Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
F2 fault showing on dish wsher motor
Sounds like no water coming in just stops F2 showing according to manual motor fault
3 Suggested Answers
  • 3247 Answers
SOURCE: Hi I have a DD603
Before we talk about water not draining away, can you confirm if the wash arms rotate during the wash cycle. The rotor works as a wash pump and drain pump depending on which cycle it is in.
If F2 keeps coming then it is also likely there is some debris in the rotor cavity which is grinding on the rotor. But one needs to be sure if F2 is coming up only in drain cycle or is it already on during wash cycle.
Posted on Jun 02, 2011
caroldon
  • 17130 Answers
SOURCE: All of a sudden my lovely Fisher& Paykel dish
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor .
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water .
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
For spares click On:
http://www.espares.co.uk/search/dishwashers/p/1083
Posted on Jul 21, 2011
Kenwood KID60B12 Dishwasher F2 Fault code
it seems you a blockage.. can you hear the pump running?if you can you will need to unstop it I have done it with just a cloth hanger coming from the front in put side
Jan 01, 2016 | Kenwood KID60B12 595 mm Stainless Steel...
Fisher and paykel dish drawer with fill fault icon. The icon comes on about 2 minutes into the cycle and stops the wash. If the center button is pressed the wash resumes and usually finishes without a...
What is the code you get and which lights are flashing when this happens? This is important because I suspect you have a low rotation issue to the motor and it does not see or sense water in the drawer. If so, you should get a F2 fault. I need more information to assist you correctly. Please get back to me and I will help you or lead you in the right direction.
Thanks
Sep 23, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hi I have a DD603 F & P dish drawer. I had an F2 fault, found the rotor motor seized. I've replaced that but F2 still comes up & the water doesn't drain away. Any ideas?
May 16, 2011 | Fisher and Paykel 23 in. DD603H SS...
Fisher and paykel soft touch dish washer, motor is running, but no water coming through, no kinks in hose
I have Fisher paykel dish washer hardley use but now says motor problem F2 call for service anything I can do first
Nov 26, 2010 | Fisher and Paykel Dishwashers
Cycle runs but dishes are still dirty. No water.
Sounds like an inlet valve. If there is no water in the pump when it runs you can burn up the rubber seals. After fixing the fill problem you should check underneath for any leaks.
Jul 03, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
Adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
May 24, 2010 | Dishwashers
Looking for list of fault codes for dish drawer
I hope this is what you are after
F1 Flood switch has been
activated.
Turn the water and power supply to the
DishDrawer® off and call your Authorized
Service Center.
F2 Motor problem. Call your Authorized Service Center.
F3 Temperature sensor failed. Ensure water coming in through the inlet
hose is not hotter than 65oC. You may
need to install a tempering valve on your
water supply.
F4 Faulty temperature sensor
or element
F9 Electronics malfunction. Call your Authorized Service Center.
U1 Fill Fault 1 Turn the DishDrawer® water supply on.
2 Ensure the spray arm can rotate about
the center, and if the DishDrawer® is
full of water, it will need to be emptied
manually.
3 Call your Authorized Service Center.
May 05, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Wsher stops in the rinse cycle wiht a n F4 message
f2 error means long drain or no drain
check the drain pump
replace drain pump if nessesary
Mar 17, 2009 | Kenmore Washing Machines
Bosch
f is fill fault to much or not enough water or water in the sump white plastic base the f code will not go away until you solve the problem when the f code shows up the drain motor will run all of the time
Apr 01, 2006 | Bosch 24 in. SHU6802UC / SHU6806UC...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
11 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
