Need Manual for Seiko SII LD 5420 - Office Equipment & Supplies
I need drivers for smart label printer pro
It would help if you had mentioned the Operating system and model number
The official Seiko site is:
Software Driver Downloads
However, Seiko has deleted its legacy printer support so you may have to find your drivers on a third party site
SLP Related Drivers
SII Printers Drivers Download for Windows 7 8 XP Vista
Note: With Seiko Smart Label printers make sure your printer is not connected to your computer until the Seiko software tells you to.
Important tips when finding and downloading application/ driver software from non-OEM sites
1. Never install any application from a non-OEM site that says it will scan your computer to determine what files you need. - search using the manufacturer name, model number, and current operating system on the computer you want to install the device on.
2. Only install the files you found. Never download any software suggested.
3. When installing the downloaded files, always select Custom Installation to make sure you only install the software you need. In this case only the application and driver files, nothing else ( no driver updating, security scanning, toolbar, etc. programs).
May 13, 2014 | Seiko Smart Label Printer Pro Thermal
Smart label printer 200 turns itself off while printing
I was able to fix the issue: I had an aftermarket power supply which I bought online. It was way cheaper, but was wasting my labels. Printer would shut off. Just go to Seiko USA website and buy the specific power supply from the manufacturer. I spent $22.50 plus shipping and total came to $30.00, but it was well worth it! Also, the letters are way darker and better than what I had coming out with the afermarket Power Supply. The link is below:
https://labelprinters.sii-thermalprinters.com/seiko-400-series-printer-accessories
Apr 20, 2012 | Office Equipment & Supplies
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
Calibrate a DPU3445
go to this website:
http://sii-thermalprinters.com/thermal-printers/mobile-printers-DPU-3445.aspx
it is seiko's official website, but you will need to register to be able to download the manuals.
good luck.
Dec 02, 2009 | Seiko DPU 3445 Thermal Printer
Need to find a df4033 user manual.
I just got a copy from Seiko in Japan
"nozomu sasaki" nozomu.sasaki@sii.co.jp from this gentelman. upon request, they will send you.
If there is a way for me to attach it, i would be glad to. It is 2.39 Mb. in pdf. i e-mailed my request to them from the Seiko website.
Dr. Ben
Jun 01, 2007 | Seiko DF4033 Translator
81 people viewed this question
k24674
