Question about Midea MDF-50AEN1-BA6 WP 50PT ES Dehumidifier
WHy does P1 code come on display for my Westpointe DeHumidifier
3 Suggested Answers
  • 5370 Answers
SOURCE: the P1 light is on
P1 means the evaporator coils are freezing up.The P1 error is related to low airflow.This can be due to clogged or dirty filter.Take the filter out and clean it, if its dirty the dehumidifier can frost up due to the lack of air flow and will not work correctly.In some cases if the filter is too old then it has to be replaced.This should help.Thanks.Helpmech.
Posted on Dec 01, 2010
  • 8 Answers
SOURCE: WHy does P2 code come on display for my Westpointe DeHumidifier
I could not find the user manual for your particular model but the manual for the MDF1-30AE model indicates that the P2 code is when the bucket is full or not in the right position.
If you have already emptied the bucket and the error remains I would recommend checking around where the bucket goes as there should be a switch that gets pressed by the bucket when it is in the proper position.
My guess would be that when you are putting the bucket in it is not properly hitting this switch.
Source: User manual for MDF1-30AE
Posted on Oct 25, 2012
What is the warranty for Westpointe dehumidifier
1 yr parts and labor/ 3 yr. sealed system
Westpointe is a brand of True Value
w
Nov 15, 2017 | Dehumidifiers
What is wrong with a Westpointe dehumidifier when it stops removing water and displays P1? It will run this way for hours and kick in and work briefly once in a while on continuous.
Usually the P1 error indicates that dehumidifier needs to be defrosted. The unit has detected ice build-up on the condenser coils.
Unplug the dehumidifier for several hours. Then plug it back in. If the problem recurs, check that the fan that blows air across the coils is working properly. Make sure that the room is not colder than the operating range of the dehumidifier. If the problems continues to occur, you may have a refrigerant leak in the system. That will require a service call to repair the dehumidifier.
If the unit is under warranty, contact Westpointe. The manual I have for a Westpointe 65 PT dehumidifier, https://www.appliancefactoryparts.com/content/pdfs/136333-1.pdf, indicates the unit is covered through year 5 after purchase for a refrigerant system. For Warranty service, the contact point is Midea Consumer Service at 1-866-646-4332. If the unit is not under warranty, consider whether to replace the dehumidifier.
I hope this helps.
(I have seen a dehumidifier develop a refrigerant leak. It constantly froze before the leak was repaired and the refrigerant topped off.)
May 15, 2017 | Dehumidifiers
Oct 25, 2012 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
Spt 65 pint error code p1
According to the manual, this code, P1, means that it is in a defrost cycle. I now have the problem that my unit is in the P1 mode as often as it is in the dehumidification mode.
May 15, 2012 | Sunpentown 65 Pint Dehumidifier with...
My Whirlpool AD40USL5 Dehumidifier is displaying P1 on the control panel. I am not able to find any information about this in the User Guide that came with my unit. Could you please tell me what this...
Here is a link to the Owners Manual for the model number you listed. However, it does not have a LCD display on the Control Panel, which would show the Error Code P1. This is a Kitchen Aid brand that was manufactured by Whirlpool with the AD40USL5 Model Number. This came directly from Whirlpool's website. Hope it helps you in some way.
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%201187730.pdf
Apr 04, 2011 | Whirlpool AD40USL Dehumidifier
DDR4010E just bought and set up now a couple hours later the display reads:P1. what does that mean?
P1 is code for defrosting. Once it's done defrosting it should start operating
Oct 29, 2010 | Danby Dehumidifier
Polar wind dehumidifier: p1 or p2 code after emptying tank.
P1 error indicates that:
  1. The water tank on the side of the unit is full.
  2. The water tank in not properly seated in the housing.
  3. The switch at the back of the water tank housing is not engaged or is loose
Jul 24, 2009 | Kenmore 54501 Dehumidifier
What does P1 mean on display?
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
I hope that helps.
May 16, 2009 | Danby Dehumidifiers
My model is DDR4009EE, after it run for a while, the display changed from RH to "P1",what does "P1" mean?
My Danby DDR657EE shows P1 periodically also. So, I called Danby.
He also described other General Codes (applicable to most Danby Dehumidifier/Humidifier models):
E2 = Not draining
So, if you see P1 periodically (for brief periods), then it would be normal.
Also, here is a link to Danby's FAQ page for Dehumidifiers (which answers some common questions):
https://www.danby.com/faqs.php?cat=12
I hope that helps.
May 11, 2009 | Dehumidifiers
P1 error
Your question needs to be answered in 3 parts:
1) As per the manual for my Danby Dehumidifier (Model DDR657EE), the unit may not turn on immediately when powered On (it may take a several minutes). So, generally, it would be normal in your case.
2) Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
E2 = Not draining
So, generally, if you see P1 periodically (for brief periods), then it would be normal.
3) Since your unit keeps running (continuously) and there is no water in the bucket, then you should call Danby ServiceI for additional assistance - it seems defective for this reason.
I hope that helps.
Oct 31, 2008 | Danby DDR2506 Dehumidifier
Midea MDF-50AEN1-BA6 WP 50PT ES Dehumidifier Logo
73 people viewed this question
Top Midea Dehumidifiers Experts
J.D. Browning
J.D. Browning
jasbo
jasbo
Andrew Taylor
Andrew Taylor
Are you a Midea Dehumidifier Expert? Answer questions, earn points and help others
