Question about Remington Polesaw Wizard
Model 106890-02 how to tighten chain on remington pole saw
  • 188 Answers
SOURCE: Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
Posted on Apr 27, 2009
dontbother10
  • 2220 Answers
SOURCE: chain fell off chain saw remington 10
Look from the side of the saw the motor/engine to left and the bar nose to the right. The thinnest part of the chain (sharpened edge) on the top of the bar is to the right.
Posted on Sep 27, 2009
  • 5603 Answers
SOURCE: REMINGTON POLE CHAIN SAW
The chain has to be tensioned when replaced. You lift the chain away from the bar about halfway and the tangs that run in the bar should just almost come out of the groove. There is a screw that extends the bar near where it attaches near the sprocket. adjust that with the bar mounting nuts not quite tight till the chain is tensioned correctely.
Posted on Sep 28, 2009
dontbother10
  • 2220 Answers
SOURCE: Remington pole chain saw model 106890-02. Chain
We are in no way connected with RemingtonPower. They are no longer in production and replacement parts are very difficult to find. Often eBay is your only source of parts. Sorry. Lou
Posted on Mar 16, 2010
dontbother10
  • 2220 Answers
SOURCE: Remington electric Pole Chain saw - what type of oil do I use?
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain.
An excerpt from a Remington manual follows (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F.
• Colder use SAE 10 oil.
• Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
• It is normal for oil to seep when saw is not in use.
• Empty oil tank after each use to prevent seepage.
Some manuals go from page 6 to page 14. This one is very good.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/113005-01D/113005-01D_OM.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
Trouble starting
Remington Pole Saw Carbon Brushes
If you're Remington Pole Saw is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Remington carbon brushes on E-bay Search for:
Remington Pole Saw 8 AMP Carbon Brush
Apr 19, 2014 | Remington Electric Chain Saw
Mar 16, 2010 | Remington Electric Chain Saw
Where can I find a bar & chain for a remington
You provide no model number for your saw. What is pictured is a RPS96.
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" (RPS96) into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
There are 8, 10, 12 and 14" chains on the IPB depending on the actual model pole saw. RemingtonPower is no longer in production, and parts are often difficuilt to find. All 4 chains listed are available and range form $12.92 to 15.95 plus shipping and handling. You can take your saw (or just the chain) to a local saw outlet and have one fabricated in about 5 minutes. It is rarely more expensive at a local outlete and you save shipping and handling fees. HTH
Lou
Jan 25, 2010 | Remington Polesaw Wizard
Remington pole saw
Problem is most likely in the trigger switch on pole. Bypass switch and test bu plugging lamp into power cord coming from pole
Jan 07, 2010 | Remington Electric Pole Saw
Remington electric pole saw stalls in vertical positon
check the bottom of the chain guard, look for a loose bolt just inside the housing.
Nov 02, 2009 | Remington Polesaw Wizard
I AM FEMALE,HUSBAND DECEASED.I CLEANED MY REMINGTON POLE SAW AND WHEN I PUT THE CHAIN ON ,I MAKE ONE CUT AND THE CHAIN COMES OFF,HELP EMAIL ADDRESS -JIMANDJO@BELLSOUTH.NET THANKS
after reinstalling the chain,make sure the two guide bar bolts are loose, Using a screwdriver,turn adjustment screw to tighten chain to bar. Re-tighten guide bar bolts
Sep 28, 2009 | Remington Polesaw Wizard
Does my remington chain saw model #m15014AS go with the remington ext.pole model #rps96
No, the largest electric pole chain saw that can be attached to a pole with the Remington Pole Saw kit, is a 10" saw.
You can go to Master Distributors to find out more detailed info about your situation and speak with one of their reps.
http://www.remingtonchainsaw.com/
Hope you found this very helpful, best regards!
Aug 07, 2009 | Remington Electric Chain Saw
Where can I find a replacement locking nut for the pole? For 10" Remington pole saw
Without the model number, I can't provide you with the part. However, you can go to masterparts.net and click on the Remington chain saw link and with your model number, get a line drawing and list of all available repair parts and pricing.
They have almost all the parts for even most discontinued Remington chain and pole saws and have a toll free number you can call, once you have your model number to provide them with. 1-866-672-6040
Hope this helps and best regards!
Jul 31, 2009 | Remington Electric Pole Saw
Apr 26, 2009 | Remington Electric Pole Saw
What type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Mar 13, 2009 | Remington 16" Electric Chain Saw
Remington Polesaw Wizard Logo
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
