Question about Ricoh Office Equipment & Supplies
Konica unix 1015 error icon blink - Ricoh Office Equipment & Supplies
  • 168 Answers
SOURCE: Konica 1015 parts
Try this company. I have used them many of times.
I checked their website and they do carry both parts that you are looking for.
Here is their main website. http://precisionroller.com/
Then on the left side, click "Konica Minolta" then "1015" then click "Fuser Rollers"
and you should find them.
See if this direct link works:
http://precisionroller.com/catalog_display.php?fm=0&step=3&MfrID=297&ModelID=590&CategoryIDs%5B%5D=16
If I have helped you with your question, please remember to post a feedback and a rating.
Good luck.
Mac =)
Posted on Feb 19, 2008
  • 42 Answers
SOURCE: konica 1015
While holding 2 and 5 turn on machine.Press 4 then 7 then p.Press 0 then p.Turn off then on ,this will reset copier if it does not have a fuser problem which is f35.
Posted on Aug 02, 2008
SOURCE: Error code F34 on Konica 1015 copier is there any
No...it's a fuser error (low warm up temperature)...It's a blown fuse, or lamp, and the code can only be reset in 'service mode'after fixing the fault
Posted on Mar 12, 2009
jqsababa967
  • 145 Answers
SOURCE: I have a error code F34 on a Konica Copier can anyone help
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Posted on Mar 14, 2009
jqsababa967
  • 145 Answers
SOURCE: KONICA 1015 COPIER - P.27 ERROR MESSAGE - - WHAT
2. Toner was added prior to adding developer and performing the TDS adjustment. Developer must be added FIRST at new machine set-up so that toner does not fall on the uncovered TDS sensor.
Run 47 mode, output code 51 until the code does not reoccur (may take 5 to 10 attempts) OR open the developer unit and clean the excess toner from the area of the TDS sensor. Then tilt the developer unit to allow fresh developer into this area.
3. Poor connection at CN95. The toner density sensor (TDS) is abnormal (0.2 V DC or lower). Reconnect CN95 (located under the front of the developer unit).
4. TDS failure. If version 16.0 is installed, P27 is displayed when the TDS is disconnected or fails. Check for proper connection prior to replacing the TDS.
Posted on Jul 13, 2009
I cant see the icon for my web cam in dell vostro 1015 on windows 7 platform
Your problem description makes no sense. Try to be a little clearer. WHAT is not working? WHAT, if any, are the error messages?
All I can tell is either your icons are disappearing or maybe your having a device problem. Please elaborate.
Oct 26, 2011 | Dell Vostro 1510 Laptop
Konica 1015 copier has been in storage for 10 years
You need a drum cleaning blade. These blades will go bad if left unused for that much time. This part cleans all that toner off of the drum in between copies. Cheap part at about $25.00 to $35.00
Just google konica 1015 drum cleaning blade and you will find one.
Dec 28, 2009 | Office Equipment & Supplies
My Konica1015 shows a p.27 error message, what
P27 Toner density sensor unplugged or toner density sensor problem.
Conduct the condition of the sensor of the toner and presence of the toner in block of the manifestation, as well as presence of the perfected toner, clean the container with perfected by toner in block of the drum. Thank you.
Sep 23, 2009 | Office Equipment & Supplies
Replaced drum error light blinking
Start the Konica Minolta Status application on your PC and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Apr 14, 2009 | Konica Minolta magicolor 2400 Laser...
Konica Minolta 2400W Magicolor. Error light blinking
Ready indicator Error indicator Condition Action
Green Orange
Blinking Blinking Communication Check The Printer
error cable
____________________________
Print over-run Turn off the printer.
After a few seconds
turn on the printer
change to a lower
resolution.
________________________________________________________
This may help if not...let me know........Whytfang
Mar 25, 2009 | Konica Minolta magicolor 2400 Laser...
Error code F34 on Konica 1015 copier is there any way to fix without service call?
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Konica 1015
Add toner.
This will take care of this problem.
Please post a rating if I have helped you.
Any more questions, please post again.
Thanks
Sep 06, 2008 | Office Equipment & Supplies
Konica 1015
Aug 01, 2008 | Ricoh 6513 Copier
Konica 1015 parts
Good luck.
Mac =)
Feb 18, 2008 | Office Equipment & Supplies
18 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
