Question about Moen & Posi-Temp Single Handle Shower Or Tub Valve
Tub drain smell badly after faucet repaired
Smell old socks increase badly from drain hole after repaired the bathtub faucet. I flush tub with hot water first then put 1cup soda powder and sit for 30 mins then followed with 4 cups of vinegar. But the smell of old sock still didn't go away. Can anyone let me know how to resolve this problem?
  • NukeDog
    NukeDog Mar 16, 2015
    Estoman711 is on point here. Could be worse though. I went to service a similar complaint only to find there was no drain on any of the plumbing. Whoeverr / whatever installed the plumbing on this residence simply ended ALL the plumbing below the flooring into the crawlspace below. The homeowner had purchased this home from a DIYer who claimed to be a Tradesman. Raw sewage and greywater eventually silted in the soil below to the point the whole underneath became a backed-up cesspool.
  • NukeDog
    We had fun with that one!
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 37 Answers
The trap is installed incorrectly
Posted on Apr 15, 2014
  • 102 Answers
SOURCE: I have a moen 1 knob push-pull faucet for my
The old MOEN single handle faucets like youve described usualy took a 1200 or 1225 cartridge. Both are available at most of your big home improvement stores. The answer to your question is yes MOEN parts are still avail. Hope this helps. If this advise is helpful, please give me a vote.
Posted on May 14, 2010
radar001
  • 1051 Answers
SOURCE: How do I repair a leaky Moen faucet handle. When I
It needs a new cartridge. Moen gaurantees most of their products for life, so if you have the original instructions check for contact info. They'll send you a new cartridge for $0.00
Posted on Jan 14, 2010
  • 49 Answers
SOURCE: Moen shower/tub faucet
hi... yes that's a very common issue with moen "cartridges" -- it's very simple to fix..... grasp the handle and give it a gentle tug upwards when the water is on... if it retracts again, pull the handle out again and tug again but this time a bit harder. Not sure what causes this on new cartridges but it will fix your issue.
Posted on Sep 03, 2009
  • 119 Answers
SOURCE: & One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
Posted on May 19, 2010
  • 61 Answers
SOURCE: no hot water flow from the upstairs bathroom
yes it can I recently had a service call where the integral shut off valve was completely clogged with debris and no water came out
Posted on Jun 27, 2010
How do I unclog my tub?
Put a cup of Baking Soda in drain, then add two cups white vinegar! This should foam like crazy wait ten minutes ,run real hot water.
you may have to repeat a couple times.
this will not hurt pipes unlike some drain cleaners.
Oct 02, 2016 | Moen & One Handle Tub & Shower Faucet
Tip
Mildew smell, gray streaks, won't drain, puddles on floor, burnt motor smell
I have had various issues with my fisher paykel top loader (GWL10US) and didn't realize they were all due to a plugged drain. I had mildew smell from excess water that never drained, gray streaks on clothes from dirt and residue that remained in tub, water left in tub and wet clothes after spin cycle, puddles on floor, and finally it wouldn't drain at all and the motor smelled hot/burned out.
This was all caused by a sock that got in between the outer/inner tub and went to the lowest part of the drain and finally blocked things so a leak was created and water dripped into the motor and caused a burn out.
To repair, bail water out of washer and unplug the washer. Tip machine back so you can see the motor/white plastic housing unit (pump) on bottom of washer. Where this unit attaches to the bottom of the washer, look for a clip/tab that you can pull with your finger (like a childproof cap) and twist the unit off the machine and unplug the connectors (there are 2). Once this unit is removed, you will see a quarter-sized hole into the bottom of the wash tub. this is where i found the elusive SOCK and pulled it through the hole.
When you order the "pump" it comes as one unit--motor and white plastic--and you twist it back onto the machine and plug in the connectors.
another website I've found helpful is ths.gardenweb.com/forum/laundry
on Oct 21, 2008 | Fisher and Paykel IWL12 Top Load Washer
The problem is my bathtub won't drain.
on most applications, where the lever for the stopper is located, mounted just under the faucet, also serves as the overflow for the tub: unscrew that plate and then you can pull the stopper linkage out. maybe you have a bunch of gunk (hair, etc) blocking the drain. once you have the entire linkage out, boil about a gallon of hot water and pour it down the drain; immediately follow with HOT tap water; if it drains, GREAT, if it doesn't, just let the HOT water sit there for a few minutes; then get your hand plunger and go to work. be sure to block the overflow hole (where you took the plate off) with plastic so that when you are working the plunger, you get good suction.
Apr 20, 2010 | Moen Home
How to fix a sulfur smell from hot water side of faucet.This started when we replaced an old faucet with a new one.
Probably coincidence, but that sulfur smell is likely from your water heater.You'll either have to shut-off power, or gas, to water heater, and drain it down, then re-fill it, or leave hot taps on, and let it flush itself out. If you have a way of introducing bleach to line coming in to house, such as a pump or something , you can do that to help flush that smell out of water heater, otherwise, flushing or draining may be your only option.
Jan 07, 2010 | Delta Victorian 2155-SSLHP Bar Two Handle...
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 | Home
Musty smell
This problem is caused because the water does not get totally pumped out of the outer tub and sits in the bottom of the tub and in the front seals. Eventually a mildew type scum develops and causes the washer to stink and also impart the odor to clothes. Even though front loaders do use less water and energy, all of them have essentially the same design and therefore all will eventually develop this problem.
Run a load with just bleach (about 1 cup) and white vinegar (about 1 1/2 cups) poured directly into the washer with hot water and it seemed to help, but this does need to be repeated about once a month or so...
but with your wife's Asthma tho you could try
Typically the cause is the machine itself, but occasionally the water being used in the washer can be the source of the problem. If the smell resembles rotten eggs, you may need a water filtration system installed. After you eliminate any other possibilities, you can begin the treatment process. Create a mixture of baking soda and vinegar. Add 1/2 cup of baking soda to 2 cups of white distilled vinegar. 3Begin a wash cycle using the machine’s hottest setting. As the water rises, add the baking soda and vinegar mixture. Let the washing machine complete a full cycle. If you notice any residue that has been loosened, use a cloth to wipe the surface clean. Run a cold water cycle to complete the process. You should immediately notice that the smell has been neutralized.
Feb 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Mildew smell
water may not be draining completely out cause something is stuck in drainage area.
Other posts tell how to remove the top of washer to look between white outer tub and inner wash tub for sock or something else that is lodged.
Look at my post on "eco smart won't drain, smells hot" for instructions on removing the black motor/white plastic housing from bottom of washer. I had a sock stuck in the very lowest part of the drainage system, water wouldn't drain out and couldn't see the sock until I removed the motor. I was able to pull the sock through the quarter-sized hole in bottom of tub and drain the remaining very stinky water. I used a dog dish (need a low edge bowl to fit under washer), tipped washer forward, then back and just kept emptying the dish.
Saw another post said don't tip washer back. There is something on backside of washer that you could break if you tip backwards. So, if you tip forward i guess you won't break anything--i haven't...yet.
Noticed a musty smell lately, and also had gray streaks on my clothes. Think the standing water that wouldnt' drain out has been my issue for some time now and when the motor burned out, I finally had to research the other issues.
Sep 20, 2008 | Fisher Paykel EcoSmart GWL15
Admiral Washer smells like mildew
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
Apr 10, 2008 | Admiral AW22 Top Load Washer
Musty smell in washer
From another consumer with the same problem:
The mildew smell started about a month after we got it and got increasingly worse! Had a service tech out who replaced the gasket, but he left me a product called WHIRLOUT. It is made for hot tubs and spas and whirlpool tubs. You can get it at a pool supply or Home Depot or Lowe's. It is made to remove the soap scum buildup that provides a growing environment for the bacteria, which produces the smell. You add about a cup to the normal wash cycle. Do not put in the dispenser, add when the water is in the tub. I ran it through twice the first time. Then about once a month to keep it clean. Another thing he told me, don't use dryer sheets in the dryer because they will eventually cause a film to build up on the sensors that tell you when the clothes are dry. I've switched to Downey fabric softener in the washer. He also told me NOT to use a really thick fabric softener because it will not go easily through the dispenser. There is a drain hose by the filter on the washer - pull it out first and drain the left over water into a bowl or pitcher before you clean the filter. This will prevent the mess when cleaning the filter!!! LG never told me this, the same technician showed me this, too!
Mar 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Moen & Posi-Temp Single Handle Shower Or Tub Valve  Logo
114 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
