Question about Dirt Devil Easy Lite Quick Vacuum
Cannot remove canister to empty - Dirt Devil Easy Lite Quick Vacuum
Release button to empty cylinder wont work cant get it off manually
Hello, the canister empty function works by pulling a long plastic rod that moves the catch on the bottom access door. It sounds like either the puller is stuck or that the rod may be broken. If the puller does move upward when pulled, then the later in most likely. You can check by removing the Torque screws and pulling the top section off very gently, because the canister really needs to be opened and removed first, do this outside to avoid a dirt spill in the house, either way I would look for a used canister from another machine, which is really a much cheaper and less dirty option.
Mar 07, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do I empty the hvc-22
If you are meaning the DC24, like your post seems to be tied to, the manual can be found here:
https://www.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/DC24_Manual.pdf and the pictures for removing the canister and triggering the lower empty-hatch are on page 3 under 'Clear Bin Emptying'.
Good Luck!
Jul 13, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
No power from unit
my dyson canister vacuum will not turn on. it cutoff mid use and now will not tuen back on. checked filter, checked head, removed debriss from head and emptied canister with no luck
Feb 03, 2014 | Dyson DC23 Bagless Canister Cyclonic...
I have a dirt devil easy lite... how do I empty the top canister? I know how to empty the bottom half.
The upper half is where the filter is.
Here is the manual:
http://dirtdevil.com/file/172/
Page 7 shows after emptying the lower container, "Twist and lift to remove dirt container lid."
Aug 06, 2013 | Dirt Devil Easy Lite Quick Vacuum
How do we remove the twin canister for cleaning from our DC11? It is over full and no matter what we have tried in terms of pushing in the "button' at the top of the canister/s and/or the...
For advice on removing and emptying your DC11's clean bin, please refer to our online support guide for this model:
http://support.dyson.co.uk/support/dc11/dc11-all-floors/how-to-use-your-dyson-vacuum/emptying-the-clear-bin-step-1
I hope this helps - if you'd like any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Aug 28, 2011 | Dyson DC11 All Floors Bagless Canister...
Hi, im hoovering my mothers house whilst she is away, using a vitesse pet lover, but now the cylinder is full and i can work out how to open it so i can empty it. thanks
Lift the catch where the canister lid joins the handle, then pull the whole assembly away from the handle.  Take the assembly to wherever you want to empty it, then press the button at the bottom front of the canister.  The bottom swings down and the muck falls out.  In the ideal world, you will then take the lid off by twisting it slightly anti-clockwise (you'll see the "lock" and "open" markings on the canister rim), remove the pleated filter (again by twisting anti-clockwise), give it a good shake and then brush between the pleats.  Reverse this process to put it back together, and away you go again!
I hope this helps. Any more questions, just ask. Please remember to rate my response, thank you.
Apr 14, 2009 | Electrolux Vacuums
WATER FLOW
ok . i may have read you post wrong but i think you want the vacuum to empty itself ? i never heard of any vacuum emptying itself ......... the water or dirt goes into the canaster . when full remove the top and dump the bin . some than a drain plug you take out when your over a floor drain or outside ........ if this answer helped please rate 3 or 4 this high rateing will keep me in the paid answer department thanks you ..........if i misunderstood your post i am sorry , just leave a comment i will get it and try to help
Apr 03, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Kenmore Quick Clean - how to remove dirt from cannister
this is the web site for Kenmore owners manuals
--->http://www.managemyhome.com/mmh/<---
Please take the time to give this solution a fix ya rating
clarkco
Feb 27, 2009 | Kenmore Quick Clean 30012 Vacuum
Round filter clogs often
The Flange in question is about one inch tall and and approx 4 inches circular ..... When you pull the canister (container to empty) off and empty the contents in the trash .... some of us tap it to get the excess out or off the sides ..... That Flange is the rubber piece attached to the bottom of the darker gray cylinder inside the canister you are emptying. When you tap the canister or after dumping it numerous times that flange can work itself (slide) up the darker gray cylinder ...... it needs to be slid downward and overlap the bottom when you close the canister from dumping it. You can remove the flange and see the grooves .... replace it back on with it hanging off a little to allow for overlap. That should decrease the amount of excess being trapped in the filter. Hope this helps.
Jul 10, 2008 | Dyson DC17 Animal Bagless Upright Cyclonic...
Emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Aug 02, 2007 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Dirt Devil Easy Lite Quick Vacuum Logo
42 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
