Question about Brother "hl-4570cdw color laser printer with wireless network"
Brother HL4570cdw message no waste toner box
After removing the replaceable components inside my printer to clean it, I am getting a "No Waste Toner Box" message. I have re-installed the waste toner box multiple times but the message will not go away
SOURCE: toner life
where and how to find the reset actuator?
Posted on Jun 24, 2008
  • 215 Answers
SOURCE: change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Posted on Jan 28, 2009
  • 215 Answers
SOURCE: TONER LIFE END APPEARS ON LCD
try opening front door, press "options" then "start" then "1" and "0". if screen shows accepted, you're good to go. close front cover.
hth,
razors
Posted on Feb 06, 2009
SOURCE: toner life end message after drum unit replaced
I spoke with Brother and one of the options was to open the cover, push options, push start, and then 1, then 1 again. If accept comes up, select. Then close cover and try again.
Posted on May 07, 2009
SOURCE: replaced toner, machine continues to say toner
Replaced toner, machine continues to say toner
Posted on Aug 13, 2009
Replace new toner and displeyd mesages "chesk waste toner box". i remove waste toner box and cleaned waste toner in drum unit. no result...
the top of the waste toner container must be cleaned 100% from the toner because it should be a light sensor that has to pass through it , if its spoiled with toner the light cannot pass through it ,so i recommend you to empty the waste toner container first and wash it with water and drying it well before using it again.
Feb 20, 2016 | Kyocera FS-2000D Laser Printer
Message on screen says "Waste Toner Box Full"
Typically you will need to replace the waste toner box. There is usually a difficult to access part of the bottle that is used by an optic sensor to tell when the box is full. Plus toner is very fine and you do not want it getting into the air. Toner will pass through the filter of most vacuums and go back into the air.
Dec 12, 2015 | Kyocera FS-1035MFP
Replaced waste toner box. Continue to receive "Replace Toner Box" message. Have insured that all parts back in properly. Will not print.
There is normal a clear plastic section on most waste toner boxes that tell the printer / copier how much toner is inside check to make sure it is clear! Dump the toner out if you don't have a new one BE CAREFUL CAN GET VERY MESSY. DO not use water to clean up use vacuum but do be care toner particles are small enough to go thru some vacuum filter so try some small amout make sure it does not spray your wall! Also check make sure the toner box does not have any broken small tabs the indicate to the printer thr the box is properly installed, one other check if the box has clear section match that section in the printer and clean that area sensor the monitors the clear section may have toner in it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Nov 22, 2015 | Brother MFC9340CDW Wireless Printer...
Ive replaced the waste toner box in a Brother MFC-9140CDN but the replace WTB message still continues and I still can't print. Its supposed to last for 50,000 pages, its done 8,000 pages.
Check your operator''s manual for a reset procedure. If this doesn't work, pull the AC plug overnight, if the error isn't stored in a flash memory, this may help reset it.
Jun 25, 2015 | Brother Office Equipment & Supplies
Reset wast toner box on 9970cdw
Remove the full waste toner box per manual. Wear breathing protection as there will be toner dust in the air. Place flat in a work area and remove the 6 screws retaining the black box cover and carefully remove cover with box still flat on the work area. Be careful, the box is full of waste toner powder. Dispose of the waste toner by tipping into waste container, being careful not to inhale the powder. Use a blower or vacuum to remove final traces of waste toner from the box and clean all surfaces with a clean cloth. Place the box flat on bench to inspect the clear sight-glass at the front. Inside will be a black flag which should be down on the bottom of the sight glass. If not, there is still waste toner in the front of the box which needs to be shaken or blown out. Replace the cover and 6 screws and replace the waste toner box in the printer. If error message still says replace waste toner box, then you need to check the sight glass again. The flag must be horizontal at the bottom of the glass or it is not completely empty.
Jul 03, 2014 | Brother WT300CL Waste Toner Box
Reset Waste Toner in a Brother
  1. Remove the full waste toner box per manual.
  2. Wear breathing protection as there will be toner dust in the air.
  3. Place flat in a work area and remove the 6 screws retaining the black box cover and carefully remove cover with box still flat on the work area. Be careful, the box is full of waste toner powder.
  4. Dispose of the waste toner by tipping into waste container, being careful not to inhale the powder. Use a blower or vacuum to remove final traces of waste toner from the box and clean all surfaces with a clean cloth.
  5. Place the box flat on the bench and inspect the clear sight-glass at the front. Inside will be a black flag which should be down on the bottom of the sight glass. If not, there is still waste toner in the front of the box which needs to be shaken or blown out.
  6. Replace the cover and 6 screws and replace the waste toner box in the printer.
  7. If error message still says replace waste toner box, then you need to check the sight glass again. The flag must be horizontal at the bottom of the glass or it is not completely empty.
Jan 24, 2014 | Brother WT300CL Waste Toner Box
Excess waste toner
For MFC-9840, it was simple to find and empty the box (http://www.howtofixcomputers.com/forums/printers/brother-mfc-9440cn-waste-toner-box-reuse-288524.html) and assume it is equally easy to do once you locate the box on your model.
Jul 09, 2013 | Dell 1350cnw Colour Laser Printer
Waste toner box full message after changing the waste toner box
When you removed the waste toner bottle, there is a sensor inside the copier. When you remove the waste toner, look to the opening where the top of the waste bottle was, clean that area and return the bottle and turn the copier OFF then ON. Good Luck
May 04, 2013 | Canon Gpr23 Irc2880/2880i Black Copier...
What is a waste toner box. what does it do and
like the name suggest, it collects waste toner. Any toner that is left over from the print process is waste toner. Once the waste toner bottle is full, the printer will stop working until You have replaced it with an empty waste toner bottle. So in short, if it is telling u to get a new one, get one or the other option is to empty it yourself which is very messy and if u dont clean the bottle of all toner dust, may not even work.
Oct 10, 2009 | Brother HL-4070CDW Printer
Check Waste Toner Box message
Clean the neck of the bottle and the black sensor the neck sits in.
Feb 04, 2009 | Kyocera Mita FS 1900 Laser Printer
Brother "hl-4570cdw color laser printer with wireless network" Logo
35 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
