Question about Optiquest Computers & Internet
My optiquest monitor flickers on and off all by itself. Any ideas
The on off switch is useless. I turn it on and it goes off, then comes back on, and off...... After shutting down the whole system and monitor, I can come back in a few minutes and see the monitoe has turned itself back on?
  • 17 Answers
SOURCE: Gateway Flat Screen FPD1830
My Samsung 215TW started flickering like a strobe light when I would turn it on... then after a while, the speed of the flashing would change, and eventually, it would go out. After turning the unit on/off several times, I could get it to stay on, but after a while, it would start to get odd video noise (strange colors appearing on the screen), and then it finally quit.
Once the monitor went dead, I noticed that I could still see the image on the screen, albeit very dark, so I took my desk lamp, and placed it next to the screen, and I could see that the monitor was still active, meaning that there was an actual image on the screen, it was just that the fluorescent lamp that lights the screen was not staying lit.
I got tired of waiting for Samsung's customer service (thats a story all within itself), so I took the monitor apart in search for the problem (I am an electrical engineer and electronics specialist). I saw that there were two circuit boards, one being the power supply board, and the other being the video signal board. Knowing that there was still a video signal present, I focused on the power supply board, as it contains the transformers to ramp the voltage up to the necessary voltage to light the lamps.
I instantly noticed that several of the radial electrolytic capacitors on the board were bulging and looked like they had swollen and then blown. There are 5 caps on my monitor that needed to be replaced: (1x) 47uF/50V, (2x) 820uF/25V, (2x) 330uF/25V.
The 47uF and 820uF caps are on the power supply side of the lamp power circuit, and the 330uF caps feed the control signal into the IC chips that control the ballast of the lamps themselves, one for the upper lamp, the other for the lower lamp.
Once I replaced these units, my monitor started functioning correctly, and I dont have to give Samsung my absolute most favorite monitor ever for a refurb unit that most likely will have 15 dead pixels on it (mine has ZERO).
Posted on Dec 08, 2008
bigdogg85
  • 3 Answers
SOURCE: Soyo monitor goes dark every few minutes.
take it a part and look for swelled capacitors take out the bad ones and soder new ones in and then its back on
Posted on Jan 13, 2009
SOURCE: optiquest q9 turns off
read the solution I have wrote on th Q7
display goes blank after few second
the fix is about 5 $ the supply is almost dead
Posted on Feb 01, 2009
  • 57 Answers
SOURCE: Monitor goes black after running for a few
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Posted on Aug 10, 2009
  • 208 Answers
SOURCE: Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Posted on Sep 02, 2009
I have a optiquest Q20WB monitor when i push the power botton the green light flashes but the monitor doesnt come on.
More likley to have bad caps like other Optiquest monitors as shown in my albums.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed OPTIQUEST monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 23, 2010 | Optiquest Computers & Internet
Viewsonic Optiquest Q19wb lcd Monitor goes blank after 2 secs. A couple of posts say replace the 1000uf 16v Cap My problem is i can't find them on the pcb (where are they?)
Look at the board where the AC power connector comes in that is the power supply board, there are more than one versions so it nay not have the same caps value.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic/Optiquest monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Post pictures or send them to me budmrtn@aol.com
May 15, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
Turns off and then turns back on again on loop
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Viewsonic monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Apr 29, 2010 | ViewSonic OptiQuest Monitor
My Monitor just stopped working. No pop, no fade, just dead. Oh, sorry it is an optiquest Q19wb says manufactured in 10/2006. bought 1.5 years ago at best buy. Worth trying to fix or dump it??
Optiquest is the Viewsonic low end products. You can take it apart and look inside.
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 30, 2010 | ViewSonic Optiquest Q19wb LCD Monitor
When I power on my viewsonic monitor it flickers and the screen doesn't come on. It is a 19" Optiquest model number VS11201 that I have had for 2 years.
After 2 years, more likely the caps will be bad by now, worst case will be bad lamps, open it up and look inside for caps with bulging top first, see example of failed monitors due to bad caps/lamps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
Feb 13, 2010 | ViewSonic OptiQuest Monitor
Optiquest q20wb goes to black screen after 2 secondsthen turn it off and back on stays on for about 2 seconds again goes black and if you leave it on the video will come back and then turn off almost right...
First to check will be the power supply, look for bad caps with bulging tops first then report back so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 04, 2010 | Computers & Internet
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Optiquest q9 turns off
Jan 18, 2009 | ViewSonic OptiQuest Monitor
Computers & Internet Logo
367 people viewed this question
Top Optiquest Computers & Internet Experts
Alun Cox
Vladimir Frolov
Tom Chichester
Are you an Optiquest Computer and Internet Expert? Answer questions, earn points and help others
