Question about Garden
My Pressure washer isn't at 100% pressure
My pressure washer is running at 60% it's normal pressure. I was thinking it had something to do with the valves and so I ordered all the replacement rings. I removed the caps but I'm having trouble trying to remove the valves as they seemed to be stuck inside. I thought dissembling the pump would make it easier but I cannot get the two part to separate. Watch a video on Youtube and thought there would be springs that would push it apart, but this didn't happen. Even used a hot air gun thinking there was lock tight holding it together, but I no luck. Any suggestions would be great, thanks.
SOURCE: Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Posted on May 21, 2009
  • 3 Answers
SOURCE: karcher k2400hh pressure washer, water pressure cuts out.
Hello cikanek:
Try this:
From your posting, I assume you have removed the splash cap and the nylon bypass valve cover. Connect the water supply to the pump and connect the high pressure hose and wand to the pump outlet. Wad up a small towel and place it over the bypass valve opening to catch the valve insert when it pops out. With the engine throttle closed, pull the starter cord several times to see it the valve insert will pop out. If it doesn't come out after two or three pulls, set the throttle to low and start the engine. I have performed this procedure a number of times and the valve insert always pops out. There is no real danger of the valve parts getting seriously airborn since the actual pump output volume is very low (2.5 Gal/min).
Good luck,
Posted on May 23, 2009
SOURCE: Karcher K 2400 HH Pressure Washer no pressure
Posted on Jun 05, 2009
SOURCE: Karcher pistol gun has broken
Make sure you DO NOT have a check valve (this is what stops your hose running when you disconnect from the hozelock fitting) in your hose pipe system, This will send a shockwave through the pressure washer and destroy the fitting you mentioned. They can be easily removed.
Posted on Jul 25, 2009
  • 174 Answers
SOURCE: Troy Bilt pressure washer model 020209 will not
A leaking gun will kill all the pressure. You may need to repair or replace the gun
Posted on Sep 17, 2009
Low diastolic pressure for what reason
That paper coined a new term, "isolated diastolic hypotension," which refers to a low diastolic blood pressure (less than 60 mm Hg) and a normal systolic pressure (above 100 mm Hg). Older adults who fit those conditions are at increased risk for developing new-onset heart failure, the researchers found.17 May 2015
UAB - The UAB Mix - Diastolic blood pressure: How low is too low? Low diastolic pressure for what reason Google Search
Dec 13, 2016 | Health & Beauty
I have a S10 Chevy my oil pressure gauge going s back and forth 40 & 60 driving stopping somethings below 40
Could be normal.
Idle RPM pressure is lower than say 2000 RPM
You could replace the sending unit or have the actual pressure checked with a mechanical gauge.
Jul 06, 2012 | Chevrolet Cars & Trucks
I have a 1998 jeep wrangler sport and it is having starting problems. i usually have to crank, release, then crank again to get it to start. it always ends up starting, but it takes a few tries. it occurs...
You can mount a fuel pressure guage to the engine fuel rail at its bicycle valve bleeder, with tof see if it has pressure when you first turn on the key to start. You may be able to hear the fuel pump running by listening at the fuel tank fill cap that you would remove for that moment. By turning on ignition to start, not run, you are energizing the fuel pump to bring up pressure that should happen in several seconds. So, check if it gets to normal fuel starting pressure, maybe 45 to 60 psi. Then turn key all the way to run, to get car engine running and watch the fuel pressure to see if it stays pretty constant at that 45 to 60 psi. Turn engine off, and watch how long it takes for fuel pressure to drop, and it should not happen fast but instead over 15 minutes or more. That might indicate your fuel regulator valve isn;t working right.
Is it possible your starting system is the culprit, say some battery cable loose that may make starting hard or eventually quit until you tighten these cable ends at battery and starter.
Aug 03, 2017 | 1998 Jeep Wrangler
Theres a code "LF" beeping....
Hello there and thank you for choosing fixya
When your washer displays error LF , it is due to low water pressure, slow or continuous fill.All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems;
  • Slow Fill- low water pressure reduces the speed at which water flows into the machine.
    • Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
  • Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine isn't supposed to be filling.
    • Contact the water company to verify the pressure being supplied to the house
  • Error Codes- LF for long fill or FH for no water detected.
    • A plumber may need to be consulted if the pressure is found to be too low.
May 16, 2011 | Washing Machines
How to Maintain a Bike's Tire Pressure for Good Performance?
Buy a good floor pump with a gauge (see "How to Buy a Bike Pump," under Related eHows). A small, frame-mounted pump is useful only for roadside repairs.
Understand that it's normal for most tires to lose up to 10 pounds per square inch (psi) per week. This does not mean you have a slow leak.
Look on the tire's sidewall for tire pressure recommendations. Don't exceed the maximum tire pressure listed.
Inflate your mountain bike's tires to 40 psi for dirt riding. You may wish to inflate your tires to 50 to 60 psi for city riding.
Inflate your road bike's tires to 100 psi for road riding. Some road tires have much higher psi ratings. However, 100 psi will provide a good mix of performance and comfort.
Inflate your hybrid bike's tires to 60 to 70 psi for city riding.
Check your tire pressure before every ride
Dec 21, 2010 | Cycling
Model EXVRB2321 would run only with full choke,
What engine is it? The plug gap should be preset, But I'm glad you mentioned the compression, it should be 100 lbs.. , 70 lbs min, or it won't start. You might have a valve burned out from the choke being on. Most engines won't run with the choke on, so something was wrong. You can pull the head and the valves easy enough to see what it is. One more thing, make sure there is nothing holding the engine back from running, like the pressure washer is full and ready to go, let the pressure out if you can. Hope this helps.
May 12, 2010 | Garden
Low pressure
hi some valves at cat pumps need a 100 psi pressure to open and close correct. when there is air in the pump the valves wil not open and close till air is bleeded. take of highpressure hose, open watertap and bleed pump till no more air comes out. reconnect all hoses and try again. if there is no more air in the pump and its still not working, i should think its the pump.
Jan 31, 2010 | Dewalt 3800 PSI Pressure Washer
Hesistation on pressure when trigger is pulled get n worse
Unloader valve is the most likely suspect here.
Remove and clean with penetrating oil then reinstall.
Also add some LIGHT oil into your supply hose via a small funnel. 3-in-1 household oil or power steering fluid lubricate the valve and pump quite well. Three or four treatments of a couple ounces each will usually make the pump happy again. If this unit has an OIL-FILLED pump on it you can expect good results. If it runs an OIL-LESS pump it is only rated for about 100 total hours of life!
Hope this helps.
Sep 26, 2009 | Honda Karcher G4000RH Pressure Washer
What is the correct fuel pressure on a 96 Dodge grand Caravan?
Don't have access to actual pressure required at this moment but I will tell you that 12-20 psi is definitely not enough. Your probably looking at a minimum of 50-60, and as much as 90-100 depending on what engine. A replacement for a 3.3.L at autozone is rated at 90-100 psi. I'd spend the money on new pump & filter at same time.
Mar 23, 2009 | 1996 Dodge Grand Caravan
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
