Question about GE GBS22HCR Bottom Freezer Refrigerator
How to Clean the Condenser Coils on GE model GDL20kcsabs
  • 159 Answers
SOURCE: clean condenser coils
Its not easy but a flexable vacume hose would help. and aslo you can take the end peice off and try to get it from the inside to. Good Luck
Posted on Jul 18, 2007
  • 351 Answers
SOURCE: We have a 6 year old GE Monogram side-by-side
do you say i solved this problem?
Posted on Apr 25, 2009
aasc
  • 1606 Answers
SOURCE: GE Model # GDL20KCSABS clicking sound
The control board is going out . Pt # WR55X10656 . Soon , you will start having a refrig problem . Probably already started , but , not obvious yet .
Posted on Aug 27, 2009
livewire874
  • 618 Answers
SOURCE: how do i clean the condenser coil on a GE side by
Take off the rear panel over the compressor .
Posted on Nov 30, 2010
  • 230 Answers
SOURCE: What's your problem?GE Model # GDL20KCSABS clicking sound Clicking sound
The clicking noise would generally be the overload on the compresser. Which means the compresser is locked up and unable to pump and needs to be replaced. Sorry You can install a 3in1 hard start which may free the compresser rotor and give you a little more time out of it but will need to be replaced eventually Good luck
Posted on Sep 08, 2012
My ge frig side by side the frig side 65 degrees why need help model number tfx22zrxd
You probably have a defrost problem -accumulation of frost on the freezer back panel. check for frost first then ask additional questions.
if no frost exist, check the condenser motor under the fridge and also clean the coils.
Jul 07, 2015 | GE Refrigerators
12 year old GE ref side by side both sides warm
has cleaning the condenser coils helped out? does the condenser have a fan? if so when the compressor is running it should be running also. is the compressor hot to touch?
May 20, 2014 | Refrigerators
GE 23.5 Model # TFF24RC Makes Noise, Won't freeze, center post gets very hot.
If this is an older unit, take the rear panel off and check the condenser coils in the back on the back of the refrigerator, and check to see if the fan is running back there or if anything is block the fan from running, if nothing is blocking it and its not running this is a bad condenser fan, if it is running check to see how dirty the coils are, if they are really dirty take vacuum or brush and clean them should fix your problem.
Sean
Mar 26, 2011 | GE Refrigerators
GE refrigerator Model GTS18FBSARWW Don't have manual, as it came w/the condo. Don't know how to clean the coils or how to get to them, either. Thanks.
The condenser coil is located underneath the refrigerator on most models. YOu can access it from the front, or in some cases, in the rear. To access it from the rear, after pulling it away from the wall, you will have to remove the machine compartment cover screws and the cover itself. If it is the type i believe it is, it is called a no-clean condenser, but they still need occasional cleaning. It will be a barrel shaped condenser on the right side of the machine compartment. A good refrigerator tip for anyone looking to clean the condenser is to make sure you turn the fridge off or unplug before cleaning it.
Oct 13, 2010 | GE GTS18FBRWW Top Freezer Refrigerator
Not cooling as well as it has took the front off and saw ice on the front
Clean both condenser and evap. coils
For a start
Dirty or clogged condenser coils will prevent coils from
removing heat thus ice forms. reducing air flow
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 18, 2010 | GE AJCS10AZA Air Conditioner
Ge window unit 5000 btu it on all day feels hot air some times frozen by the condenser
Remove from window and remove the case,and clean it with a water hose,and do not bend the fins on the evaporator ,or condenser coils with the water hose pressure,but make sure the inside,and the coils are clean.The coils need to have all dirt and debris removed .
Jun 10, 2010 | Heating & Cooling
Can't find refrigerator coils/ cooling issues
There're two coils ,the condenser coil wich you already clean (also make sure the condensing fan motor works properly and the fan blades are also clean).The other is the evaporator coil wich is located inside the freezer behind the back wall cover.
Apr 21, 2009 | Refrigerators
Always defrosting GE Model 20
clean the condenser coils at the back and make sure the condenser fan by compressor is running if is not running you mightg need to call a tech to trouble shoot it or if you want repl both the motor and main board like i said you might need a tech to trouble shoot it
Oct 16, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE side by side refrigerator
Try pulling toe plate at bottom front and clean the condenser coils. If they are plugged, it will cause this to get hot. If you can't see coils in front remove back panel and clean coils there.. Give it time after cleaning to see if it helped. If no change, remove back panel and check to see if fan is turning when the compressor is on.
Also check for something caught in fan blade, such as a dead mouse or a dead coupon. If fan isn't turning, may need condenser fan motor. If still need help, give us a model number. Found in refrigerator compartment at top on side walls.
Nov 22, 2007 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Clean condenser coils
Jul 17, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GBS22HCR Bottom Freezer Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
