Question about LG M1910A 19 in. LCD Television
Connection how can i connect LG M1910A 19 in LCD Tv to a free view box
eagle338
  • 4889 Answers
SOURCE: How do I switch off subtitles on my LG 19LG30 19 in. HDTV LCD TV?
Hit the menu button, select options , select "hard of hearing", turn off and press ok.
Posted on Mar 01, 2009
SOURCE: Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Posted on Jan 28, 2010
SOURCE: connect tv to cable box with hdmi lead
You will need an HDMI to DVI cable which are available in the shops, even ASDA has one but I don't know how good it is. Or you can buy an adapter that will plug into one of the ends of the HDMI cable and then plug into the DVI socket at the back of the TV. The DVI input is video only so you will need audio leads for sound. These will connect from the output of your source, say, blue ray or sky HD (Left and right audio sockets ) to the audio L/R at the back left of the TV (on the block next to the three component video connections and s-video connections)
  • 65 Answers
SOURCE: I want to connect external
You don't necessarily need a receiver. You can use powered monitors (speakers). Powered computer speakers would also work. I have the 32" and use Beringer powered monitors using a standard 3.5mm audio cable to connect to the TV. Works well. Optical interface is available and would probably perform better but I doubt I would notice the difference.
Posted on Jan 03, 2011
  • 159 Answers
SOURCE: I recently purchased an LG
Hi, The set top box will more than likely have two coaxial connectors ( threaded/ribbed pieces of metal ) coming out of the back. also three R.C.A. connectors-these will be smooth and be colored yellow red and white. one of the coax connectors will say " IN FROM ANT> or CABLE IN) the other ( OUT TO T.V. ) hook up your dvd recorders " ANTENNA " input to the set top box's ANTENNA output. If your D.V.D. recorder doesn't have an antenna input then hook up the recorders audio/video input to the set top box's audio/video output. then you should be good to go. If you buy a H.D.T.V. tuner to receive FREE H.D. programming it may be possible to hook up to recorder with H.D.M.I. cables.( those connections resemble slots ) I hope this has been of some assistance, good luck, Prodzilla.
Posted on Apr 02, 2011
Why am I getting after retuning two vertical black lines either side of my screen on some programmes "?"
Try to check the connections between boards inside the tv. If you can then remove those connections and reinsert it. especially the connection which go to lcd panel from the mother board
check the videos to know hoe to remove the connections .
If you wish to get some details; check the site linked here
http://electro-medical.blogspot.com/
Plasma TV Repair Ribbon Cable Removal Install Tutorial Overview LG LCD TV Repair How to Replace 6871L 2045A Con Board How to Fix LCD TVs
Nov 04, 2015 | Finlux 19H6030 19" LED TV 1280x720, 50 Hz,...
I have an indoor digital aerial connected to a free view box but when I automatically tune the TV it comes up with no channels found check aerial connection
Possibly. Try rotating the antenna a little bit and retry tuning. Keep on doing this until you get your channels. If this doesn't work, raise the antenna as high as possible and try again.
Dec 20, 2014 | Goodmans GTVL19W17HDF 19 in. LCD TV
My 19ld350 lost signal and will not retune
If the video inputs still work, give it to someone for use with a satellite, cable box, video games, dvd, etc. but if it truly needs a tuner, a 19" TV is usually not worth a main board replacement.
Feb 15, 2014 | LG 19LD350 19Inch 720p 60Hz LCD HDTV 19 in...
On / off switching screen
It sounds like you have a bad (but not quite dead) capacitor on your power board. It costs only a dollar or so, and is easily replaced if you can solder. But it is probably not worth having a repair shop fix. They will replace the whole board. Have a look at badcaps.com.
Jan 24, 2014 | LG M1910A 19 in. LCD Television
How do i get freeview reception on my 19' LG TV/MONITER its not picking up any channels in bedroom...recommend best antenna to fix please
Get a Digital antena,any name brands.Make sure it put some where high,will get all the free air tv channels.
Apr 12, 2010 | LG M1910A 19 in. LCD Television
Bought new tv but dont get as good reception through my top up tv box as my last tv
WHY U ARE USING UR TOP BOX WHEN U HAVE A NEW HDTV LCD TV
EVERYTHING IS BUILD INTO UR NEW TV......SO PLEASE DISCONNECT UR TOP BOX AND YOU WILL HAVE A PERFECT PICTURE... CONNECT ANTENNA ONLY TO UR NEW TV
GO IN TOUCH WITH THE STORE AND LG AND ASK FOR HELP.......AFTER ALL UR NEW TV IS STILL UNDER WARREN TIE..........SO FREE SERVICE FOR 12 MONTHS
Nov 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Not able to connect my lap top to to the monitor
the laptop should have a special area under display properties and goto settings you should see 2 screens if not it might need the top addres bar settings change and you will have to choose which screen is the primary and secondary and if you click to verify the screens the screens should have a number of which is the primary is 1 and secondary is 2 on the screen and if you have the icon to change these setting near the clock then try right clicking it and it should be up a option screen and it should should have the option to output to monitor and screen....
Dec 01, 2008 | LG M1910A 19 in. LCD Television
Trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
Nov 24, 2008 | LG M1910A 19 in. LCD Television
Rolling picture
Try the free view and see if the box is bad, then if it still does the sane thing, I bet theres a bad connection on the driver IC board, on a connecting ribbon cable, or a bad drive ic. These are things that a user should not attempt to repai, as there are no user replaceable parts inside this set and should be serviced by a train tech. Good Luck
Oct 10, 2006 | LG 37LP1D 37 in. LCD Television
LG M1910A 19 in. LCD Television Logo
14 people viewed this question
Computer Repairing
Computer Repairing
