Question about Jack Lalanne Power Juicer (Stainless Steel)
My juicer's motor and blade has stopped working
3 Suggested Answers
oldnovii
  • 667 Answers
SOURCE: Jack LaLanne Power Juicer
Hi smer67 - This is what it says on the official site about spare parts: See the back inside cover of the instruction manual for the spare parts order form or call: 1-973-287-5150
(MON-FRI 9AM to 7PM EST & SAT 9AM - 5PM EST). If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Posted on Aug 17, 2008
  • 496 Answers
SOURCE: My jack lalanne power juicer's blade and its
Here is a number you can call for a parts inquiry:
1-800-526-2518
Hope this helps you... Good luck!
Posted on Sep 23, 2009
I bought a Jack Lalanne's Power Juicer (I guess it's the original) at a yard sale. It worked fine at first, but now whenevr I put a carrot or apple the motor stops. I have to disassemble and clean the...
motor has burned out field winding s and is not capable of running under load
the seller knew that and you bought it
hope you didn't pay more than a few dollars for it
Nov 16, 2017 | Jack Lalanne KN2047 Juicer
Jack Lalanne Power Juicer250
the power is not properly supplied to blade .....just check whether the connections are proper ....
Aug 09, 2008 | Jack Lalanne Power Juicer 250 Watts
The blade wont spin even though the mothor is on. I can hear the motor engage but the blade will not move...it has not been used in awhile.
Have you ensured that the blade is securely screwed into the drive motor? Using the two-pronged tool that came with the juicer (or, if you've misplaced it, a DIY solution like two small screwdrivers), make sure that the blade unit is screwed clockwise onto the drive motor. There should be two holes on the inside of the blade unit, at the bottom of the "bowl." That's where you remove the blade unit for cleaning and reattach and tighten it.
Mar 01, 2011 | Jack Lalanne Power Juicer 250 Watts
I haven't used my Acme Supreme Juicerator in years. How do you assemble the juicer? The flat blade sits on the aluminum filter? How does it attach to the motor? Am I missing a part
Juice bowl first, then the basket followed by the
shredder blade which is all held down by the
white clutch nut. If you're missing the nut ctc.
Waring at 1 800 492 7464 for a new one.
Nov 04, 2010 | Acme 5001 Supreme Juicerator Juice...
It won't "go" It seems to be assembled the same as always and I have oranges in the tube and the motor goes on and hums but the blade and sieve don't spin
mcdevito75 here, The Oranges must be in the tube so tight it"s keeping the blades from spinning, turn juicer off nplug from wall, remove cover and unclog the oranges. Reassemble and feed oranges slowy into the juicer.
Jun 15, 2010 | Jack Lalanne Power Juicer 250 Watts
Jak lalanne not working
Regarding Jack Lalanne juicer. After making sure nothing clogs the blades., make sure the stainless bar is on the correct slots on top of the juicer, left and right. It has a safety switch that when its not closed properly, it won't run.
Jan 31, 2009 | Jack Lalanne Power Juicer 250 Watts
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
Pusher won't come out
Hi,my name is patricia ,and i found a solution,first the black button .the black vise grip put it in the blade while the blade is still in turn the black vise grip to the left while still in the blade keep turning to the left and the blade will come off of the black button.the black button do not come off or up.When you put food in but smaller pieces in and have all your pieces near you so you can continue to drop in in the processer while running it and can slowly put the long tube in to keep food from splashing do it slowly .hope that help
Aug 27, 2008 | Jack Lalanne Power Juicer (Stainless...
Using the Citrus Attachment
CALL WARING AT 800 492 7464. MAY BE
SOME TYPE OF SAFETY CUT OFF. YOU
MIGHT ACTUALLY HAVE TO ATTEMPT
JUICING AN ORANGE OR SO WITH THE
NEWER MACHINES.
Jun 25, 2008 | Acme 5001 Supreme Juicerator Juice...
Jack Lalanne Power Juicer (Stainless Steel) Logo
54 people viewed this question
Top Jack Lalanne Juicers Experts
Starnley Johnwells
Starnley Johnwells
Cory Koby
Cory Koby
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
