Question about Kuddles Ultimate Moisture Balm 4 oz
Where i can by kuddles ultimate moisture balm
What should I apply to my beard to make it extra conditioned?
There are many different types of beard products available on the internet but all products are not safe to use because they may contain harmful chemicals on them.
You can use pure natural products for your beard which will make your beard extra conditioned and soft without causing any harmful effects. You can prefer Best Beard balm like Extra conditioning balm and Extra hold beard balm as they contain beeswax, Babassu Oil, Shea Butter, Cocoa Butter, and Rhassoul Clay which offer extra condition and hold to your beard.
May 18, 2017 | Health & Beauty
Stila Color Balm Lipstick ?
Featuring a luxe, satin finish, Color Balm lipstick offers excellent color payoff, subtle shine, and phyto-derived emollient properties that deliver hydrated and healthy lips. Naturally cooling peppermint oil provides a fresh and rejuvenating sensation, while exclusive sunflower-based polyglycerides smooth lip contours and add volume and definition to lips. A handy mirror on the top of the cap makes on-the-go application a snap.
STILA COSMETICS INDIA
Jul 14, 2016 | Stila Health & Beauty
French Bull dog, he has no tail, what care can i give instead of going to the vet>
BAG BAlM is used for this application it has been around for years. i do believe it contains Antibiotics also , I have used it on my pets and children? Farmers use it on there cattle and such. very good product.
Bag Balm Vermonts Original Moisturizing Softening Ointment
May 22, 2014 | Dogs
How good.is this cream
Good for what purpose?
If you are using cream to lubricate bearings on a bicycle, then better choice would be grease from auto parts store.
If you are using cream to slick down hair, then better product might be vaseline from drug store.
If you are using cream as sunblock, then better choice is sunblock.
If you are using cream to treat rash on cat, then better to take cat to vet.
If you are using cream to protect from chapped lips, then lip balm is probably better choice.
If you are using this cream to wash hands, better choice might be bar of soap.
If you are using this cream as experiment on your skin to see if body absorbs chemicals that are added to creams, then you might have the best product. Try others and see which offers the most chemicals per dollar. Consider also that some moisturizing creams affect skin so that skin requires more cream to stay moist. Maybe it's the chemicals, so it's good to experiment. Cream from China might offer best chance of exposure to chemicals.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 14, 2013 | Health & Beauty
Can yardley pomade be used on lips to cure cracked or chapped lips?
Pomade is made intently for styling your hair. If you wish to have your cracked or chapped lips be cured, you may use products such as lip balm. The primary purpose of lip balm is to provide an occlusive layer on the lip surface to seal moisture in lips and protect them from external exposure. Lips are particularly vulnerable because the skin is so thin, and thus they are often the first to present signs of dryness.
Jun 14, 2011 | Yardley English Lavender Brilliantine Hair...
My lips have discolored due to constant picking and they look very ugly. can the color be restored
I would recommend using Burts Bee's chapstick. It's one of the only chapsticks that does not have an ingredient that will INCREASE chapped lips. Upon applying, it's not the most moist of the lip balms, but you will notice a difference over a couple of days. Try the different kinds, and find which one is for you. As for the discoloration, for a quick fix, you can use a lipstain (close to your natural color). I like using NYC's lipstain because it's cheaper, AND stays on just as long. Another tip, try applying a good amount of chapstick and take a dry toothbrush and rub the excess skin/dryness away that way. It will enhance your lip color and scrub away the dry mess. Afterwards, reapply the chapstick.
Hope this helps!
Jun 08, 2011 | Blistex Medicated Lip Balm 0.15 oz Stick
Hello, I received the secrets lip product today and am wondering if I should apply a balm over it during the day. Thanks so much for your time, your feedback is appreciated. Kim
hello
Yes you can use Lip Balm Over it. But please first check the ingredents that make up that product if glycerin, vaslin or oil is included in the ingredient, there is no need to use the balm over it.
Hope that this answer will help you. Kindly rate the answer
regards
Mar 05, 2011 | Sothys Secrets Intense Lip Care
Hi I suffer from cracked lips. How can I treat it?
You can help treat cracked lips by drinking lots of fluids and using Essentielle de Colosé (Alpine Herbal Ointment), containing nutrients that are great for cracking, chapping, rough spots and irritations. Regularly use lip balm on your lips as well.
Nov 23, 2010 | Health & Beauty
High beam dash lamp
remove instrument cluster... replace bulb! unless u have magic bendable arms!
Jan 11, 2009 | 1989 GMC Sierra
Kuddles Ultimate Moisture Balm 4 oz Logo
88 people viewed this question
Top Kuddles Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Kuddles Health and Beauty Expert? Answer questions, earn points and help others
