Question about EnGenius Computers & Internet
Ssid not broadcasting ens500ext - EnGenius Computers & Internet
What is the ssid #
How to Locate a Router's SSID and SSID Broadcast Setting
Applies to: Wii U Deluxe, Wii U Basic, Wii, New Nintendo 3DS, New Nintendo 3DS XL, Nintendo 3DS, Nintendo 3DS XL, Nintendo 2DS, Nintendo DSi, Nintendo DSi XL, Nintendo DS, Nintendo DS Lite
Published ' Updated --> Step by step instructions on how to locate your router's SSID and broadcast settings.
Note:
Was your router provided by your Internet service provider? If so, before continuing check for a sticker on the bottom or side of the router that has the default SSID printed out. This is usually labeled as the SSID or "Network Name" and may be located next to a barcode.
What to Do:
  1. Log in to your router's settings. How to
  2. Search through your router for phrases such as SSID or Wireless Network Name. The terms and locations can change from router to router. Below are examples for common router brands:
    • D-Link:
      You can typically find the SSID by selecting the "Setup" option, and then "Wireless Settings."
      Enable SSID broadcast by selecting "Visible" for the "Visibility Status."
    • Netgear:
      You can typically find the SSID by selecting the "Basic" settings option, and then selecting "Wireless Settings." The SSID may be labeled as "Wireless Network Name."
      The option to enable SSID Broadcast is often located by selecting "Wireless Settings" under the "Advanced" settings.
    • Belkin:
      You can typically find SSID by selecting the "Wireless" tab and then selecting the "Channel and SSID" option.
      The option to enable SSID broadcast is located here as well.
    • Linksys:
      You can typically find the Network Name (SSID) by choosing the "Wireless" tab, and then "Basic Wireless Settings."
      The option to enable SSID broadcast here as well
If you require additional assistance locating your router's SSID settings, please refer to your router manual
Oct 07, 2015 | Nintendo Wii Console
Ssid code
SSID is a wireless network to connect your game console, (and other devices) to the internet. They are case sensitive and can be up to 32 characters long. SSIDs are usually broadcasted so your device can display available networks. Not all SSID are broadcasted, in that case you have to know the exact name to find it. Commonly it will be password protected using a form of WPA (WiFi protected access).
Apr 24, 2013 | Nintendo DS Video Game Consoles & Games
Wireless ssid not showing in some laptops and mobiles -dlink router
The D-Link wireless router may have the SSID broadcast turned off.
In this case only computers that have wireless connection to the D-Link will show the SSID.
If you know the SSID you can enter the SSID manually in the wireless card settings in the laptop/computer.
OR
Turn on SSID broadcast in the D-Link wireless settings.
Aug 08, 2012 | D-Link Computers & Internet
Whats ssid mean.
Hi
SSID- Service Set Identifier
An SSID is the name of a wireless local area network (WLAN). All wireless devices on a WLAN must employ the same SSID in order to communicate with each other. The SSID on wireless clients can be set either manually, by entering the SSID into the client network settings, or automatically, by leaving the SSID unspecified or blank. A network administrator often uses a public SSID, that is set on the access point and broadcast to all wireless devices in range. Some newer wireless access points disable the automatic SSID broadcast feature in an attempt to improve network security.
SSIDs are case sensitive text strings. The SSID is a sequence of alphanumeric characters (letters or numbers). SSIDs have a maximum length of 32 characters.
Dec 11, 2011 | Nintendo Wii Console
Find ssid number for linksys model wrt54g
SID broadcast allows computers to quickly locate a new network and connect to it. In wireless home networks computers often use only the home network, which makes SSID broadcast unnecessary. Disabling SSID broadcast adds a bit of security to your wireless network, because computers won't be able to see your network's SSID.
Log into the router.
  1. Open your webbrowser and type http://192.168.1.1 in the address bar. This is the default IP address of the browser.
  2. Type your login info in the login screen. Default: 'admin' (without quotes) in both fields.
  3. Go to Wireless > Basic Wireless Settings 'wireless
  4. Set SSID broadcast to 'disable'.
  5. Click Save Settings.
On the next page you will set a router password to prevent unwanted visitors from accessing your router setup.
Sep 23, 2011 | Linksys Wireless-G WRT54G Router
I do not know what ssid is
An SSID is the name of a wireless local area network (WLAN). Your Wireless Network.
Hope this helps!
Don't forget to rate:)
Dec 22, 2010 | Nintendo DS Lite
I have the WRT54G router. I got an adapter for my USB Printer cable to Ethernet to connect it to the router. I have a wireless laptop that I would like to use to send the print jobs to the printer (a...
Connecting to a Wireless Network with SSID Broadcast Disabled when using Windows Vista & Windows 7 Article ID: 5451
Disabling SSID broadcast is another way to secure your wireless network. This will ensure that your SSID will not be detected whenever someone does a scan. When connecting to a wireless network with SSID broadcast disabled, you will have to create a profile.
Creating a Profile
NOTE: Disabling SSID broadcast is another way to secure your wireless network. This will ensure that your SSID will not be detected whenever someone does a scan. When connecting to a wireless network with SSID broadcast disabled you have to create a profile.
Step 1:
Right-click this icon kb_5451-001_en.png at the bottom right-hand corner of the screen, then select Network and Sharing Center.
NOTE: If you are using Windows 7, just click once on this icon kb_5451-003_en.png at the bottom-right of the screen then select Open Network and Sharing Center.
On the Network and Sharing Center window, click Manage wireless networks.
Step 3:
Click Add. NOTE: You have to remove your preferred network before before you proceed to click Add a new connection. If you see your network has changed from Automatic to Manual, you will face difficulties to connect your computer on the network because the SSID is not broadcasting into the available network connection. After removing your preferred network and adding it back, the network will turn to Automatic and you will be able to connect automatically into your network. Make sure to look at network properties/Connection and check "Connect when this network is in range".
Keep reading here
Jul 10, 2010 | Linksys Wireless-G WRT54G Router
Wireless not detected
Are you broadcasting your SSID 'Network ID" If not you won't see a wireless network if "SSID Broadcast" is turned off in the router.
Login to your router config page and enable 'Broadcast SSID"
Nov 22, 2009 | Acer Aspire 3000 Notebook
Windows Vista won't connect to my actiontec
If you have disabled broadcasting of the SSID you will havw to tell Vista to connect even if the SSID is not being broadcast.
There is a checkbox on the wireless connection pannel for doing that and there is also that option when you setup the connection. If the SSID is not broadcasting Vista will not connect until you tell it to. You can check if that's the problem by enabling the SSID broadcast and seeing if it connects. If yes, then find that checkbox (sorry, I'm not on my Vista system and don't know all the steps to get there offhand) and mark it; then disable the router from broadcasting again. It should connect every time after that.
Apr 13, 2009 | Actiontec GT704WG Wireless Router...
Cisco 1242ag broadcast multi SSID issue
It stops broadcasting the SSID? Make sure it's configured to broadcast the SSID firstly... secondly, test whether it is actually working but just not broadcasting the SSID.
Set a client PC to the same SSID and get all the parameters identical (encryption, user/pass etc). Try connecting again. If it connects then it's just the SSID that isn't working... if there is no joy, then it is just the SSID that isn't broadcasting, not the whole AP.
Also, enable some debugging for the radio0 while it is not working. It might shed some light.
Feb 05, 2008 | Cisco Aironet 1242ag 802.11a/b/g Wireless...
Computers & Internet Logo
55 people viewed this question
Top EnGenius Computers & Internet Experts
Michael Vincent Cruz
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
