Question about Texas Instruments TI-83 Plus Calculator
What is the second key on a caculater? - Texas Instruments TI-83 Plus Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
It's the key at the top left of the keyboard, just below the five function keys, marked "2ND"
Posted on Apr 16, 2014
Hi i have windows 7 & just purchased a perixx wireless keyboard every time i hit the shift key the caculater pops up most annoying how do i disable it for ever. many thaks alex
open the keyboard software and find the hotkey menu and disable it. should be self explanatory. let me know if you can't find it
Feb 20, 2012 | Acer Computers & Internet
Odometer has becme brown and the readings are almost impossible to read in daylight .i beleive from exposure to florida sun.Please don't suggest polaroids.Any one else with this problem?Ihave a 2003 and...
my 04 honda vtx 1300 and my 4 wheeler did the same but before i replaced them i did some experminting and found out what i could use to keep that from happing. i took a old caculater and put some window tint on it thats what helped my 4wheeler i really couldnt find much to put on my bike so i just took a old leather glove and used that to cover it.
Dec 24, 2010 | 2004 Honda VTX 1300
How would u get the caculater to do a square root problem like give i the real anwser
Turn calculator ON
If you see no icons, Press [MENU]
Use the arrow keys to move highlighting over RUN/MAT
Press EXE button.
In Run/MAT screen press [SHIFT][MENU] to access the (SETUP)
By default the mode is et to real as you see on screen capture below
In this mode if you press [SHIFT][X^2] to access the square root, then type in a negative number) you get the following message
To be able to operate on complex number you must set the calculator Compl mode to a+ib. You have to press F2(a+ib)
Press the F2 key corresponding to tab a+ib (complex)
Now if you enter what is on the next screen capture you get the correct result.
There is another way to enter complex numbers: the polar form. It corresponds to the F3 tab r<Theta
With angle set to degrees, you can enter complex numbers in r(r,theta) form (use [SHIFT][X,Theta,T] sequence to enter the wedge). Heis a sample.
I magnified the screen capture before pressing the Post it button, but I dot vouch that the system will respect my wishes. Sorry if pictures are too small for your confort.
May 24, 2010 | Casio FX-9860G Graphic Calculator
Ti 83 is frozen error window screen what do I do
push 2nd +7 then 4 then 2 this will reset the whole caculater. if it stills does the same thing then it probly need to ne replaced..
Apr 15, 2010 | Texas Instruments TI-83 Plus Calculator
The screen of my ti83 fills with pixels when turned on. Can this be fixed?
there is one choice for you to do push 2nd +7 then 4 then 2 this will reset the whole caculater. if it stills does the same thing then it probly need to ne replaced..
Apr 14, 2010 | Texas Instruments TI-83 Plus Calculator
Where is the ab/c button in the TI 83 plus caculater?
There is no button, otherwsie you would have discoved it. However you can use a command called [|=>Frac] or [ToFrac]. It is accessible through the key sequence [MATH][1:ToFrac]
To use it , you enter the numerator and denominator of your fraction, and before pressing [ENTER] , press [Math][1:ToFrac]. Thus by pressing the key sequence, you force the result to be displayed as a reduced fraction.
Apr 01, 2010 | Texas Instruments TI-83 Plus Calculator
I have replaced the batteries on the key remote control but it does not work
Programming
When
Key added or replaced. System malfunction.
How
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Mar 22, 2010 | 2005 Honda Accord
Black scar
Sounds like you have crackedthe lcd screen. Not worth repairing.
Jun 10, 2009 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
