minutes for it to go from maxed out to...
sounds like check valve is stuck, could have some trash in your lines, check manuel and remove check valve and flush hydraulic lines. also accuator cylinder may be out, that would be at the lever, may not be letting the oil return
Sep 25, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Cant send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 27, 2009 | Lexmark X6170 All-In-One InkJet Printer
Cannot send a fax
Apr 29, 2009 | Lexmark X4270 All-In-One InkJet Printer
Temp guage goes to max (right) when engine is cold.
change the themostat when you remove the old themostat you should see it stuck in the open postion . before i install the new one i fill the the block with coolant install the new stat run the mtr and heater core until hot iwould also replace the cap
Jan 01, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Hardware & Accessories Logo
78 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
