Question about Brother HL 5170DN Laser Printer
Brother hl 5170dn light amber
I have a brother printer hl 5170dn and the light is amber yellow color printer will not move will do nothing anything I can do to make it move
  • 43 Answers
Open the printer - remove the toner etc. shut the door. Should resolve the problem.
Posted on Jun 18, 2009
How to print the configuration page brother 5170dn printer
According to page 30 of the Quick Setup Guide from Brother, you can print the Printer Settings Page, which includes the network settings, by pressing the Go button 3 times.
The above image was clipped from page 30 of the Quick Setup Guide, which can be downloaded here: http://k4gdw.us/1O8UFNx
Jun 05, 2014 | Brother HL 5170DN Laser Printer
Tip
Brother HL 5170DN Printer Toner error
Trick Brother HL 5170DN printer into think there is toner left. Rather than run out for a new toner cartridge use a small (.5 x .5 in.) piece of black electrical tape to cover the sensor hole on the non-gear side of the cartridge. By covering the hole the printer is fooled into thinking the hopper is full of toner.
on Feb 01, 2010 | Brother HL 5170DN Laser Printer
Broter hl-5170dn in paper jam drum
Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot
remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of
the jammed paper from the paper tray
Jul 07, 2011 | Brother HL 5170DN Laser Printer
Paper jam btother prinnter 5140
Hi justus1229,
Just click on this link and you'll have the step by step procedure on how you'll clear paper jam. This troubleshooting works for HL-5140, HL-5150D, HL-5170DN brother printers.
Hope it helps.
Thank you for using Fixya.
Apr 14, 2011 | Brother HL 5140 Laser Printer
Brother HL-5170DN 4 yellow lights - seems dead
if all the lights are flashing it means there is a physical problem with one of the main parts of the machine, such as the power supply or main board. you can find a technician on their website who would be able to fix it for you
Mar 23, 2010 | Brother HL 5170DN Laser Printer
How can you reset a brother HL-5170DN with out the password either with it connected via USB or ethernet i cannot remember my password
You'll need to reset your printer to factory settings. BE SURE TO PRINT A CONFIGURATION PAGE FIRST.
VIA THE PRINTER CONTROL PANEL
  1. Switch the printer off.
  2. Make sure that the front cover is closed and the power cord is plugged in
  3. Hold down the Go button as you switch the printer on. All the LEDs light up. Keep the button pressed down until the Toner LED lights. When the Toner LED lights, release the Go button.
  4. Hold down the Go button until the Yellow Status LED lights. When the status LED lights, release the Go button.
  5. When all the LED's light, the printer will start warming up. The print server has now been reset to its factory defaults.
Nov 02, 2009 | Brother HL 5170DN Laser Printer
I have brother 5170dn printer but printer all light continuous blinking
it is about fuser unit. Or it needs reset ,if that could not help, then you need new one. Hope it helps
Oct 29, 2009 | Brother HL 5170DN Laser Printer
BROTHER HL-5170 FUSER COUNT RESET
To reset the drum you have to hold down the go button untill all the lights light up and flash.
Aug 05, 2009 | Brother HL 5170DN Laser Printer
Is it possible to replace the fixing unit yourself on the Brother HL 5170DN?
You can, it just takes patience. Removing covers, screws and plugs for the fuser is pretty simple. You can find a fixing unit at precisionroller.com just select your make and model and then fusers and parts.
Jul 29, 2009 | Brother HL 5170DN Laser Printer
Printer doesn't work at all. Status light is red.
A voltage surge often accompanies a power cut and even when surge protection is used sensitive electronics can be damaged. Often the damage is such that the item doesn't fail immediately, or doesn't completely fail.
That happened to a friend a couple of years ago and he was fortunate enough to suffer immediate failure so the power company paid to replace his motherboard and hard drive.
You should have your printer checked by an engineer.
Jun 18, 2017 | Brother HL 5170DN Laser Printer
Brother HL 5170DN Laser Printer Logo
257 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
