Question about Garden
Pull cord won't retract on a poulan PPB200 - Garden
  • 376 Answers
SOURCE: Pull cord broke on my lawn boy mower,new cord won't retract??
I don't know exactly what you have there, but starters in general work pretty much the same. What you have to do with any starter when you replace the rope is to first wind up the spring with the pulley. Turn the pulley in the direction it would be turning if you were pulling the rope. When it's wound tight, back off to align the rope hole in the cover and the pulley. Stick the rope from the outside through the cover and pulley and tie a knot. Then let the spring tension pull the rope into the starter. Hope that helps. Dwain
Posted on Jul 16, 2009
  • 3600 Answers
SOURCE: Yard Man 21" Mower Pull Cord Won't Retract
You will find the retractable spring is broken you can go to any lawn mower shop and buy a replace me, also Wal mart and others you will have to wind it up till rope is tight then hook to the flywheel where the slot is. cost about $10.00 also lube the center hub bearing with wd 40
  • 3 Answers
SOURCE: pull cord will not retract
Have to take all 3 plastic covers (housings) off to get to the spring and tie the new pull rope or change the spring. Just did mine, spring just unlatched and string wouldn't retract. Did not have to by any new parts....works great! Took me 1 hour to get it done.
Posted on Sep 30, 2009
SOURCE: reattach pull cord for poulan pro bvm200vs
how to replace cord in apoulan pro gas blower
Posted on Mar 27, 2010
  • 8 Answers
SOURCE: the pull cord on my poulan pro weedeater will not
You have a broken recoil spring. Dis-assemble (pull-off) the recoil housing and check for proper dog alingnment, broken spring, or something jammed between recoil sprocket and engine block.
Posted on Apr 27, 2010
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Pull cord binding when mounted on engine but not when removed from engine
When you assemble the Recoil Starter, push it down onto the blower easily and then pull the cord slowly. It should drop into position as you slowly pull the cord.
May 07, 2015 | Poulan Garden
Hi Susan. It sounds like the spring has either snapped or become un attached. It's going to be a two person job to re do it. It may be worth while going to a scrap metal merchant and getting the recoil starter of an old mower.
Jul 26, 2013 | Poulan Garden
Starting cord won't retract
if its brand new take it back tell them the retraction spring is broken and fix it
Jul 25, 2013 | Garden
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Poulan Pro PP5020AV pull cord won't retract
You need to wind the spring back in a coil at a time, it is not easy if you have never done one, order a new spring, this will come pre wound in a cassette and is an easy fit.
Nov 22, 2012 | Poulan Pro Chain Saw 46cc 20"
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
The pull cord on my poulan pro weedeater will not
Apr 27, 2010 | Garden
Jammed pull cord on Poulan P4018 chainsaw!
There maybe a split pin holding the cover down over the spindle! Not too sure, but possible. Could be pushed down the centre, just a case of having a good look. Only really worked with Hurqvarna's and Makita's. Hope it helps. Good Luck
RICH
Dec 16, 2009 | Poulan Wild Thing 18" 40cc Gas Chainsaw -...
Pull-cord will not retract.
If you put a longer cord on it , then it will not retract as far and get stuck.
Jan 24, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
14 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
