Question about Electrical Supplies
Preglow diesel When starting the DG it shows preglow indication as well it takes time to start DG please guide us accordingly
    Sergeant:
  • 415 Answers
The glowplug is designed to heat the diesel fuel prior to cranking. Typically you energize the glow plug for 10-30 seconds then hit the starter. If the battery is weak or it is very cold, you may have to run the glow plug a little longer.
Posted on May 06, 2014
3.2 t6 ranger cold start takes long
Most long cold starts are from the fuel returning to the tank. Check ball stuck and bleeds off. Next time, turn the key on and off 3 times. If it starts faster, that's the problem. Check ball is in the tank, part of the sending unit.. I would live with it. Costly fix.
Jul 19, 2016 | Cars & Trucks
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
· Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
Peugeot 307 not starting
pumping the diesel will not do anything as there is no pump on the accelerator. Diesels always start at full throttle and when they start the governor takes over and brings the engine back to idle rpm. If the diesel is hard to start then there is an indication that the GLO- plugs are not working. Check out their operation and check out the relay that turns them on. They are small heater elements that are in the cylinders to assist the air temperature to get hot enough to ignite the atomised fuel being sprayed into the cylinders. If you do not know of these plugs then have a qualified mechanic with diesel experience show you or have him fix them for you.
Dec 29, 2013 | Cars & Trucks
Preglow light turned on during driving
If there is a problem with any electrical sensors,switches,motors in and on the engine anylon slight fault can bring the glowplug light on. I would suggest that you take to a independent Mercedes specialist and have the code read most fault are logged.
Jun 10, 2017 | 2010 Mercedes-Benz GLK 220
C220 cdi wont start
Hi it might be worth u buying new glow plugs is sound like urs ain't warming up fast enough
Jun 18, 2012 | Mercedes-Benz Cars & Trucks
My monitor screen does not turn on at the start...the indicator light is greyish...after long wait, it gets purple and then i need to re-start the computer, then it starts. It is quite annoying.
A monitor that is slow to show a picture is a good indication of a power supply that is in the first stages of failure. The filter capacitors are not holding a charge correctly and it takes a bit to get up to full change and the power supply can start up. Here is a link to a repair guide that show how to open the unit and what to look for and replace to rebuilt the power supply board. The repair guide has pictures and videos to help you get it back running again.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
I hope this helps, if so please rate my solution.
BuddyMc
Feb 23, 2011 | ViewSonic VX2235WM Monitor
Mercedes 1975 240D preglow problem
Yes its a relay issue. Should be near the drivers side headlight off the top of my head.
Jun 22, 2010 | 1985 Mercedes-Benz 190
1983 300td hard to start when cold.
The glow plugs can be worn also.Make sure the glow indicater is nice and red.
Aug 30, 2009 | 1983 Mercedes-Benz 300-Class
Electrical Supplies Logo
29 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
