Question about Jacuzzi 230v E10 Circulation Pump
Spa circulating pump
Intermited
I have a Canadian spa swift and the pump is beeping with error code E7 can anyone help
E7 is a DRY heater fault.
Check the following first:
1) Water level - Have you filled the spa with enough water?
2) Filters - Are the filters blocked, when did you last clean/replace the filter?
3) Is the circulation pump running? If you can hear the pump, can you see/feel the water circulating? If you can't feel the water circulating but you can hear the pump, then you may have an air lock within the pump/heater.
Canadian Spa Co. do offer their own repair service for these spas. Basically they collect the faulty pump unit, repair it and then send it back. Although it isn't cheap and you should check the basics first.
Good luck,
Ian Kime.
Apr 23, 2017 | Pool & Spa
Water not pumping
Is the pump running? If so I would say you lost your impeller. If not running I would check for a circuit breaker for the motor.
Apr 10, 2013 | Intex Automatic Salt Water System for ...
How do i test a e10-nshn2w20 to see if it works
We are play with 230V here Two hot wires and a ground center off pump to water top off pump to lawn
Feb 27, 2011 | Laing Thermotech Laing Circulation Spa...
Spa n a box 6 person portable hot tub pump cl250-c pump stops working error message OH on display
If the water pump is not circulating water you will want to do a simple procedure called "turning the impeller" You can call 888-997-6366 to be walked through this procedure over the phone.
Feb 26, 2011 | Comfort Line Spa 2 Go Portable Spa with...
I have a Heritage spa that has a fault code of FLO on the pad and also it is not heating up.. Are these related and what is the fix... Cheers Steve
All spa's have a circulator pump. This pump works in conjunction with your heating element. The pump automatically turns on when the heater does to circulate the newly heated water. If the pump fails, the heater will not kick on as a safety measure so you don't burn out the heating element. It sounds like your circulator pump has failed. On many spas, this may also be related to a pressure switch failure. I hope this helps. It should at least give you a place to start.
Jan 03, 2011 | Heritage Pool & Spa
Motor is wire to be on full cylce rather than circulate.
The wiring is not what makes a pump full cycle or circulate. If the spa motor is always on it is either because the pump relay is stuck closed, or the heater isnt keeping temerature therefor requiring the pump to be constantly running. There are also setting on newer style computer boards which determine a pump to be either "jet" or "circulation" pumps.
Also, a spa pump will run fulltime if the water is below 50 degrees F.
If you need further help, contact me @ adamh@newconceptchem.com
Nov 22, 2010 | Century New Magnetek Pool Spa Pump Motor...
Hot tub heating is working but pump has stopped
you may have a system that uses a small circulating pump that circulates the water thru the heater to keep water temp at proper level (this is usually the case with hot springs spas and is because it is the most cost effective way to maintain constant water heat without using a full size pump or two speed pump just to push water past the heater core. therefore the issue is you have a problem with your jet pump and it has nothing to do with the circulating and heating portion of the spa. you can check to see if there are any reset buttons in or near the equipment as well as open enclosures to make sure everything is clean and dry also make use any contacts on spa skirting are secured propertly
Apr 24, 2010 | Pool & Spa
Replaced heater failed within 2 months
If your filter is plugged causes the heater to work harder(overheat). Rus
Mar 17, 2010 | Heating & Cooling
Jacuzzi 230v E10 Circulation Pump Logo
52 people viewed this question
Top Jacuzzi Plumbing Experts
Donni Steen
Tom Chichester
Are you a Jacuzzi Plumbing Expert? Answer questions, earn points and help others
