Question about Xantrex Technology Xantrex Xpower PowerPack 300 EP (XPOWERPK300EP) 300-Watt Power Supply
Don't know voltage setting for charging this unit.
I just received a powerpack 300 but without a proper charger. will a universal charger work and what setting should i use?
  • 1,056 Answers
You can use any adaptor that supply 12V or more. If you have at least 800ma of current, and 12V or higher it will do the job. Higher voltage rating will charged it much quicker but you have to watch it.
Posted on Jun 28, 2009
Xantrex XPower PowerPack 300 will not charge even after replacing both battery and adapter. What else can I try?
Either charger has an issue or new battery is boogus. Check charger output for specs. Subject battery to a few discharge/charge cycles. If charger is definitely good and battery will not charge fully after a few cycles then you have confirmed that new battery is bogus.
Sep 06, 2017 | AMP Computers & Internet
Hello. I do not use my rx330 frecuently,to keep my battery charged may l use a battery maintainer conected directly to the battery car or l have to keep conected to the battery without the car. How can l...
if your battery maintainer(charger)has the capability to charge from a higher charge to lower charge as the battery gets charged up and shut off when proper voltage is attained then you can leave the battery in the car as every time you disconnect it you have to reset everything in the car.some now can detect when to turn off and turn on as the car sits and voltage drops to low.don`t know which ones do and don`t someone may be able to answer that if they know about them.
Jun 13, 2011 | 2004 Lexus RX 330
Trying to charge but all I get is a clicking sound and flashing light while charging
had the same problem, was going nuts. Then I pushed the button for the flash light charger and it stopped clicking. Here's hoping it works
Aug 28, 2010 | Xantrex Technology Xantrex Xpower...
I bought a new Powerpack 300 and never had a use for it. It was plugged in for a year and when I decided to test it everything worked until I plugged in any AC appliance.. It just doesn't seem to have the...
Your battery is likely damaged from being plugged in for a year. The battery is a sealed lead acid battery inside, probably a 12 or 17AH job. Proper way to store a lead acid battery is to keep in cool dry location, and top off charge each month or two by charging according to manufacturer guidelines.
If you can figure out how to get into the case, you can replace the battery.
Aug 05, 2009 | Xantrex Technology Xantrex Xpower...
Xantrex PowerPack 300 will not hold a charge
Machine no longer takes a charge. Light remains yellow, if you plug anything in there's not enough power. Any suggestions? Purchased XPower Powerpack 300 Plus from QVC appx. 6 - 8 years ago.
Mar 28, 2009 | Xantrex Technology Xantrex Xpower...
CANT LOCATE CORRECT CHARGER
Howdy,
Most office supply stores and home supply stores, Office Max, Office Depot, Staples, Home Depot, Lowes, carry a Universal AC Adaptor that has multiple voltage settings with multiple plugs that fit a variety of low voltage charger connections.
Dec 11, 2008 | Peg Perego 12 Volt Rechargeable Battery
I have a CMZ984 coleman portable rechargeable bug zapper.I have lost the manuel and charger for it.It is 4 watts.The company that made it for Coleman has gone out of business.It is about 2 years old.What...
The CMZ984 takes 6 volts DC at about 850 ma or 0.85 Amp. The problem is finding a plug that will attach to the Coleman charging port. Use the Radio Shack universal DC power supply. This is a little unit that comes with an assortment of plugs and has a number of switches on the Radio Shack DC power supply. (1)-Find a plug inside of the Universal DC power supply that fits without forcing, (2)-set the voltage to 6 volts and (3)-the polarity to "+". When the universal power supply is plugged into the bug zapper and the universal DC power supply set at 6 volts, turn on the BUG ZAPPER. If the lights inside turns on when the battery is dead then you probably have all switches set correctly. At yard sales, this UNIVERSAL power supply sells for about $1. It comes with a number of different plugs. Don't forget to write the voltage and polarity on the bottom of the bug zapper for the next time.
Jul 29, 2008 | Kitchen Ranges
Battery don´t work
try to replace new battery charger.
Feb 22, 2008 | Astar Trent PD-3070
Xantrex Technology Xantrex Xpower PowerPack 300 EP (XPOWERPK300EP) 300-Watt Power Supply Logo
910 people viewed this question
Top Xantrex Technology Computers & Internet Experts
Marvin
Marvin
Steve
Are you a Xantrex Technology Computer and Internet Expert? Answer questions, earn points and help others
