Question about Google Finance
SANSUI FR-D45 TURNTABLE
WHEN YOU TURN TURNTABLE ON THEN A GREEN LIGHT FLASHES ARM MOVES OVER. THEN TURNTABLE TURNS OFF. AFTER ABOUT 15 SEC.
  • 927 Answers
SOURCE: Turns on and turns off.
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Posted on Sep 30, 2008
sharptech1
  • 29 Answers
SOURCE: My sony KP-57ws500 flashes green then turns off.
YOU HAVE A BAD GREEN CRT. UNIT IS NOT WORTH REPAIRING SINCE YOU WOULD HAVE TO REPLACE ALL 3 CRTS FOR THE UNIT TO SET UP PROPERLY.
Posted on Jan 12, 2009
Phantomgreen
  • 128 Answers
SOURCE: my ps3 wont turn on. light turns green, flashes
This is known as the yellow light of death.(ylod) It's about 150 bucks to have it serviced unless it's still under warranty.It says in the manual it is an overheating issue.
As for your problem, call customer support at 1-800-345-SONY
Posted on Mar 26, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a problem with a Sansui turntable
Linear tracking tonearms probably don't move much under manual control. It would still help if we knew the model number.
Posted on May 17, 2010
  • 6 Answers
SOURCE: I have a Sansui FR-D3 Turntable. The speed fluctuates
The spindle is probably seized up due to dried up grease.I collect vintage record players and dried up grease is a common problem especially if the previous owner had not used the player for some time.Taking the spindle apart is a reasonably easy job and sites like Vinyl Engine can prove very helpful in explaining how to take things apart safely.
Posted on Dec 17, 2010
Go to turn on it turns on for 15 sec, then turns off flashes green light
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 23, 2015 | Televison & Video
My turntable turns and the arm moves onto the record but then the arm moves back and the turntable shuts off. What's wrong?
The auto reject/auto return lever has been advanced therebt tripping the arm to return to the pick up rest.It needs adjustment.
Jul 13, 2014 | Denon Audio Players & Recorders
Sansui pl 50
It is purely a mechanical problem. Contact any service technician.
Sep 15, 2013 | Televison & Video
PS3 wont power up
try another outlet if the light still will not turn green you will need to contact sony,
if the light does turn green let me know and we will get this fixed
Dec 24, 2011 | Sony Playstation 3 (PS3) Console
Looking for a stylus for old sansui turntable model FR-D25??? Any suggestions
It is next to impossible to find a replacement stylus, I suggest replacing the cartridge which will include the stylus giving you the flexibility to make a choice on what you prefer.
Mar 19, 2011 | Sansui Audio Players & Recorders
Mitsubishi WS-55857 turn on/auto turn off problem
After it shuts off, you need to get a code from the tv by pressing the menu and device buttons together for 5 sec. A code will flash at you made up of 2 digits. Example. 2 flashes a pause and 2 flashes points to a convergence failure. If this is not your code post yours and I will help you.
Jul 06, 2010 | Mitsubishi WS-55857 55" Rear Projection...
May 17, 2010 | Audio Players & Recorders
Have a Sansui compu edit p-m70 turtable. I turn
Lift off the turntable mat and the platter. Near the tone-arm, remove two screws holding down a panel and then inspect the tonearm belt. They wear out and stretch out and this could be the problem. Replacement is easy and does not require any special tools or further dissasembly.
Lock light indicates that turntable platter speed has reached correct speed.
Aug 21, 2009 | Sansui Audio Players & Recorders
Land Cruiser (2006)Emergency Flashing Lights will not turn off
Unplug the battery fr 15 minutes then that should reset your computer
May 16, 2009 | 1999 Toyota Land Cruiser
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
Apr 22, 2009 | Televison & Video
Finance Logo
62 people viewed this question
Top Google Finance Experts
Bill Boyd
castletech
castletech
Are you a Google Finance Expert? Answer questions, earn points and help others
