Question about Bunn CWTF15-TC
Pot continually fills on or off. trips breaker.
  • Bunn Master
  • 2,237 Answers
Inlet valve is stuck open. remove the front plate and locate the inlet valve in the front at the bottom. shut off the water supply and unplug the brewer. remove the nut and solenoid, and, using a crescent wrench, remove the valve shaft. take out the small metal plunger with the spring and stretch out the spring a bit. clean out any residue and put it all back together.
Posted on Dec 06, 2014
I have a ge washer that trips the breaker when it starts to agitate. I've replaced the belt but still trips breaker it spins and drains on that setting put soon as it fills,starts the breaker goes
Once a breaker "trips", it is more-likely to trip the next time at lower voltage/wattage levels. Hire an electrician to replace the breaker.
May 31, 2015 | GE Washing Machines
Viking DFB450 Tripping breaker in pots and Pans,normal, econo,cycle after prewash drains and fill. Heater or pump/motor bad? Does the pump have 2 speeds?
Dave,
You may have a bad breaker. Have you tried replacing the breaker? I would not think you heating element was bad unless it didn't heat up. If the pump works at all then the pump should be ok. If it does not work and you have power going to the pump motor then it may be causing a phase to ground resulting in the tripped breaker.
Oct 05, 2014 | Viking DFB450 Dishwasher
2005 Honda Odyseey van sliding door continues to trip breaker and not work.
make sure the cable is on the track and not running next to it dragging a heavy load on the system this happens when the door if push close while the motor is trying to run it
Aug 08, 2012 | 2005 Honda Odyssey
Hello, after the first fill it will trip the circut, I have tried what I believe to be a different circut with the same result. Washer still full of water, please help.. Thank you for any help. Model# ...
Check to see if this may be caused by a Ground Fault Interrupter. If water has gotten into the electrical system of the machine, this will continue to trip until the fault location has dried out and no longer causing electrical leakage. If this is a standard breaker that is tripping, this would mean you have a shorted motor causing it to draw excessive current.
The combination breaker/GFI can itself fail; I replaced several of these after only a few years of service.
Aug 08, 2011 | Whirlpool Washing Machines
Friedrich model 24m continually trips circuit breaker. had new 220 line installed and have replaced breaker but problem continues.
How new is unit? Looks like a portable. if it has a 3 prong plug, it sounds like the compressor is shorted to ground, tripping breaker. If its new, return it, if not, junk it
Aug 05, 2009 | Friedrich P-12 Air Conditioner
Mitsubishi Mr. Slim breaker continuously trips
Sounds like you're on the right track. Might as well replace the , inexpensive, gfi while doing so. With power off make sure all connections are tight. Electrical tape is a wonderful thing. Good luck!!
Apr 01, 2017 | Mitsubishi Heating & Cooling
Trips breaker, windings not open, no continuity from windings to frame. startsfor split second then trips breaker. Breaker is ok
ASSUMING THIS IS SINGLE PHASE HAVE YOU CHECKED THE CAPACITORS. START CAPACITOR COULD BE BAD OR BURNT LEAD. HAVE YOU MADE SURE THE PUMP IS NOT LOCKING UP. POINTS IN THE PRESSURE SWITCH LOOK GOOD. HOPE THIS HELPS, JODY
Apr 26, 2009 | Plumbing
Tripping the breaker
How far into the cycle does it trip the breaker?Does the motor run then trip it?Is it at the end of the cycle when it goes to a dry cycle?Does it trip in the beginning when it fill's up with water?
Mar 19, 2009 | Dishwashers
Air compressor trips motor breaker
PLEASE CHECK THE CAPACTORS ON THE MTR, THE MTR WILL BE HARDER TO START AFTER IT HAS AIR IN THE TANK
Nov 26, 2008 | Air Tools & Compressors
Bunn CWTF15-TC Logo
89 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
