Question about Zebra Office Equipment & Supplies
ZP500 PRINTER EXTRA LABELS - Zebra Office Equipment & Supplies
2 Suggested Answers
Niraj Limbu
  • 183 Answers
SOURCE: Printing in page mode feeds extra blanc labels
Make sure,
you firmware is right one for that printer because in most of cases it happens due to wrong firmware and bad ADF kits. so check your ADF kids and if you find them fine the install updated firmware on in.
once you done with these all then turn your printer off and turn it back on.
post back if any thing changes and rate all answers.
Good luck
Posted on Feb 24, 2009
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
Datamax M 4208 Printer - Barcode is missing when we print the label and we also get 10 extra blank labels with it. Please help me with a solution
Sometimes it's simply the Internet Browser settings. Go to File, then Page Setup and change the margins to 0.1 and all footers and headers to Blank or Empty.
Feb 28, 2013 | Datamax M-4208 Thermal Label Printer
How to adjust intermec to print thicker labels
Only user Intermec Labels or they will probably not work.
Feb 20, 2012 | Intermec EasyCoder PC4 Label Printer
ZEBRA ZP500 SWITHC TO OFFLINE BY ITSELF. ANY GUESSING?
Check if you don't have a problem with the panel or switch.or your computer sending a ZPL code to switch the printer to off line state
May 18, 2011 | Zebra Z4M Printer
Why dose printer eject blank labels after every print
If pressing the FEED key advances just one label at a time then the printer works ok by itself. The printer will only do what it's told to do so so if extra labels feed at the end of printing, then you have to look at the printer driver or the label format for something adding the extra labels.
Hope that helps
Jun 16, 2010 | Zebra 140XiIII Plus Thermal Label Printer
Smart LabelPrinter Seiko 440
The code between the labels indicates either you are using labels designed for another model or that it is thinking it has a shippinhg label opr some lareger type installed. IT is more likely to be the first option, you are usinjg the wrong coded labels
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Seiko Smart Label Printer Pro Thermal
We are facing the same problem
Try calibrating the printer. This can be accomplished through the printer driver under 'printing preferences' or the Cognitive Printer Setup Utility
Jun 11, 2009 | ATSI Holdings Cognitive Blaster Advantage...
S4M automatically feeds extra labels everytime it's turned on
Set your print driver to "Do Nothing" on Head Close and Power Up. the next time you print will pass this information to the printer and the problem will not come back - actually the default for the driver is "Do Nothing" so it has probably been changed for some reason, you will need to change it back.
Apr 12, 2009 | Zebra Z4M Printer
Make sure,
Good luck
Feb 24, 2009 | Epson TM-L90
2 LABELS COME OUT
your label length is set incorrectly, there are 2 things it could be
1) your software is telling the printer the label length is longer then the current labels, even if the label size is out my a single millimeter the printer will give you this issue of feed an extra label. you need to change this in your software. you can set a label size smaller then the current label size and it will work correctly
2) you software is not setting a label length and so the printer is going off its internal setting, to recalibrate hold feed and power up the printer letting go after the light starts flashing
it is important to note that label roll will change slightly over time so even though you are ordering the same labels as a year ago the manufacturer will have slight changes from batch to batch
Oct 13, 2007 | Zebra LP 2844 Thermal Printer
15 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
