Question about Bose Audio Players & Recorders
Pod on my Bose Companion 3 Series 2 Speakers won't mute
Had to do a factory restore; now my pod for muting won't work on my Bose Companion 3 Series 2 Speakers.I've unplugged everything pertaining to them and it still doesn't work. My speaker system is just a little over 2 years old, and I'm using Windows 7 64-bit. Also, the speakers take turns working.. First it's the left and then the right and then they work together. I've jiggled the cords and it seems to make them work after... Not really sure how to fix this... Please help?
  • 749 Answers
SOURCE: bose acoustimas speaker output jacks not working
try to trace your problem inside the main circuitry of the jacks ( open it and see on the solder side of the Printed circuit board(where all the electronic components and soldered/welded if there are loose connections (small cracks... use magnifying glass if you have one) then solder them.
also check for the transistor amplifiers and output capacitors....
check also for the connectivity of all wirings!
Posted on Nov 17, 2007
SOURCE: Durabrand home theater speaker help
Your problem is simple; if you are using a player that does not have the 'center, rear right and rear left' functions, then those select speakers won't play anything. This happens to me a lot when I plug in my CD player to listen to my music because the CD player does not support those individual speakers; I can only hear the right and left, the speakers that it DOES support. If you are using a system that does have these functions, then I can't really help you there....
Posted on Nov 19, 2007
SOURCE: Looking for a control pod.
I recently had a similar problem. In my case the left speaker had no sound. Finally traced the problem to a broken wire inside the control pod plug, which I destroyed by dissecting it. For those who have the experience, or know someone who does, purchase a new plug, which a Mini DIN 8 pin (RS-422 standard). It should be available at any good electronic parts store. Solder new plug on to cable, which requires a fine electronic soldering iron and a fair bit of skill (the wires are very fine).
Look at the plug (from the rear); you will see it comprises a top row of 3 pins equaly spaced; a middle row of 3 pins (there is room for 4 pins but one pin is missing just left of centre); a bottom row of 2 pins. I numbered these as follows:
8 o 7 o 6 o
5 o 4 o 3 o
2 o 1 o
The wire from the controller comprises 8 coloured cores and a bare core. The wiring of the eight cores are as follows:
DIN CORE PCB
pin 8 - brown 8
pin 7 - red 7
pin 6 - orange 6
pin 5 - yellow 5
pin 4 - green 4
pin 3 - blue 3
pin 2 - white 2
pin 1 - black 9
body clamp - bare wire - G
In case your coloured cores vary from mine I have also listed the pin each one goes to on the printed circuit board plug, which will let you identify the colours.
Posted on Feb 04, 2008
  • 51 Answers
SOURCE: Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Posted on Dec 27, 2008
  • 51 Answers
SOURCE: Bose Cinemate speakers stopped working
Sounds like you need to take them back for exchange. A new electronic product is most likely to fail in the first few months, when any weak or defective parts that made it through final test at the factory decide to **** out after a few hours of use. This is a very common situation, especially nowadays with manufacturers buying the cheapest parts they can find, and the general public crying out for lower prices instead of paying more money for better quality. Bose has traditionally been "top of the line" stuff, but even they have to cut corners to keep prices low and sell stuff in this economy.
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
My speakers keep muting themselves at random
I am having the exact same problem. Has this been resolved yet?
Feb 12, 2010 | Bose Companion 3 Computer Speakers
Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Aug 12, 2009 | Bose Companion 3 Computer Speakers
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Jan 29, 2009 | Bose Companion 3 Computer Speakers
Bose Companion 3 Series II not working (Mac)
The speakers seem to be muted by default - you'll see that the LED is yellow/amber. Tap the control pod - the LED will turn green and speakers will work. I felt like such an idiot after I spent almost an hour trying to figure this out. (This feature should be more prominent in the manual.)
Dec 20, 2008 | Bose Companion III Computer Speakers
Where Can I purchase a bose companion 5 control pod?
You can purchase it from amazon, click here Amazon com bose control pod and choose, which one fits to you.
I hope I was helpful
enjoy
Nov 25, 2008 | Bose Companion 3 Computer Speakers
Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Oct 03, 2008 | Bose Companion 3 Computer Speakers
124 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
