Question about Kitchen Appliances - Others
Aroma rice cooker
Beeps after starting
early1234
  • 871 Answers
SOURCE: rice cooker stopped working after one month's use
You probably should bring it to a service center. since youve mention a span of time not using your cooker, the thermal capacitor may be busted.
hope this helps.
Posted on Jan 17, 2008
SOURCE: I accidentally put the rice into the outer pot
The problem has been solved - the bottom cover of the rice cooker was unscrewed and pried off, and after removing the insulation, etc. the rice was removed.
Posted on Feb 19, 2009
blueextc3221
  • 15935 Answers
SOURCE: need manual for Aroma rice cooker and steamer
CLICK HERE
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Jun 14, 2009
SOURCE: Need a steam vent for an Aroma ARC-838TC 8-Cup Rice Cooker
I just called their customer service (used the number on their website) for the same problem, and they are sending a replacement out in a week!! Awesome customer service!!
Posted on Aug 07, 2009
heatman101
  • 43501 Answers
SOURCE: ARC-838TC 20-Cup Rice Cooker: Lost the instructions on how to use the aroma arc ...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Posted on Jul 27, 2010
Can i use the aroma rice cooker w/ 220v?
All you need is a power converter. Go to amazon and put in the search bar 220 volt power converter.
Best regards,
Bill
Oct 25, 2014 | Aroma Rice Cooker ARC-914sbd 8-Cup Cooked...
IM IN LONDON. I PURCHASED AROMA RICE COOKER THROUGH AMAZON.120V RICE COOKER. How to use it here in London?
Look on the information label to see how many amps it draws at 120 volts. Multiply the amps by 120 to get watts. Next you'll need to get a transformer that will handle the watts when changing 240 volts to 120 volts
Oct 10, 2014 | Aroma Rice Cooker ARC-150sb 20-Cup Cooked...
My faulty transformer caused my 110 volt rice cooker to fail
Doubt it - you probably fried the control board. Most appliances don't have internal fuses, except thermal protectors which sense only heat.
Jan 20, 2018 | Aroma ARC-914 8-Cup Rice Cooker
Slow Cooker Beeps only after a few minutes and won't stop.
4 years later... I'm pretty sure it has to do with liquid in the slow cooker (maybe relating to temperature also so it doesn't overheat/burn your meal?). I just threw in some short ribs and a thick (and somewhat scant for the cooker's capacity) bbq sauce. It started beeping and beeping and beeping at fairly frequent intervals. I added about a cup of hot water and the beeping stopped.
Jun 30, 2012 | Kitchen Appliances - Others
I need an instruction manual for a model # 886 rice cooker. It is an Aroma.
Hi
I'm not much into rice cookers, so I don't know the finer differences between the models.
You can check here: Aroma Rice Cooker Manuals
http://kitchen.manualsonline.com/ex/thread/view/idThread/1901552
or from AROMA directly:
http://www.aroma-housewares.com/kitchen/appliances/manuals/Rice%20Cookers.html
Surely there will be one model close enough to yours.
Good luck and yum yum!
May 11, 2011 | Aroma Vacuums
Water to rice ratio in an Aroma ARC 1000
Water to rice ratio is usually the same regardless if you have a rice maker, or are cooking it in a pot on the stove. 2 parts water to 1 part rice works everytime.
Jun 08, 2010 | Aroma ARC-930 20-Cup Rice Cooker
Does my Aroma rice cooker have a fuse?
You have a bad connection because the wiring has been bent around too much and has failed...this will not be repairable and you need to replace the cooker...
heatman101
May 27, 2010 | Aroma ARC830 6Cup Rice Cooker
heatman101
May 18, 2010 | Aroma ARC-838TC 20-Cup Rice Cooker
Kitchen Appliances - Others Logo
21 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
