Question about Husqvarna 36 41 50 51 55 136 141 154 254 257 261 262 Oil Cap Aftermarket
Carberator adjusting hard to start and just installed new carberator
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Husqvarna Expert
  • 216 Answers
Many new units have a very limited adjustment possibility. This is due to EPA regulations. If the saw is hard to start, it may need to be richened up a little. Your dealer should have proper tool to adjust.
Posted on Feb 03, 2016
Please assist me in adjusting my carberator on a arctic cat 400 atv
Bring extra main jets with you. Keep an eye on your spark plug. if it starts looking like its burning whiter you need to bump up your main jet size!
Aug 31, 2014 | ATVs
Carberator adjustments
there are several other issues that can relate to a 2 cycle not starting.
crankshaft seals
plugged exhaust
burned up piston/jug assy
you need to investigate a little further before you think you need to adjust something...
Aug 25, 2014 | Solo 445 Backpack Gas Leaf Blower, Made In...
How to adjust a carberator on a 1979 datsun 310
Screw mixture inwards until the motor starts to cut out then back outwards until it smooths . Screw has a spring on the thread.
Jul 26, 2014 | Vehicle Parts & Accessories
Briggs & Stratton 4 cycle Lawnmower engine no fuel from carberator. Fuel is being supplied to carberator but only runs when starting fluid is used. Gas is new. What's clogged?
the float may be gummed up. or the needle is plugged up.
you need to clean the carburetor, old gas left in the carburetor turns
into shellac and gums up in side. you need to take it apart and clean it.
Jun 05, 2012 | Garden
I have a MAC 3516. I runs starts fine and runs for a few minutes at high speed (have made a few cuts), but sputters and dies. It will start again, but when I try to increase speed it dies. I have...
Try checking the fuel filter in the tank for plugging. Also, check the condition of all of the fuel lines for decay or other damage. You won't be able to adjust the jet settings if the screw heads are 'D' shaped--only authorized service dealers have the necessary special screwdriver. Try removing, then replacing the fuel cap when it quits--if the vent is plugged, it will starve the carburetor after running a while. If it works well at first, then it is not likely that the jets are mis-adjusted. Hope this helps!
Oct 08, 2010 | McCulloch Garden
Start engine after installing new carberator and gas runs out of filter
The float in the carberator is stuck, try taping the carb with a wrench to free it up. If this don't do the trick, remove the bowl off the carb and move the float by hand a few times then reassemble.
Before starting, check your oil level. All this gas has to go somewhere and its usually in the oil chamber. You may have to do an oil change.
Sep 24, 2010 | Garden
Need intructions on carberator adjustments for mac-3514 35cc/cm3 runs but hard to start after using it for few minutes.
There is a low speed jet and high speed. Low speed sets the idle or stays running without feathering the throttle./// When setting high speed, hold the throttle wide open until engine revs high, then turn back in(at least ¼ turn) to slow the engine which in turn gives the engine more gas and runs cooler. If you have it too lean on the high speed, it will be hot and hard to start. Sometimes using 40 to 1 mix helps with starting, especially on older chainsaw. good luck
Sep 22, 2010 | McCulloch Garden
MY CARBURETOR IS WEAR DOWNWHICH I BEEN PUTTING KITS SO SHOULD I BUY A NEW CARBURETOR FOR 2010 GAS MOTOR,it,s a john-deere tractor
Yes it is time to buy a new carberator unless you know someone who can make and install bushings in the trottle plate shaft, and choke shaft. What normally happens over time is the shaft wears into the housing as it is being used which allows ecsessive air into the fuel air mixer which causes inproper run conditions and no matter how much you adjust all the settings you cannot overcome this condition so its either get new bushings made and installed or purchase a new carberator. Hope This Helps Don
Nov 28, 2009 | John Deere 2010 Tractor Basic Carburetor...
New carberater and a mechanic needed!
Even if you do it yourself you need to adjust it.I would get another mechanic to look at it also.Have you tried cleaners? 1 type you add to the gas the other you remove the air bonet and spray into the top of carb while running (have someone press on the gas lightly so you don't stall.Have you tried to increase the idle via the adjusting screw? has the auto choke been tested..adjusted? Good Luck.
Sep 17, 2009 | 1984 Honda Prelude
Need carberator settings for a sears craftsman chainsaw model#358.354831
You don't want to tighten them down just turn them in until the are just snug and then turn them out.
Start with the low at 2 full turns out and the high at about 1 full turn out. Start the saw and let it idle adjust the low idle to where it runs smooth. Adjust the high until the saw runs as much rpm as you can get at w.o.t. (Wide Open Throttle).
Jul 11, 2008 | Electrical Supplies
Husqvarna 36 41 50 51 55 136 141 154 254 257 261 262 Oil Cap Aftermarket Logo
80 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
