Question about Sennheiser Audio Players & Recorders
Sennheiser px 200 ii jack (plug) broken, need to replace
I stripped of the broken part to replace it with another stereo mini-jack plug, but when i stripped the wire of my sennheiser i noticed that there were not three, but four copper whires running through (copper-red-green-blue). Since I have no idea what this implicates, I would like to ask for your help. Thanks!
3 Suggested Answers
  • 1138 Answers
SOURCE: replacing headphone connector
The impedance or resistance of the two different sets of wires might be different. The higher the impedance the less signal. If your cable is long enough you are better off spending the five or so dollars for a new plug. Red is right, green or blue is left and copper is ground.( Usually) Unfortunately not all manufacturers agree. Also what could have happened is a short between the wires that you soldered.Make sure they are physically separated from each other and insulated.
Posted on May 14, 2009
  • 61 Answers
SOURCE: Replacement connector for Sennheiser PX 250 doesn't work...
The bare copper conductor wire is the screening/common earth to the two signal wires of green and red. The important connection is the copper wire which goes to the jack plug earth which is the section furthest from the tip. The other two are the left and right signal connections. If you get these the wrong way round you will just have to swap them over. Check if they are the right way round by using the balance control on your amplifier or whatever. Have you checked that the problem is not with the headphone amplifier within your equipment? Don't rely on OK sound from loudspeakers as the headphones may be fed from separate op-amp output chip. Try another pair of cheap and cheerful headphones to make sure.
Posted on Oct 04, 2009
How do you repair a sennheiser sk100 jack socket
I assume you mean the mic plug/jack. Bent pins or broken connectors will require a new jack and/or plug installed and they are not easy to do. These 3.5 mm jack connectors require both a light touch during install and soldering. If you're a pro then start shopping for a replacement 3.5 mm mono jack but be warned. The jack may solder directly to the PC board....which reminds me. Look for broken connections from jack to PC board..a common failure point and resolder as needed.
May 01, 2014 | Sennheiser Audio Players & Recorders
Wiring issue and one of the headphone is not working. how to sort this out?
I think you will have to send it for repair as the wire maybe damaged
Oct 02, 2012 | Sennheiser PX 200-II Headphones
No sound in right headphone, however if i hold down the wire in a certain position sound is restored. is this fixable?
Sounds like u have a bad wire, Its fixable depending on where the break is. If its near the plug end, u can head to ur nearest radio shack and get a replacement, however, if the break is in the leading headphone, though still fixable but requires a bit more tech savy. As long as u can operate a pair of wire cutters and a soldering iron, youll be good to go
May 23, 2011 | Sennheiser PX 200-II Headphones
Oct 03, 2009 | Sennheiser PXC 250 Consumer Headphones
Replacing headphone connector
May 14, 2009 | Sennheiser PX 100 Consumer Headphones
The 1/8" right-angle plug on my Sennheiser ear buds broke. I was able to get the piece out of my MP3 player, but I need to replace the plug - can you help?
IF THIS IS A STANDARD .125 90 DEGREE STEREO JACK(NOT FAMILIAR WITH SENNHEISER)THEN YOU SHOULD BE ABLE TO PICK ONE UP AT ANY LOCAL ELECTRONICS OR STERIO STORE.ITS JUST A SIMPLE MATTER OF SOLDERING IT ON.THEY SHOULD CARRY SOLDERLESS ALSO.BUT BE WARNED THESE ARE NOT PRETTY.HOPE THIS HELPS.THANX FOR USING FIX-YA.PLEASE RATE.
Nov 11, 2008 | Audio Players & Recorders
Cahnging plug
The standard HD25SP cable's 1/4" jack screws over the mini-jack. There's no reason for you to do any soldering. If you have a few inches of cord left from where you cut the plug off you may want to re-splice the cable back together to their corresponding colours. Then unscrew the 1/4" ******** to reveal the mini-jack.
Oct 11, 2007 | Sennheiser HD 25 SP Consumer Headphones
48 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
