Question about Wahl Clipper Corp Bravura Clipper catalog Category: Dog:grooming
I recently purchased a used wahl bravura pet clipper...type 1870 A. Is there an online operating manual for this machine?
Thanks
Wahl trimmer instructions
RTM. Read the manual. If you need a manual, you can get on by Google, with your make and model and manual and you should get results. Or go to pet grooming school.
Aug 06, 2014 | Wahl Animal Clipper Pcmc-2 Dog Cat Horse...
How do you adjust the head to cut various thickness of your dogs hair?
RTM. Read the manual. You're probably not using the correct blade and size.
Clippers not cutting
It is not unknown for a sharpen to be no good, anyone can turn out a bad sharpen. Look for correct blade assembly, check that there is sufficient pressure holding the blades together, check there is no missing stroke. Check the blade is secure and not wobbling. If the above are OK I would buy a new blade. You could also return the blade with the clipper for the sharpener to test for themselves.
Nov 20, 2013 | Wahl BravMini Rechargeable Trimmer Purple
Wahl 9590-210 Pro-series Complete pet clipper kit - corded and cordless operation, will not charge, only used once, bought new on US amazon using in Perth aus., it looks like the resistor has blown, the...
Is it the correct voltage? Check your transformer specifications, operating voltage will be written on it. If the blown resistor is on the PCB beside the battery it is not supplied as a separate part, it comes on that PCB. www.unityagencies.com.au will be able to direct you to an agent able to supply parts.
Oct 22, 2013 | Wahl 9590-210 Pro-series Complete Pet...
I used my Wahl clippers for my horse a few months ago and one night when i needed to use them the blades will not move, it will just vibrate is it someting with the alignment?
The blades are stuck together because you didn't lubricate them before you put them away. Oil them and force them apart with a knife or screwdriver, use the gap between them at the side.
Feb 28, 2013 | Wahl 9160-210 Corded Basic Pet Clipper Kit...
Replacement filter for KM2
Contact your nearest Wahl agency www.wahl.com
Oct 29, 2012 | Wahl Two Speed Dog Grooming Clippers Km2...
Needs screws for a Wahl 8786451A Arco SE Pet Clipper
I would take it to Home Depot or Ace Hardware and gently try to fit screws in until something fits easily. Then adjust up or down for the correct length. Should be pretty easy.
Hope this helps! Dont forget to rate!
Jun 26, 2012 | Wahl 8786451A Arco SE Pet Clipper
Wahl Clipper Corp Bravura Clipper catalog Category: Dog:grooming Logo
129 people viewed this question
Top Wahl Pets - Others Experts
Anglia Clipper...
paul tooker
Ross Keen
Are you a Wahl Pets - Other Expert? Answer questions, earn points and help others
