Question about Canon PIXMA MG5320 All-in-One Printer
Printer is offline - what do i do?
Cannot get the printer to recognize the PC. Printer is listed but computer says it is offline
Beni S-P
  • 1006 Answers
SOURCE: Canon MP 530
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Nov 03, 2007
IB4G2008
  • 3587 Answers
SOURCE: printer offline
go through control panel, printers, and select your printer..right click on it..bring it back online..
Posted on May 10, 2008
  • 199 Answers
SOURCE: printer offline or does not respond
oh my friend. just click the printer icon 1)click start on task bar. 2)go to settings or printer and faxes options. 3)in there you can see the printer icon 4)just right click that printer icon 5)there u will get the option 6)beside of which option there is a tick mark that is applied/enabled. 7)if there is tick mark beside the pause printing and offline option. 8)just click that option and that tick mark will go away and it will start working.
Posted on Jan 05, 2009
TMurdock
  • 93 Answers
SOURCE: Printer is offline to one computer but not other.
Ok what you need to do is network the 2 PC's together using a crossover cat5 cable ( can be purchased at Radio Shack). If you don't know how I can explain how to do that also.
Once that is setup one of the PC's with printer driver needs to be shared so the second PC can access. As long as PC 1 is on both PC 1 and 2 can print without issue.
I can be more specific if necessary
Hope this helps,
TankMurdock
Posted on Apr 23, 2009
  • 20 Answers
SOURCE: Printer says it is offline.
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi15
Posted on Sep 05, 2009
Printer is "offline". How do I get it "online"?
Off line means computer is not communicating with printer. Check the connections of the power supply and the network cable.
Sep 26, 2014 | HP Photosmart 7510
Not recognized to my pc
Reboot the pc without the cable attached. When you have rebooted plug in USB cable. Is the printer listed in Printers on the PC, offline, disabled...etc? If not, add a printer. I don't know your PC or your OS?
Nov 15, 2012 | Canon MF4450 AllInOne Laser Printer
My canon i9900 is offline
It usually means that the printer is off, not connected to your computer or your computer does not recognize it. If your computer doesn't recognize your printer, go to control panel and click on add new hardware, then follow the directions . After trying all the above try using your printer once again.
Mar 18, 2012 | Canon i9900 InkJet Photo Printer
Can't print. Lexmark has an x by offline
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 10, 2012 | Lexmark X6150 All-In-One InkJet Printer
It says it's ofline
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.PC Instructions
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
May 23, 2011 | Office Equipment & Supplies
I have brother Printer HL 2140 . This printer become offline automatically after some time & does not print. how we can solve the problem.
hello
printer becomes offline if it is turn off or the pc not recognized the printer.
solution: check the cable printer, transfer cable printer port to another port in your computer, if the problem still occurs re-install the printer driver.
thank you
Mar 08, 2011 | Brother HL 2140 Laser Printer
My HP deskjet D4260 is offline. I have tried everything to resolve this but cannot find a way of etting it back online. Please help
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
    Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Mar 02, 2011 | HP Deskjet D4260 Printer
Printer is offline. how do I get it online?
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online. Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Feb 28, 2011 | HP Office Equipment & Supplies
MY HP PRINTER D2460 TURN ON BUT THE COMPUTER DISPALY IT OFFLINE
the Deskjet 2460 is recognized bij my computer and shown as the standardprinter but when I want to print something it does not work
Oct 26, 2009 | HP Deskjet 2460 InkJet Printer
Printer offline
first of all when you upgrade your computer you deleted all your program thats why your computer cant recognized your printer. do you still have the disc the came with the printer if you do dont worry the only thing you should do is restall the program by inserting the disc into the computer and then follow the steps in the screen.
Apr 24, 2009 | HP PhotoSmart C4385 All-in-One Printer
Canon PIXMA MG5320 All-in-One Printer Logo
19 people viewed this question
old marine
old marine
