Question about Samsung SyncMaster 203B LCD Monitor
Sumsung 203B turns off
The monitor turns on for one second and then turns off. I have to push on the power button twice to bring it back on.
5 Suggested Answers
tantong
  • 138 Answers
SOURCE: Samsung LCD Monitor SyncMaster 203B
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen blacked out or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
  • 541 Answers
SOURCE: my monitor started to give me problems when I
you need your power supply reaired. the capacitors go bad. remove the covers and look at the power supply reeplace any leaking and or crowned capacitors
Posted on Jan 01, 2010
budmrtn
  • 11361 Answers
SOURCE: SyncMaster 203B (Black) LCD Monitor: Monitor will not stay on (Samsung Syncmaster 203B)...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 18, 2010
  • 732 Answers
SOURCE: I have a Samsung SyncMaster
If not into lcd monitor "tear-down" and repair, just trade in for new. May only be 1 poorly soldered lead of some component on switch-mode supply board/ inverter board. Check for swollen electrolytic filter capacitors on same board. 12fixlouie
Posted on Sep 23, 2010
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
How to repaire canon MP 510 error, wen turn printer on in the lcd diplay get message : error service required 5800
Welcome to Fixya.
Please try the following steps to resolve this problem - this same procedure worked for my colleague :
  • Power off printer
  • Hold down STOP/RESET button then Press and Hold down Power button
  • Keep Power button down and Release STOP/RESET button
  • Push STOP/RESET button twice
  • let go of power button
  • Wait 20-30 seconds - my display shows "canon Idle"
  • Then Push STOP/RESET button four times
  • Push Power button twice
  • Power off (shut printer down)
  • Wait for at least 5 seconds and power it back on
This should do the trick and will get you printing again in no time.
Thanks for using Fixya.
May 25, 2011 | Canon PIXMA MP510 All-In-One InkJet...
Monitor won't stay turned on. You push the on button and it flicks on and then immediately off. Help!
The possible problem of your monitor is may be cold solder, bloated elec. capacitor or defective lcd panel. If you found that bloated capacitor replace it and resolder all pins of inverter area. Defective lcd panel could cause of display flicks then immediately off.
Sep 30, 2010 | Samsung SyncMaster 203B LCD Monitor
I have a Samsung SyncMaster 203B flatscreen monitor that I have to keep clicking the power button on and off to get it to finally power up without quitting again. Is there a capacitor or something I can...
Sep 23, 2010 | Samsung Computers & Internet
Monitor goes off
mcdevito75 here, You can try to hold the button in for 3--5 seconds see if that helps. Switch could be bad, bring the monitor to Staples or computer repair for test.
Jun 26, 2010 | Hannstar AG-191DPB Monitor
Syncmaster 203b power light comes on, but no image...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 20, 2010 | Samsung SyncMaster 203B LCD Monitor
May 16, 2010 | Samsung SyncMaster 203B LCD Monitor
My monitor started to give me problems when I first turn it on I have to push the power button several times before it will stay on it's the samsung syncmaster 203b
Jan 01, 2010 | Samsung SyncMaster 203B LCD Monitor
Monitor is flickering and go black severel times before coming.
i feel, you try go to control panel,, and display settings,, from there.. click on screen saver tab, there you can find power button,, click it and change all to never ,, and also dont forget to make screen saver to none.. and see..
Sep 27, 2009 | Samsung SyncMaster 203B LCD Monitor
How to rotate display when I rotate screen - SyncMaster 203B
You ought to be able to bring up the video card settings from your control panel and change it there. For instance I have a nVidia graphics card. When I bring up the settings panel it offers me the opportunity to change the rotation there.
Dec 28, 2008 | Samsung SyncMaster 203B LCD Monitor
Samsung SyncMaster 203B LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
