Question about Water Heaters
Cointra godesia boilers
Our heater leaks gas when the level in the gas canister gets low.
5 Suggested Answers
jeff_drakesr
  • 155 Answers
SOURCE: water level to low on boiler
There is a automatic valve that is suppose to open when water gets low in the system. They do rust up and quit working. You can add water to the system. There should be a waterline making a loop around the automatic valve. It will have a manual valve open this up to allow the water through and close it again when the correct water pressure/level is acheived. Should replace the automatic valve as soon as possible. I hope this has helped, please rate if it has helped in any way. Good Luck and have a great weekend.
Posted on Apr 02, 2010
Healeyman
  • 1198 Answers
SOURCE: Gas boiler leaking
The video zeroed in on a relief valve. They love to leak once opened. If it won't re-seal after you lift the little handle and let out some water, you will have to replace it.
Posted on Dec 01, 2013
charles_ma
  • 169 Answers
SOURCE: cointra electric water heater (5 years old). Leaking water through base panel. No T & P Valve visible. I have emptied it and removed the base panel but am not sure whether to refill and observe or
Usually, this means that the water tank is leaking. It is not worthwhile to fix the leakage unless you have welding equipment. Just buy a new one.
Posted on Feb 22, 2014
cougar123
  • 77 Answers
SOURCE: My Cointra Godesia E10P water heater seems to have too much gas flowing. There are flames coming out of sides and the top of the casing. Water is not getting hot and there is a smell of gas. Sometimes
leaks in line get loca repairman repair guy there soon
Posted on Nov 17, 2014
My Lochinvar residential gas heater is showing "lockout low water level. What could this be?
First, I'm not a Lochinvar Tech.
* call vendor for service. Gas leaks are hazardous and require a qualified tech to service.
* Low water indicator usually means your supply water stopped feeding. Check the water line for pressure. Turn on a faucet or nearby sink for both cold and hot water. If you get cold water but not hot (or at least water flowing from the hot side even though it's cold water as your heater is still off.) then check the cold water inlet to the heater as it might be off. Check if the output of the heater is turned on. (some heaters have a shut off valve at inlet and outlet to allow for quick heater replacement.)
* If you still don't get water then you have a clogged water line. Though it is possible to have a clogged heater, especially if it's 10 years old or you have a lot of sediment (sand) in your water. You would know this as your sink faucets spout screens needs constant clean out. (like every month it gets clogged) May need to replace heater and/or call a plumber if the water line is clogged.
*** The following is for information only.***
* I've always had problems servicing gas stove, heaters, boilers, etc. Lots of unique components that require special tools to service.
* I was surprised to find out that it's better to call on your local Gas Supplier for service. The not only check the supply line but also have a very good working experience with all types of gas fired equipment.
* Check gas mains for pressure and flow (you need a gas meter for this but if you have another stove on the same line then it's probable that the mains are okay. Unless the connector or shutoff valve is not working properly (partial open).
* Check gas hose to for sharp bends. Replace if bent (re bending will crack a metal hose.)
* Check the gas regulator (again, need a gas meter)
* Final, Be safe; Call your Gas company or MFR tech for service.
Aloha, ukeboy57
PS The following vid may be helpful
https://www.youtube.com/watch?v=Pz6DWmeo2dY
https://www.youtube.com/watch?v=9bdLuGKaCXI
https://www.youtube.com/watch?v=sMDTEjJUImw
Jun 06, 2018 | Water Water Heaters
My cointra gas water heater has started switching off hot water after 1 minute in the shower
contact a local plumber that can diagnose the system . we can not for here.
Apr 09, 2018 | Water Water Heaters
The heater starts leaking gas when the level in the canister gets low.
You are going to have to supply more information before somebody can help you. Make, model, etc.
Apr 14, 2014 | Water Heaters
Cointra electric water heater (5 years old). Leaking water through base panel. No T & P Valve visible. I have emptied it and removed the base panel but am not sure whether to refill and observe or just...
Feb 22, 2014 | Water Heaters
Either the pilot is not lit, or the thermostat/gas valve is not working.
Dec 18, 2013 | Water Heaters
Gas boiler leaking
Dec 01, 2013 | Water Heaters
Cointra godesia water heater... works perfectly but only for 5 mins then pilot goes out... u can relight straight away and it works for 5 mins again .. this boiler I have just bought new ... j
In my experience thermocouple either work or they do not.when a water heater runs for a length of time before the interupter cuts the pilot or on some modules safety cut out sensor also known as over heat thermostat cuts the gas supply the problem can normally be found in the flue restricting the disposal of waste products of the combustion or the lach of air flow through the appliance
May 19, 2013 | Water Heaters
I have a Rheem glas fury model 22-40 gas water - leaking
Dear Hank McNeal; I have successfully used a "boiler plug" to seal a water heater tank leak in 2007. It was a 100 gallon electric commercial hotel unit. To this day it's still in use. It depends where the leak is located....Predrilling the leak is necessary to be sure the plug will ernguage it's threads into good material... Start as small as possible, then use the best suited plug. they come in an assortment of sizes. rheem-glas-fury-model-22-40-gas-water-qbzdprdp3yetvbzozs4dsujq-4-0.jpg
Oct 23, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water leaking
it sounds like the gland on the valve is leaking unusual in a valve so young but it does happen. is the valve electrical operated or water pressure. you should be able to get a complete diaphram kit with all seals etc .
Nov 16, 2008 | Bosch 1600P-NG Natural Gas AquaStar...
Water Heaters Logo
22 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
