Question about Toys
Kawasaki teryx problems
2008 TERYX. LOW GEAR POPPING SOUND LIKE A CHAIN BREAK. GOING UPHILL WITH TORQUE
  • 16 Answers
SOURCE: kawasaki vn1500 classic 1st gear problem!..
it sounds like you have a broken dog on 1st gear. (on sprocket inside gear box) gearbox needs stripping down and investigating.
Posted on Feb 21, 2009
  • 1129 Answers
SOURCE: it is difficult to change gear from high gear to
I am assuming when you say changing from high gear to low gear you are talking about changing the chain drive gears if so yes it can be difficult because the rear wheel must be removed and also the front sprocket must be held stationary in order to unscrew the hold down nut, this is usually the hardest part of the job but not impossible. Don't forget that most people that change the sprockets to increase off the line torque usually change the sprocket in sets unless you want to shorten or lengthen the chain, sometimes this si neccessary other times the chain slack adjustment range will allow you to get away with not needing to lengthen the chain, this only applies to people who decide not to chain the sprockets as a set.
Posted on Dec 07, 2009
  • 8909 Answers
SOURCE: I have a Kawasaki Ninja 636 zx-6r 2002 model. The
Probably a worn chain will cause that. Check your chain and sprockets.
Posted on Feb 19, 2011
dan4492
  • 8 Answers
SOURCE: My kawasai zr 7, 2001 revs too high in top gear, chain sprockets are, 16, 39 is this standard?
The US models should be 16/38 sprockets from the factory.
Posted on Feb 21, 2012
  • 120 Answers
SOURCE: 2010 Kawasaki teryx oil light won't go out
Get a new battery, this is a common issue on this model.
Posted on Sep 20, 2012
Are there any videos showing how to change a rear wheel bearing? If not, how hard is this to do?
Linda, looked for video on the wheel bearing replacement for your Kawi, no success. Check the attached links for your manual which would show how to change wheel bearing, I beleive the send link is a free manual. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kawasaki teryx Manual eBay
http://milatv.com/documents/manuals/2013%20Kawasaki%20Teryx%20Service%20Manual/99924-1434-06-Kawasaki-Teryx%20KRF750NA%202010-13.pdf
2010 Kawasaki Teryx 750 FI 4X4 Workshop Repair manual DOWNLOAD Download...
May 27, 2016 | kawasaki 2010 Teryx 750 FI 4x4 LE
Kawasaki teryx 2008 750 missing at low speed
Hi, Tony and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Inlet system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
12. The enricher valve not seated or leaking.
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.Engine Mis or popping at low speed Kawasaki Teryx Forum
Low speed missing and jerky start Page 2 Kawasaki ATV Forum http://www.militaryatvparts.com/service_manuals/2008-09%20Kawasaki%20Teryx%20KRF750RAF%20Service%20Manual%2099924-1434-02.pdf
http://www.militaryatvparts.com/service_manuals/2008-09%20Kawasaki%20Teryx%20KRF750RAF-OWNERS_MANUAL.pdf
Jan 08, 2016 | kawasaki Motorcycles
Kawasaki Teryx ,running down the road 20 miles an hour and it died. Turns over slow like there is back pressure and won't start
Maybe it isn't the filter. Have you cleaned your gas tank, you may have junk in it. What about your exhaust, have you cleaned that. It sounds like the caburetor. Are you putting fresh gas in the tank? Are you putting K & N oil on the filter. Try another filter if you think that is the problem. Try using Seafoam in the gas tank, can get at O Riellys. Could be spark plug. To be honest it sounds like all the things mentioned above need to be cleaned
Feb 18, 2014 | K and N Kawasaki Krf750 750 Teryx K and n...
Shimano gears
Basically, avoid cross-chaining. That is, the right-most drive chainring with the left-most cogs, or vice-versa. They place excessive sideways torque on the chain (increasing friction and wear) while not prividing any unique gear ratios that a straighter chainline would provide. The rear derailleur may not be able to take up the slack of small-small riding; or your chain length may be sufficiently short that large-large combo will pull the derailleur to far forward, perhaps even damaging it. To illustrate for yourself what crosschaining does, manually shift your bike into the two described extremes then get behind the bike and sight along the top run of the chain. You'll clearly see that it forces two unnecessary sideways bends in the chain. That is really bad for the hardware.
Generally, the large chainring is for high wheel rpm's but low rider torque, so stay toward the same side (medium-smaller cogs) of the cassette in the rear to maintain higher speeds.
Conversely, the granny gear (smallest chainring) is for high torque, low speed conditions and it works best with its same side (medium-larger) cogs on the rear. The middl ring works with all of the cogs in the rear and serves most off-road purposes that don't require extremes of speed or power.
Buy a few bicycle magaizines, visit bicycling.com and read up on shifting and everything else. It's worth it to get it right and ride smarter instead of harder.
Jan 25, 2010 | Cycling
It is difficult to change gear from high gear to low gear, it is not as easy as going to high gear. Model Kawasaki Fury 125 (2008)
Dec 07, 2009 | kawasaki W 650 Motorcycles
Toys Logo
13 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
