Question about Dryers
Washer flashing F20
Flasing F20 in estimated time have to open washer
SOURCE: Fault code F20 on kenmore he2t clothes washer
I have a brand new front loader that never fill with water but shows F20. How can I get this machine to wash clothes?
Posted on Aug 09, 2008
SOURCE: f20 error code???
Ok, I found 2 solutions for this problem, I tried the first one, and it really seemed to work, but I think I will do the second one too.  First, if you have metal flood safe hoses, you need to look for debris blocking the filter at both ends.  I kept checking the screens at the washer end and not seeing anything, but there was debris located at the water supply end, stuck in the flood safe device that is in the metal hose.  Also, Flood safe hoses say to turn the water on to full pressure, but sometimes that can activate the flood safe device, so only turn your water supply on half way.  Make sure that the hoses are on right as well, the flood safe device needs to be at the end with the water supply, not the washer end.  You will be able to see the device (it looks like a little sieve) inside the hose.
Another cause of this problem can be the filter IN your washer, it is located in the front just under the front bottom removable panel.  If you have a pet in the house, definitely check this out, a lot of hair gets stuck in that.  Just unscrew the front bottom panel, and then it is right in the middle at the bottom, a cone shaped filter.  Get a towel, because there will be water in there, too. Check out this link with pictures: http://enginerdandwife.com/2007/03/kenmore-elite-h3-washer-error-code-hf.html
Posted on Aug 18, 2008
rylee_smith
  • 8619 Answers
SOURCE: F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Posted on Feb 08, 2009
SOURCE: What does f20 mean on the duet steam washer?
After a time the small hose that comes from the pump area to the pressure switch located at the top of the machine can clog.
Unplug the machine. Remove the top or the back of the washer. Locate the pressure switch near the top of the washer. It is about 4 in round and has wires and a 1/4 inch black tube attached to it. Pull the tube from the switch and blow through the tube until clear. Reassemble, plug in and test.
Posted on Feb 26, 2010
  • 1382 Answers
SOURCE: maytag the washer quits and a f20 or f11 shows up
Its a water inlet problem (no water or insufficient water supply) check your washer inlets, maybe the water valves are off or you don't have enough water pressure.
Posted on Apr 01, 2010
Keeps flashing f20
F20 simply means the washer is not getting the water level to fill in the amount of time that the computer alows to and therefore stoping the washing prosess. check the fill hoses screens for dirt and also the water valve screens. also make sure that water pressure is at least 20psi or more if not the water valve wont open or open slightly. make sure the faucets are all the way open too.
Feb 04, 2011 | Kenmore Front Load Washer
Flashing error code F20
wer
Sorry to read about your problem, I hope this helps you out.
F20" on display
(Water Inlet Problem-no water or insufficient
water supply)
1. Are water faucets completely turned on?
2. Are screens at inlet hose connection to washer
clogged?
3. Are water inlet hoses kinked?
4. Are water inlet hoses frozen?
if this issue's are ok you may want to contact a service company
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-20????
Check for any error codes in the Estimated Time Remaining display. The code "F20" indicates a water inlet problem. Press the Stop button twice to end the cycle and check that the faucets are turned on fully. Take a look at the inlet hoses. Close the valves and unscrew them. Look for any clogging on the screen and clear it.
May 17, 2010 | Kenmore HE2 Plus Front Load Washer
When the washer is washing a code F20 will flash
take the top of the washer off there is a book in there that will tell you what f-20 is
Apr 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Getting F20.
“F20” on display
clogged? Are water inlet hoses kinked?Are water inlet hoses frozen?
Dec 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No water is running in to washer and display F20 flashing
These things have an awful reputation for F20 errors. Take a look at http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore (Not written by me, but I just came across it) for some advice
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washer is flashing F20 what does that mean stopped during cycle and flashed f20
F20 means there is an electrical problem.
Click on this link to go to the manual and look at page 21.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0606184.pdf
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
Oct 18, 2009 | Kenmore Elite 45986 Front Load Washer
What does the F20 flashing code mean on whirlpool duet washer
I believe F20 may point towards a control unit failure.
You could try disconnecting it from the mains supply for a minute and plug it back in.
Hope this helps
Oct 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When washing stops and flashes f20
That code means "No water or Insufficient water supply" Check the water supply valve, the fill hose screen for debris... Good luck let me know if that solved it..
May 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hi!
“F20” on display
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
Dryers Logo
14 people viewed this question
Top Dryers Experts
