Question about Peg Perego John Deere Turf Tractor
Info. for starter wireing hookup for model 3tn66uj
    Genius:
  • Peg Perego Master
  • 1,508 Answers
These toys do not have a starter
Posted on Aug 18, 2017
I am trying to find my starter wire and power wire connected to my ignition
What make , model and year vehicle ? Wire connected to my ign. ? Ign. switch , ignition system (coil's , ICM , ) ??????? Starter Wire ???? need more info .
Jan 09, 2017 | Cars & Trucks
89 f150 changed key switch,ignition switch,starter solenoid no power anywhere now
Do you know anything about automotive electrical ? How to follow a wiring diagram ? Basic electrical testing ? Using a DVOM - digital volt ohm meter etc.... You could go to http://bbbind.com/free_tsb.html free wiring diagrams ! Enter your vehicle info ,year ,make , model an engine size . Then under system click on electrical distribution ,then under subsystem click on power distribution . It will show 2 diagrams found . Click on the search button an two blue links will pop up .Click on the first one scroll down to last diagram . This is a diagram of ignition switch an power feeds ! Check the two yellow wires for B+ voltage . No power there would mean one of the fusible links blew . Scroll back to the top diagram ,the fusible links are shown at the top left .They hookup at the starter solenoid > There are videos on youtube showing basic electrical testing , how to read a wiring diagram , how to use a DVOM . This is how you have to find the problem ,testing !
Aug 14, 2016 | Cars & Trucks
Where do you hookup starter kill relay on 06 Porsche cayenne, or where is the starter wire located?
    [PDF]Cayenne 2003-2006 - Porsche
    www.porsche.com/all/media/pdf/.../en/E_9PA_KATALOG.pdf
    Porsche2006. 21.01.2010. MG. Pos. Part Number. Description. Qty. Model. 0. SG. 01. Illustration .... (3) 955 612 507 00 wiring harness. 1 I1D9. (3) 955 612 508 00 wiring ... images for 2006 porsche cayenne wiring
Mar 13, 2015 | Porsche Cars & Trucks
Took my ev6010 generator out and put it back in but hooked up the starter motor to the ground not to the positive and now it wont start. I also changed the oil and coolant.
On the ev6010 Honda generator the posive starter wire is black and was accidently hooked up to the chassis ground wire. Then the start button was pushed and nothing happened. I corrected the wire hookup to the positive side but will not start still
Aug 28, 2013 | Honda Ev4010 Ev6010 Rv Generator Inverter...
Im replacing the starter on my 1995 mitsubishi galant. I need a picture of the wire hookup to the starter.....you know, which wire goes to the negative and so forth
this might help...Same concept ..3 wires http://www.google.com/search?q=how+to+install+a+1995+mitsubishi+galant+starter&um=1&hl=en&source=lnms&sa=X&ei=TO4OUqrrHMaB2gXtmYCgAw&ved=0CAgQ_AUoAA&biw=1024&bih=672#bav=on.2,or.&fp=1cb0759d76b6b3f9&hl=en&q=1995+mitsubishi+galant+how+to+replace+the+starter+
Aug 17, 2013 | Cars & Trucks
Battery hookup for a 35 hp vanguard
Follow the wires from the solenoid its wires go from the battery to the starter, a small wire on it comes from the switch it would be the wire from the switch that is the furtherest on the switch "starting " blade on the switch..the heavy wire to the starter should be red the small wires black..good luck
Apr 21, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Wiring hookup on starter chevy cavalier
i have a 97 cavalier and i have 5 wires that connect to the starter but i dont know where 1 of them goes
Mar 11, 2010 | 2001 Chevrolet Cavalier
Need to replace starter im not mechanical incline. i know basic
Get a chilton manual online if you a DIYer and it will save you time and money..Basic step by step-Remove postive batt cable. locate starter, obtain new starter to see location of mounting bolts,remove starter mounting bolts,remove wires firrst if accessable if not starter will lower when mount bolts out ,then remove wires noting where they go. hookup wires and replace in reverse. note:some can be hard to get to-always handy to refer to a manual Good luck..oh replace positive cable when aal is tight and right...
Jan 20, 2009 | 1990 Nissan Pathfinder
AIWA CDC-x227 CDPlayer
GO to WallMart, Kmart, Radio Shack, etc. and get a new connector adapter (plug)...they're reasonably priced, have them for all make/models of cars, and make installing a car stereo a breeze! When you get the one for your specific car, the wiring instructions are quite easy to follow! :-)
Dec 03, 2006 | Aiwa CDC-X227 CD Player
Peg Perego John Deere Turf Tractor Logo
53 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
