Question about Baby Care
Medela Circuit blown out when plugged into int'l socket - haven't yet opened to see if it is motherboard or just wires, but is there a fix if it is the motherboard?
After electric outage, makes loud hum
see this steps and fix it, use the VOM. God bless you
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
Jul 13, 2013 | Dryers
Lighter socket wont work
Most likely a blown 15-amp (blue) fuse, in the fuse box near the driver's feet.
Jan 25, 2013 | 1990 Toyota Corolla
I triger power switch but dose not work mother board
Check to see if the problem is the Power On switch, or the Power Supply.
Bypass the Power On switch.
http://www.supermicro.com/products/motherboard/Xeon/GC-LE/P4DL6.cfm
[For the motherboard user manual;
Go to the heading, to the upper right in blue - Links and Resources.
{Don't believe we can use the Ampersand on here. Let's try & }
In the list below it click on - Motherboard Manual
Click on the blue - [ Download ] for the second file listed.
MNL - 0660 (English)
P4DL6 / P4DLR / P4DLR+ ]
The SuperMicro P4DL6 motherboard can use a 20-pin ATX main power cable, OR a 24-pin ATX main power cable.
Suggest you use a Power Supply, that has a 24-pin ATX main power cable.
Why?
A 20-pin ATX main power cable, does NOT provide enough power to the motherboard.
General example of a 20-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
[NOTE*
Color of the connectors does NOT matter ]
General example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note the additional power wires.
3.3 Volts (Orange), 5 Volts (Red) { 2 of them }, and a Ground wire. (Black)
Which type of ATX main power cable are you using? Don't know. You haven't stated it.
For both,....look at the Green wire. This is the Soft Power On wire.
(Abbreviated as PS_ON)
A jumper wire is used to jump from the Green wire, to ANY Black wire.
ALL Black wires are Ground wires.
Go to the link with the 24-pin ATX main power cable, in it.
Look at the photo to the far right. See the Green wire?
See all the Black wires?
The preferred jumper wire is a paper clip, straightened out, then bent into a U-shape. The middle of the U is wrapped a few times, with black plastic electrical tape. This taped area is for your fingers, and thumb to hold onto.
Turn the U over. Taped middle is up. There are now two 'legs'.
These legs go down into the socket holes, of the Green wire, and ANY Black wire.
One 'leg' down into the socket hole of the Green wire, the other 'leg' down into a socket hole with ANY Black wire.
The 'leg' of the jumper wire, goes down RIGHT NEXT TO the wire already in the socket hole.
The 'leg' has to go down into the socket hole, (Next to the wire already in the socket hole), pretty far.
It has to go past the insulation of the wire, and touch a metal terminal, that is on the end of the wire.
Look at the middle photo. Here you can see the metal terminals, in the socket holes.
Again, Power Supply plugged into power. ATX main power cable plugged into the motherboard, just like the photo to the far right.
The jumper wire makes a contact of no more than 2 seconds.
(Stick the jumper wire down in the socket holes, no more than 2 seconds, then pull it out.
The ATX power on switch is a Momentary Contact Switch )
Power supply comes on? You have a bad Power On switch,
http://www.directron.com/atxswitch.html
Power supply does NOT come on? You have a bad Power Supply.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 01, 2012 | SuperMicro SUPER DL6 (P4DL6) Motherboard
Int sw
Green and white is normally the power LED connection, as I recall. I may be wrong. Anyway, you need to trace the path of the wires back to the case and see what it's attached to. You normally will have a power switch connection, a hard drive LED connection, a power LED connection, a speaker connection, and possibly a reset switch.
Jun 05, 2012 | ASUS A8N32-SLI Deluxe Motherboard
My cooler just stop after spark on the socket it was working fine now i change the wire but it dont turn on
check the fuse in the plug. check your fuse board also. a circuit breaker may have tripped down, or you may have blown a circuit fuse if its the really old type. plug in another electrical device to check.
May 21, 2012 | Refrigerators
I bought a Made in US Medela Pump In Style Advanced. When I plugged it into power the power adapter blew a fuse. I am residing in Malaysia (our voltage is the same as the UK ie 240V). I have bought another...
Your pump has been recalled, perhaps that is the root of the problem.
Here is the link to the Medela recall site
Medela, Inc. is recalling a limited number of the Pump In Style Advanced breastpumps. The small percent of pumps affected by this recall were manufactured between February 10, 2010 and March 3, 2010 and shipped between February 10, 2010 and April 30, 2010. These pumps would have been purchased by mothers between approximately March 1 and June 30, 2010.
We have determined that on a very small number of pumps produced during this period, a component on the control board, after a period of usage, may cause the motor to slow down or stop. Please see below for the list of possible symptoms. We will replace recalled units free of charge. The unit being replaced must be shipped back to Medela at Medela's cost.
Jan 29, 2011 | Medela Power Adapter Transformer for Pump...
Power circuit got blown off
Are we talking the transformer (the pack you plug the laptop into and then plug into AC wall socket)? Or we talking smoke was coming from the laptop?
The transformer can be replaced. Use your favorite search engine to search for the part number for that power supply. You can find many OEM replacements including directly from Dell.
If the laptop was smoking, that could spell trouble. Once the capacitors burn out, many other components on the motherboard and expansion cards can be fried.
Unless you are a serious DIY type, I'd ask a professional technician to open it up and examine the parts.
Bret
1-2-1ComputerServices
Oct 07, 2009 | Dell Latitude D600 Notebook
1995 camry wagon cigarette lighter not working
start with a test light and check for power at the center of the cigarette lighter socket. If power is good, then check for ground at side of lighter socket.
If no power, run wire from power wire of lighter to power wire of stereo, thus tapping the power directly and bothering to trace out where the open int he circuit may be.
Jan 25, 2009 | 1995 Toyota Camry
The power supply burned out. replaced it. Still I get, no signal
there will be one INTEGRATED CIRCUIT (ic) near by the pci slot it is called as the video adapter ic ....
if this ic is dead then the the display will not come ...
so you need replace that ic ..
you can do that if you are experienced professional ...
if you have no idea then you need take it to motherboard technician ... ..
regards
-Dileep
Nov 23, 2008 | E-Machines (308714) Motherboard
Baby Care Logo
510 people viewed this question
Top Baby Care Experts
masud
masud
Tom Chichester
Are you a Baby Care Expert? Answer questions, earn points and help others
