Question about Dometic Refrigerators
Installing light switch
Light switch wiring
2 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: Pull switch wiring
What you have is a switch for a ceiling fan/light combination.
Black wire from your light is power, White is Neutral (do not connect this to switch or dead short).
Posted on Apr 24, 2009
I am installing a SPST door switch in my closet and have two ceiling lights both getting power with a pull string. What is the sequence i should use when wiring these two lights to the switch ?
Assuming both lights are operated by the one pull switch and its working correctly as it is Just disconnect the black (hot) wire and the neutral (white) wire from the pull switch and connect them to the new switch black to dark terminal and neutral to silver terminal. You will obviously need to run a 14/2 cable from the door switch to the old switch location if you don't have one there.
Mar 15, 2015 | Electrical Supplies
Why after installing a Pass and Seymour lighted single pole toggle switch, the CFLs in my bedroom light flicker on and off.
Is the switch wired wrong?
Does the switch have 4 wires?
Look at wiring for single-pole timer and see it it applies to your switch
http://waterheatertimer.org/How-to-wire-timers.html
Gene
Oct 06, 2014 | Electrical Supplies
I can't find the timer for my outdoor lights
Is there a photo eye located on light fixture?
What is the light doing?
Is it not functioning?
Are you installing a switch?
http://waterheatertimer.org/How-to-wire-switches.html
Are you wiring a wall timer?
Nov 12, 2012 | Hardware & Accessories
I am installing a Leviton 7299 smartlock pro gfci combo switch. I am also installing a new vanity light. I have 2 wires coming in. One from the panel box and the other going to the new vanity light. I have...
run a jumper wire from brass load on gfi to top screw on switch then the black wire from light to the other screw on switch, white wire from vanity light should be connected to silver load screw on gfi WILL NOT WORK IF NOT GROUNDED PROPERLY if your ground is connected to common (white) in your breaker box this could cause issues also. a sure ground is the plumbing in your house. if you have copper lines you can use a saddle connector to ground the gfi, if these options are not available contact an electrician in your area.
Jul 04, 2012 | Electrical Supplies
I"m installing a Cooper Devices
Wiring is suspect.
Black hot wire connects to dark screws.
Break off tab should be intact.
White neutral wire connects to silver screw.
Wire going to switch load connects to brass screw.
Jun 18, 2011 | Cooper Industries Cooper Wiring 274W...
Wiring bath fan with Fan/ light combo. Want to operate the features on seperate switches. Have power wire Black/ White/Green. Each switch has own wire Black/White/ Green. In the unit there is a Blue/white...
If I understand correctly you are installing two wall switches.
Your switches are switch1 and switch2
Each switch has 2 brass-colored screws
If you have a double switch, see page bottom
And you are installing a fan/light combo with separate wires for fan and light.
Bare ground wires and green wires connect to each other and to green screw. A ground wire runs from fan/light to switch box where it connects to other bare copper wire and these wires will not be discussed.
Lets work from the fan/light down to the switch.
Blue-wire-fan connects to either brass screw on switch1
White-wire-fan connects to white Neutral (we'll talk about this wire as we go)
Black-wire-light connects to either brass screw on switch2
White-wire-light connects to same Neutral as White-wire-fan.
So you need 3 wires running from fan/light to your switch box.
One wire arrives at switch box and connects to brass screw on switch1
One wire arrives at switch box and connects to brass screw on switch2
One wire is the Neutral wire and it arrives at switch box and connects to other white wires inside switch box. Twist these wires together and cover with wire nut.
Now your white Neutral is connected to other white wires in switch box.
Each switch still needs another wire.
The Hot black wire from breaker box connects to brass screw on both switches
Pardon the crude drawing.
The switches would actually be located next to each other, but it was easier to draw like this.
Drawing shows 3 wires coming from fan-light to switch box.
The drawing shows the black and white wire arriving from breaker
The drawing does not show how the white wires are joined with a wire nut
If you have a double switch, with 2 switches stacked vertically.
The screw colors can be different.
Double switch could have brass screws on both sides, in which case your Load (fan-light) wires connect on one side of device, and your Hot from breaker connects to other side. It doesn't matter which side, but loads on one side, hot on other side.
Double switch could also have dark screw(s) on one side and brass screws on other side.
In this case, the black Hot from breaker connects to dark-colored screw(s)
And your Load (fan-light) connect to brass colored screws.
If you need more information, or if something is still confusing, answer back.
Oct 26, 2010 | Broan-NuTone Fan,Bathroom Exhaust Broan...
Hi I am installing a trailer electric brake
I belive it would be the wire that actually sends the control signal to the controller?...correct? well the if so you would need to tap into the wire casing with a test light to see which wire is lighting the test light when the brake pedal is depressed good luck
Sep 11, 2009 | 2006 Toyota Land Cruiser
Pull switch wiring
Apr 17, 2009 | Refrigerators
Refrigerators Logo
10 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
