Question about Home
Aquariss showers how to remove the disc and replace the control handle
  • 148 Answers
SOURCE: I have a Moen Shower
Take a picture of the fixture and then take the plastic handle to Ace orI HD or Lowes and see if they have a match
If they do not have it ask clerck at ace if there is a plumbing specialty store and see f they have it
if not contact Trayco company Florence Sc
they have the largest supply of spare parts in the country
good luck
Posted on Jan 04, 2009
  • 659 Answers
SOURCE: replace delta single handle shower cylinder
Yes, I believe this unit uses a cartridge right? They do fit a little tight due to the small washers on the back side of the cartridge. If this is the one I'm thinking of, there are two leg like appendenges that come off the back and fit into small holes at the back of the manifold or what some call mixing valve housing.
Posted on Apr 10, 2009
  • 20 Answers
SOURCE: I have an Aquariss shower mixer that runs cold when fully on
a washer or o-ring inside the cartridge may have dislodged and caused this ---turn off water to valve or whole house if necessary, and remove shower valve cartridge and inspect---all o-rings/washers should be in place and somewhat greasy(lubricated)....note which way it was when you removed it, as its replacing must be done the same way
Posted on Mar 14, 2010
  • 81 Answers
SOURCE: moen monticello shower control, remove handle
If your Posi-Temp has no water coming through the valve my first step would to replace the cartridge (Moen pn 1222). The valve as a simple one. Get the part first so you can ues the plastic tool that comes with it if you need to. Beneath the actual lever insert on the handle hub you will notice a small hole. this is to gain access to the allen head screw which holds the handle in place
Posted on May 29, 2010
packrat1948
  • 528 Answers
SOURCE: My volume control handle takes several rotations
The splines are probably striped and the handle will need replacing. but it may be as simple as the handle set screw is lose.
http://www.aquabrass.com/sections/shower
Nine out of ten times these handles go bad when they get lose so if you buy a new one it will come with instillation instructions.
Posted on Jan 30, 2011
Can't remove shower faucet handle
The plastic handle can be removed as follows:
1) pry off the lastic cover in the handle with a rounded knife or flat screwdriver (the cover is a disc, just above the "MOEN" and blow the H/C marks
2) use a Phillips screwdriver to take out the screw
3) pull off the handle, if it resists try gently prying it off with a falt bar or big screwdriver, working on different sides (putting pressure on teh back). There are special tools for this also, most hardware stores carry them, usually about $10
Hope that helps
Jul 19, 2011 | Moen 3175 Legend One Handle Shower Faucet...
How to adjust the hot water on a moen one handle shower 82496 srn
remove the handle and adjust the disc in the direction the arrows indicate to make it hotter. all that you are doing is moving the stop farther so that the handle will go farther to the hot.
Feb 15, 2011 | Moen Home
My volume control handle takes several rotations before shower finally stops dripping. Do I need a new handle and how would I replace it?
Jan 30, 2011 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
We installed a new singel handled faucte in our shower and now we are running out of hot water. this never happened in this house before. we always have plenty of hot water, i called delta and they said...
The way the faucet cartridge is designed it will protect you from large changes in water pressure. This can happen if someone is useing the shower and someone else flushes a tolet there is a sliding valve in the cartridge that will close off hot water supply to protect you from getting scalded.If you are not getting hot enough water there are adjustment you can make to increase the maximum setting.
As long as you are getting good hot water supply in other fixtures in your house I doubt that changeing the water heater is going to help.
I think that you may have a defective cartridge and I would call delta again and give them another chance. They generally have very good customer service, and perhaps the one you talked do did not understand that you have good hot water supply elsewhere.
If you do not have hot enough water to shower valve that can eaisily adjusted by removing set screw that holds the handle on and remove the handle.If there is a white temp. limit disc on the stem then remove it. Slid the chrome sleeve from around the valve body off. You should see a disc that you can slid out a little and rotate to the left a small amount. This adjusting disc and its mating surface have teeth on them that mate. There should be marks on the valve and disc with a arrow on them to show which way to turn for hotter water.Reassemble and check.
If your water starts out hot and then gets cooler while being used and you still have hot water in other places then I think you have a defective cartridge. It should be under warranty. Hope this helps you some. Good luck and thank you.
Jan 26, 2011 | Delta & Single Handle Shower Faucet
I have a one handle Delta shower knob. I have turned up the hot water heater. All the other sinks within a few feet of the shower run very very hot but my shower stays a mild luke no matter what. The knob...
On your single handle the first thing you do is remove the handle. To do this locate allen set screw on handle and select the right size allen wrench to fit it. Loosen set screw and pull handle out away from wall to remove it. There should be a plastic disc on the handle stem, slid it out to remove it.Remove chrome sleeve..On valve body there are marking that show hot or cold settings. Seperate teeth on geared flanges and rotate set stop toward h mark on valve body. Each tooth will change temperature about three degrees. Make trial setting and reassemble and try it out. If you want it hotter just repeat adjustments. If you try to go to far you will not be able to mesh gears,simply back off alittle bit and try again.Hope this helps you. Thanks
Nov 22, 2010 | Delta & Single Handle Shower Faucet
How do i install a new cartdridge for a delta single handle faucet in my tub
Remove the shower control handle. If the cartridge is threaded there will be a nut on the top. Remove with a crescent wrench. If there is no nut then there will be a retaining clip and the cartridge will then pull straight out. Installation is the reverse procedure.
May 31, 2010 | Delta & Single Handle Shower Faucet
Mar 11, 2010 | Home
Moen monticello shower control, remove handle
Feb 07, 2010 | Moen & Posi-Temp Single Handle Shower Or...
A handle in my shower will not rotate and therefore I can not turn on any cold water. The shower faucet and handles are at least 30 years old. How can I get the handle to rotate?
you will need to dissasemble the faucet control and remove and replace the stem and seat in the unit its just froze and if you try to keep turning it the stem will eventually break
Jan 20, 2010 | Home
The shower control valve for my moen 2995 faucet is stuck in the shower position. how do i remove it?
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Sep 27, 2009 | Moen 2995 Chateau Three Handle Tub and...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
